Sump extensions, benefits & products available?
Yeah, that doesn't necessarily mean that it flows. If the exit side pipework is blocked somewhere (in the hose, in the nipple that it returns into the motor/plumbing, etc), but the supply side is not blocked, then when you crack the bleeder you will get flow from the open side. But when you close the bleeder - no flow. And.... therefore no heat. You might have to work a little harder to prove it to yourself. When I bought my engine the entire IACV bleeder was choked with cooling system schmutz. I had to clean it and the pipework out before it would work.
"The outer is separated from the inner by the rubber" duh....I know that, I should have figured that out, gheeze. thanks, I'll replace it.
Hey Yeah ill be there ! Hussling hard now to get seat time and make car all good see if can get some early track time over east 🤞 Itd be really nice to have some luck 😁
The two tyres U have mentioned are the same height as the profile height is a calculated percentage of the width
appears to be, I loosened the bleeder on top IACV and coolant came out.
