Faulty Coils? Misfire At High Rpm? Read This.
Zahos
This thread follows on from this other thread, where people were having problems on boost b/c of cracked coils. In most cases coils were not actually faulty themselves, but due to fatigue, or who knows what, had developed small cracks where the spark could jump from..... (I guess same principal as cracking the ceramic coating on a spark plug).
Anyhow, I said I was going to follow up on this issue by reporting the progress of my coils where I melted more plastic over the crack with a soldering iron, and also get them plastic welded, as I feared the melted plastic would not stick due to the fact that they are made differently, and that they didn't fuse together properly.
MELTING:
The plastic I melted on is showing signs that it is coming off (as expected), so don't bother trying this... seriously!
PLASTIC WELDING:
I took a spare set of coils I have to get plastic welded, and after testing the plastic, I was told they could not be welded! They said some plastics can't be done, and this is one of them!!!!
BUT.. he made a very good suggestion.
EPOXY GLUE:
If you look at the back of your coils (the tallest part), you will notice it is a clear / yellow type of plastic, unlike the rest of the coil. This in fact is simply made from an epoxy resin (like Selley's Araldite), and that's all it is! So rather than spending my money on welding that would have cost me a few $$$, he told me that spending $5 on some selley's Araldite would be by far the best option.
Simply clean the surface VERY WELL, and mix up some Araldite and slap it on - problem solved! And you shouldn't have to worry about it coming off!
Only thing is, you will need to give it about 48 hours to dry properly (maybe more), before you can put them back on.
Hope this helps a few of you out there.
Zahos
EDIT: Added a crappy pic of where to put glue (area in red)
Edited by Zahos
  • Replies 148
Posted Images
Well i've tried this and so far it has given me noticable results.
About 2mths ago I taped all 6 coils which gave a noticable improvement. I then replaced #1 and #4 coils with 2nd hand standard coils and got another noticable improvement so obviously the 2 I pulled out were slightly faulty.
I spent the last 2 days covering these 2 coils with about a 2-3mm layer of araldite and fitted them today. I let the car warm up for 10mins and then took it for a quick burn and their was a noticable improvement so I left them in there. I had no hesitation and my car felt the quickest it has been in the last 3 or so months.
I've just started covering another 2 in araldite (very time consuming coz it takes about 3 days per coil to completely cover otherwise it just runs off and drips everywhere but where you want it). Hopefully by about wed-thu next week i'll be completely done.
I bought the twin-syringe 24ml "clear drying" araldite at bunnings for $13. Looks like im using around 6ml per/coil so i'll need to get another 24ml twin-syringe stick.
Gee You used a fair bit then....
I could have gotten away with the tiny tubes you bu for $5...
Did you cover the entire coil?
I only covered the section at the front that is most prone to cracking.
I had the syringe from another job i did last year and I still haven't used half...
I did all 6, 3 times also putting a little on each time to avoid dripping...
I gave it about 1 hour between coats, and let them rest in different positions each time so the glue runs in the direction i want it to, also moulding it as it dries...
here's some pics I just took of mine...
so will a few cracked coils cause hesitation?
I seem to have this problem. replaced the sparks and reset the ecu, fixed for a few mins then back to hesitating.
maybe i should check the coils,hmm. btw it seems to hesitate at like 5000rpm, maybe sooner, and then rev out fine to redline. is this what you guys were experiencing?
well, I generally mean in 2nd. you know, sometime you'll just floor it all the way through to redline to get to 100. I only do this to make sure the car is running ok. for quite a while when doing this the car has felt a bit weak. the hesitation is really annoying. just cant work out the exact problem. The majority of it has developed since i installed an FMIC tho
I replaced spark plugs with NGK BCPR6ES, and while i was changing them i taped up the coil pack stems; have i taped up the wrong thing? Should i be taping up/aradite'ing the black box things? Should i only tape them up if there are cracks or do it anyway? I was experiencing some missing aswell but since the new plugs and taping the stems it has dissapeared...
- Even one cracked coil can cause a lot of hesitation!
- i was getting it between 4500 - 5500 rpm, and after that it was all good, it would rev out nicely...
- When i taped mine the problem went away, but after a week or two, came back b/c the tape shrunk on the coils, exposing parts of the crack once again
- I would be doing this to ALL of the coils, regardless of wheather there is a crack there or not, as it could crack soon anyhow as the others have....
you know that the 5 minute expoxy is pretty good ... means you could do all 6 coils, 3 times in about 2 hours ...
I will be trying this epoxy glue this week, as I am going to place a new turbo on the car and I don't want this popin to come back and as the weather has heated up the the tape must of shrunk or came loose and I have a little poping back, but nothing like before!.....epoxy here I come!:)
    • @Butters I can't tell you why but the bigger HKS step 2 cams improved low and mid end immensely. Turbos started spooling about 1k RPM less than before and the idle/vacuum was rock solid, it was an absolute thrill to drive, 3rd gear pulls hit 180kmh where previously only managed 160. Conversely, the milder poncoms in there now have a funky idle making it harder to get off the line, drives poorly in lower revs, laggy and makes less power/torque throughout. Feels better after I swapped the EBC but unless I put it on the Dyno again, I can't say how much better.
    • Hi Sydney kid   do you still selling spring and blistein shocks for Nissan 260rs? Air any suspension upgrades? Please advice     yudy
    • Cams are not needed at this power level, they will create lag. The cam gears are a good idea though.
    • @Murray_Calavera yeah, I guessed as much, cooler temps, more boost, less knock, more timing, hello power. Unfortunately not quite within reach ATM, could upgrade my whole fuel system to support but still wouldn't have E85 to run it 😂  Anyway, I changed cams again, 260/260 poncam B and everything else the same except an EBC upgrade. Now I must say I was quite disappointed with the result as it was like running stock cams (didn't try to dial them in as they're supposed to be optimum already) but after awhile I suspected my new EBC was underperforming not to mention difficult to use. I recently swapped back my old EBC and it drives much better now, boost comes on sooner, more stable, no spikes etc, feels all quicker and faster than with stock cams. Planning to fiddle with the cam gears and see what happens but maybe skip the Dyno as I intend to revert to the HKS cams cos they really made the car come alive; low and mid end was unbelievable and it just wanted to rev to the moon, finally knew what people were raving about, RB26 really loves revs. Anyway, Dyno 03 is quite disappointing, in Dyno 02 although peak power was less and trailed off at the top, the low and mid end improvement more than made up for it.
    • @Darrel It's so tempting to say e85 is borderline magic. It cools the intake charge, so if you're flirting with the edge of the turbos compressor map it helps dramatically cool down the hot air the turbos are pumping. It is very resistant to detonation so you can crank the timing, I don't really want to say you won't be knock limited anymore.... but you probably wont be knock limited anymore lol. I wouldn't be surprised if you made 20% more power swapping to e85 (provided you have the fuel system to support them, bigger injectors maybe bigger pump etc).
