Faq – General Maintenance
Guest RedLineGTR
Guest RedLineGTR
Frequently Asked Questions & General Guides.
Electrical
-Headlight Gone Out (Left Side)
-Misfire Problem, Boost@4500-5500 RPM?
-Resetting the ECU?
-How to clean your AFM?
-HICAS Diagnostic & Codes?
-Aftermarket Tacho wiring diagram
-The Best Way To Disconnect a Car Battery?
-Dangerous power cut/jerks during WOT + high boost?
-Why does my speedo bounce and flick around?
Mechanical
Spark Plugs
Oxygen Sensors
Brakes
Clutch and Gearbox
Oil
Heating/Cooling
Servicing
Intake/Exhaust
Other
Interior
-Liquid Comin From Front Foot Wells?
-Door Window Tint Getting Scratched
Exterior
-Windscreen Rubber replacement
Misc
-Engine Firewall Blue Plate What's the Deal??
Maintenance Guides & Car Specific Problems/Issues.
R31
-RB30 specs, maintenance & modifications
R32
-Diff & Gearbox Oil What To Use
-R32 Gtst Timing Belt/Water Pump Part.No & Price
-R32 Oil Pressure Gauge Display
-Taking/Removing R32 Headlights?
-Where Is The Fuel Filter On A R32?
-Dodgy Climate Control Display?
-R32 Maintenance Parts and General Info
-ATTESSA Fluid Change + Bleed
-Handbrake Light Stays On !!
-Clear Indicators - GT-R and GTSt
-Rust Areas
-Steering Rack Boots - Repco Part number
-R32 GTR Low Oil Pressure / Oil Pressure Gauge Problems
R33
-Gearbox Oil Change
-Spark plug change
-Changing Parkers on an R33
-A Guide to Changing Your Oil & Oil filter In An R33!
-How to Change your own brake pads (Front + Rear)
-R33 Headlight Maintenance
-R33 Rear Seat - How To Remove?
-Blow Off Valves on R33 GTS-T??
-Gear box noises possible problems?
-Moisture in Headlight
-Steering Wheel Removal (Airbag)
-Water Pump Replacement RB25/R33 Whats Best?
-Clutch Adjustment Is It Possible?
-Common Rust Areas (R33 Specific)
-Adjusting Fan Belt Tightness!
-R33 Rear Brake Light Not Working?
-RB25DET stuttering/hesitation under load
R34
-R34 GT-T Spare Key Cutting?
-Removing Your R34 Shift Knob?
-R34 GT-T Spark Plugs, What to Use?
-R34 GT-T How Reset Your Stock Ecu?
-R34 Air Conditioner & Air Filter Maintenance!
GUYS USE THESE GUIDES AT YOUR OWN RISK. IF YOU HAVE A QUESTION ABOUT SOMETHING THAT YOU'RE NOT SURE OF PLEASE POST UP!! NO PERSON BUT YOURSELF TAKES RESPONSIBILITY FOR YOUR ACTIONS... and no person but you takes away the satisfaction of maintaining your Skyline by your own hand :P
Guest
