Brake Pads Users Ratings Guide
Guys and Gals,
I thought I'd chuck together a thread where everyone can post up the brake pads they have used and what they thought of them. I'll try and keep a summary up in this 1st thread as a quick glance resource. I'll list the pads as people post them up under three headings as either track only pads, track/street pads or steet only pads. For the summary I'll do a simple :) next to the pad name if people like them or a :) followed by a reason if people don't like them. Also if people can list where they got the pads from that would be great too. If you want anything else added let me know.
Track Pads
EBC Green :) (poor performance and taper wear)
EBC Yellow - OK but not as good as DS3000's
Ferodo DS3000 :)smile.gifsmile.gif
Ferodo DS2500 :) (rears) :) (crumble with hard use)
Performance Friction Carbon Metallic :P
SBS Dual Carbon :)
Track/Street Pads
Bendix Ultiamtes smile.gifsmile.gif (Light track work)
EBC Green - OK But not as good as DS2500's
SBS Ceramic Carbon :)
Street Pads
I'll start my own thread then :P
I currently use in my GT-R Ferodo DS3000 pads in the fronts and DS2500 in the rears. I think they are great. Can get a little noisy if I haven't done much hard driving but after one good session become quiet again rather quickly. For me I love the progressive bite - but they will bite hard given a firm press. I get mine from John @ UAS and would highly recommend them for a track set-up.
cool.
ds3000 good feel ,consistant, used on v8 brutes. the discs crack before they break up.
ds2500 pretty average not very bity. and crumble with hard use. (since 3000 came along) but once warm ok.
ebc green. garbage and extreem taperd ware.
sbc ceramic carbon. awsome street/track pad. long lasting and dont overheat the disc. my pic for steet/track
sbc duel carbon. very good aswell. more track orientated. long lasting and take an awfull lot of heat. (targa favorite)
performance friction carbon metalic.
omg insane pad. so easy to use and instant pedal responce. my pic of the list. but due to the fact that they work so well you cant tell your overheating the discs. cos they feel the same from warm to a orange hot disc. (as used in most top level motorsport. nascar,v8 supercars etc etc)
bendix ultimate,ferodo formula,metal kings etc etc. pretty crap and good for going up to the shops.
i haved used all these pads in my gtr with 355mm rotors and brembo f40's (38,44mm pistons) and im hard on brakes. once you get good brakes you seem to explore there limmits hehe
Dave, where can you get these from, how much will they set us back? For a track gts-t, what would people recommend?
I've been using factory pads so far and they are working fine, no fad. Have just brought some new Bendix Street Road Track to see if I can shortern the distance down a bit. But very impressed with factory brakes!
If there spongy it's in the fluid not the pad, but 180km/h plus and braking at the 100m mark into a 2nd gear hair pin lap after lap, no fade. I'm impressed with the factory brakes. :O
This topic is a good idea, pity about the lack of response.
Anyway, I've had good results when doing sprints at QR, Sprint circuit, with Bendix Ultimates. Great bang for buck but not a race pad. So thinking of EBC Yellow stuffs, which are supposed to work cold too. My big concern is rotor wear, but seeing noone uses them.............
Using RB74 front and rear pads. Stock rear dics and 4000 series (non-slotted) fronts on R33 GTSt.
Good pad, warm up in one average stop first thing in the morning, can be very noisy if you don't grease the shims properly. Definately better than Nissan pads that seem to leave material on the disc after hard driving (makes discs feel temporarily warped)
Been used around QR and seemed fine and dandy. But I've only got 170rwkw.
my 2c - some of this is second hand tho
DS3000s - high friction 0.62 so very grippy - works well at high temp - tough on rotors (maybe only at low temps tho) - manufacturer says "NOT suitable for road use", presumably because of the rotor wear issue
EBC Yellows - quite like DS3000 - similar price so you might as well use the better DS3000s
DS2500s - med friction 0.5 so not as grippy as DS3000s - dont eat rotors - good for track and street
EBC Reds - quite like DS2500s - similar price so you might as well use the better wearing DS2500s
EBC greens - med friction 0.55 - everyone says they're crap but they worked ok for me on street and light track work
You should use pads of the same friction coefficient front and rear unless you want to change the brake bias.
what are people's thoughts on the endless sss or ssm pads? looking to get these sometime soon. 90% street work, the rest on twisties or track.
Recommended...
I've been running the SSS pads for a lil while now. For what you've said you'll be using them for - low noise, low dust and still good after 4 laps of Sandown...
In my time with the 34 I used:
Endless Euro-X (front) and Endless NA-R (rear)
Great for track, no fade after 5 laps, but poor pedal feel and noisy when cold so not the best for street. These are now old parts replaced by newer Endless pads.
Bendix Heavy Duty (front)
Put in as a stop-gap measure cos my front pads were too low before a track day. These pads were crap for my application, poor pedal feel on the street, dusty, wore quickly, faded after 2 laps but didn't go away completely.
Queensland Friction Materials (QFM) A1.RM (front+rear)
Good compromise pad for those on a budget. Good street feel from cold. Good performance on the track with only a slight fade on lap 5. Kind to rotors, low on dust, and cheap, ~$120 per pair (about 1/3 the price I paid for Endless).
I should mention what really helped was also:
- decent fluid (Endless fluid or Motul Factory Line)
- decent rotors (basic upgrade to DBA/RDA slotted rotors of stock diameters)
- cooling (cutting away the guard plastic in front of the front wheels to allow airflow, removal of dust plates)
- braided lines front and rear
- master cylinder brace
- proper bleeding procedure
Im using the SSS 500 deg front and 380 deg for rear for almost 1 year. Been on a lot of twisties all year round and does mostly street. No noise at all and quite low brake dust with plenty of bite. Though some ppl use them find them to be squeky on low speed though i haven't experienced this before.
Any price is acceptable and gonna change the pad in 2 months time.
Dunno how I missed this thead til now.
Snowy, what's the reasoning behind DS3000 front and DS2500 rear?
I have used:
Bendix advance - as dave says, fine for going up to the shops.
Bendix Ultimates - Nice and bitey, better than advance, chew through rotors like a fat man munching down on an old twix, wear out quickly, dusty, can be noisy.
Ferrodo DS2500 - long wearing, heat rotors pretty badly making it very easy to crack them, don't chew them though, cheap for performance pads, can be used on the street although an emergency stop when dead cold wont be too great, don't need much heat to negate this at all though.
    • Full results via link below https://docs.google.com/spreadsheets/d/1inu1mRRO0WjV2-3vGYsjnmYggVOzmApWOby68GwPGcI/edit?usp=sharing
    • Have I not posted since 2022 - wow. Yes, it's pretty much finished mechanically. I'll probably sell it soon as the old man is 80 in November, so 99% he won't ever drive it again. I don't really need 3 GTR and I haven't driven any of the GTRs since September - Correction, once drove my 33 earlier this year on Australia day. All of them have been like this since then.
    • So, after talking to Tyson at Auto Tech Engineering about my "cunning plan", he suggested to "not piss money away on stuff that the car probably doesn't need" (the max IAT at the end of the 1/4 ever only seen around 30°C, which is in no way a issue, and as such, for what I use the car for I really don't need colder IAT anyway The whole point of the "upgrades" that I thought about doing was that my IAT started creeping up from 25°C to 30°C when cruising, then drop back down, then raise back up, rinsing and repeating, it has never done that before, so after talking to FI interchillers they assumed that it was the Bosch pump starting to fail, and if I was going to replace the pump....... I would do my usual thing of "while where in there" But, Tyson said he has seen similar things happen to IAT with failing or leaking AC compressors on other cars with interchillers, and as the AC compressor is 22 years old it is probably well on the way out anyway, and if a electric water pump fails it stays failed and doesn't just speed up and slow dow, but if a AC compressor starts to fail or is leaking, it will fluctuate and give a typical result to the IAT He said he could test the compressor and see how it is functioning and pressure test the whole system, but, as I do, I've just got them to order a new compressor to install to start with, and do a AC service and see if that fixes the issue That way, if it is the compressor, I wouldn't be spending lots of coin on something that wasn't the issue, and not actually needed, as the stage 2 kit, and pump, comes in at around $2k in parts alone, not including the plumbing and other parts that will be required or labour  And apparently the Bosch pump I have is really reliable and well up to task for the flow/pressure requirements that I need to keep my intercooler and massive amounts of boost heat (7 psi LOL) under control giving a nice and cold IAT A big shout out to Tyson for this, not many people will talk a idiot out of wasting money on car modifications, and the saved car budget funding can be wasted elsewhere on things that I may, or may not, need, like a nice new leather SS interior with red stitching......maybe I can convince the Minister for War and Finances into a nice trip down to Victoria for a week away to see the sights (I'll explain that I will need a hire car once we're down there so we don't have to worry about the Commodore being parked up on the streets at night, and it just so happens there's a joint that I can store it during that time) $1680 for all of the interior trims, + installation cost (I'll ask for a quote to install the trim if the new compressor fixes the issue)   https://leatherseats.com.au/products/leather-seats-trim-skins-kit-to-fit-vt-vx-vy-ser1-ss-green-black-diy-install
    • Anyone here know the answer?....missing since the w/e...
    • Google tells me that's a Japanese Rat Snake... 2m long? Man I think Australia has traumatised me to think all snakes are dangerous unless they're pythons. Also... "16 years later..." is that a record on SAU @PranK?
