"the Olds" & The White Wreath Assoc Say Thank You !
OLDS
The WHITE WREATH ASSOCIATION notified us OLDS of the receipt of your $200 donation, today. The cheque was received last Friday (Thanks to Brenton who collected it and passed it on to them) On behalf of the White Wreath Association OLD Jules & myself would like to sincerely say THANK YOU .
The White Wreath Association will send Brenton a receipt for the money & a Certificate of Appreciation...made out to the Members of the South Australian - SAU.
Briefly, if you missed the White Wreath Association (a voluntary organisation) display in Vic Sq last year...it was breathtaking, not only visually but the reason behind each wreath - more than 2500 Australians last year. Thank you again, for helping us OLDS raise awareness of this silent epidemic that is killing so many in our community.....you can & have made a difference
"the dr1ft_pig13 OLDS" (Mark & Jules)
Edited by mark03
