Cruise From Gc To Dyno Day 24th Feb 2007
Grrr
This is for anyone wanting to go from the Gold Coast to the Dyno Day in a little cruise so no one gets lost. Anyone is welcome to cruise up - whether you are participating or just watching.
Meet: Nerang Mac Donalds @ 8:30am
Leave: 9:00am
Stops: (none at this stage - but maybe a petrol stop and possibly after the hway exit if we lose anyone)
Arrive: Allstars Geebung @ 10:00am
Bring:
- Toll Money (its about $2.50 now)
- Camera
- Shiney Clean Car
- Music for a boring and legal 100-110kph drive to brisbane with no silly business
- Smile
I understand that parking at maccas on sat morning might prove difficult; but my stomach says that it is a very good plan and i dont think there will too many of us to worry at this stage.
Please post your interest (hint hint nudge nudge seriesII and bsd-gtst)
Hokay so...
Well looks like its just brad and myself heading up. If anyone wants to join us you still can. You'll know where to find us.
