Crazy Gen-tt Skyline Fires Up!
Crazy Gen-TT Skyline Fires Up!
[flamesuit on :(]
For those that have been following the progress of the LS1 and Gen-TT R34 Skyline being built by GT Autosound in Adelaide, the good news is its now fired into life, and man its one mean sounding Skyline!
Listen to the engine as GT George gives it a good solid rev for the Camera!
(Right Click and Save Target As)
http://doughy.theddrzone.com/MOV00705.MPG
The LS1 would be lighter would it not?
All alloy. :)
With all the rest of the bs there i doubt the f/r weight balance has improved at all. Its still more than twice the capacity of a 2.5, double the turbos etc. more pisons more rods etc etc. Just because the block is alloy doesnt make it all good.
A rotor would have been a better choice
However if it did end up with a weight balance same as stock or better i would be a huge fan :happy:
btw gotta love the chopped rad support :)
Also im sure cars like this are great at getting people from both worlds together and into their workshops spending money. But how great will the car be in a drift comp, i dont rem the pink s15 every achieving much...
GT autosound are a car audio shop... do they even do this sort of work for the public?
However if it did end up with a weight balance same as stock or better i would be a huge fan :)
an ls1 weighs about 400lbs, where as the RB weighs around 700lbs
it is only as long as an I4, so it sits further back in the engine bay
so not only is the whole car lighter, there is better weight distribution.
no matter what way you try to skew it, it will come out lighter
