Entries updated to public
Nah. I reckon that that is the HICAS CU. Just the large plug, PS specific and other I/O. I can't see that there'd be a need/want for the (non-HICAS) PS CU to be watching any of those inputs other than the speed sensor.
Is there coolant flow to (through) the IACV?
I replaced the entire IACV assembly with new unit from Nissan, idle acts the exact same, starts and runs with idle rock solid at 900, as soon as I plug in the solenoid from the new IACV the idle races up to 1400, even with idle adjustment on side back of intake manifold maxed out for lowest idle still way too high around 1200. Again if I unplug the IACV, turn idle screw to about half and it runs fine at around 900. thinking about just leaving it unplugged, do not ever plan to drive it when its cold, and always stored in climate control garage, just sucks to spend 500 dollars and have no change, could have left the original at this point. any other thoughts as to what it could be? maybe not even worth pursuing? that is if cold start idle aid was the only reason for Nissan to have this part anyway. tried AC and other loads and it never seemed to push idle below stall.
I don't know if this is accurate. The EPC places the EPS control unit somewhere in the engine bay or somewhere in the interior near the firewall, presumably because the things it's controlling mostly live up in the front of the car unlike HICAS which has a whole steering rack on the rear axle to handle. @D.phantom The R32 GTR manual actually has more than I give credit for talking about the non-HICAS cars: You can probe the pins on the diagnostic connector directly to read the EPS solenoid voltage as far as I can tell following the flow chart.
