R34 Traction Control Cancellation Circuit!
Do you find it annoying to constantly turn your TCS off?
Do you wish it defaulted to 'TCS Off' the second you started your car?
If you answered yes to either of those questions, this is for you!!!!!
The device when fitted to your car will instantly turn off the traction control, you now have to press the button to turn it on! (reverses the factory setup) The circuit can also be wired so that it's selectively on (great if your girlfriend is going to drive the car and you want TCS to come on the second she turns the key!!!!!!)
Easy to wire with only 3 wires to the ECU in the boot:
Only $30 + Postage
Actual unit may vary slightly from picture, new improved wiring version only has 3 wires!!!
Not that im that lazy,, im not to bothered presing the button, but, if it automatically turns off, does this mean the ""TSC OFF"" dash light is always on????
And isnt it just as easy to remove the fuse :)
Awesome work on finding it though
Yes 'TCS Off' is the default.
It's not as simple as removing a fuse, I wouldn't recommend taking a fuse out, this actually buggers up a few of the other systems that rely on the TCS and will give the SLIP light as well as the car detects an error. You also can't turn it on if you decide you want to, you'd have to mess around replacing a fuse.
The other benefit is the switch still works, just in reverse...you press to turn on. This circuit just reverses the operation of the switch
It took me a while to build these a fair bit of trial and error :)
Yeah its a pain in the ass turning tcs off, or sometimes i forget and try to light the wheels and it stalls :) were bouts you located? i'll take one...
Exactly what I mean!!!! I find I get owned on corners where the car *thinks* it would be a good idea to drop engine power.
I'm located in Brisbane, PM your details and I'll get one on it's way.
Not with anything over stock power, slows you down by kicking in all the time. It sucks!!!
Or if you have a valve body upgrade :laugh:
Only $30 will prevent you from forgetting to press your TCS button and looking like a chump as you get flogged by a barina and your car is still thinking about giving 3 cylinders back to you.
I bet I'll still be beaten by a Barina
Also Dan, missed your MSN message the other night - I'll take you up on your offer :rofl: Cheers!
Installation will happen tonight - will post up results tomorrow morning! Now it's just a matter of turn the key then slide; instead of turn the key flip switches like you're in a fighter plane then slide :)
On the topic of the ABS though; what happens if your car does not have ABS or it was removed?
    • New R34 owned here (from the US) and found a gem, '98 GTT with ~6k miles, super clean & completely stock. When shifting there's no grinding, shifts smooth, etc. The concern I have are 2 things: 1) Only in 2nd and 3rd... when maintaining a slower speed (in traffic as an example) as I let off/on the gas, the shifter will slightly move and vibrate. If the clutch is engaged, none of this happens. It's not bad, but enough to feel like something isn't necessarily right. 2) This mainly happen in 4th or 5th... the shifter slightly bounces up and down, almost like it's riding on unbalanced tires (and I do think the tires are unbalanced as I get a little of that bounce feel at higher speeds, which is maybe why it only happens in 4th/5th). Lastly, and sorry for this noob question but I want to work on this car myself, can someone teach me some on these manual transmissions? Like servicing them, best products to use, etc.; would be greatly appreciated. Thanks!!
    • Coilovers aren't even the first step. Bushes, subframe position and alignment, HICAS elimination, adjustable upper arms and traction arms in order to dial out understeer. All these things need/deserve attention first. ARBs (There's no such thing as a swaybar. Please, everybody, stop calling them that) are useful if you want to limit spring stiffness. Otherwise you can control body roll with springs. Spring and damper rates are a function of road surface, speed and usage. There is no solution that works for all cases.
    • Define "nothing". Is the starter spinning but not the engine? Engine turning but not firing? If the engine is turning but not firing, then you are missing either fuel or spark. You need to find whichever has gone missing.
    • Shitbox Tiguan updates, got the APR OTS tune put back on (no charge for it to be removed/added back), didn't want to just come in just for that (not a fan of wasting people's time for nothing) so I purchased an APR dog bone insert. The boys at German Performance Garage said they would fit it for free too since they had 1x hoist free. Now that's service you don't normally get from most workshops. Anyhow, tune back on, snow grate pulled out, dog bone insert back in and not going to lie, a few smiles when I nailed it around the industrial area heading back onto the M7. Amayama also said 1 to 2.5 month wait for the RB25DE heater hose, yeah why not, car has been off the road for nearly 3, what's a other 2.5?
    • Hmm I'm going to approach this from the other side... What is the car doing that you don't like or what would you like the car to do that is currently isn't doing (handling wise that is)
