Some Angry Stagea Youtube Videos
AlexCim
Here are some angry Stagea youtube videos for everyone to enjoy
Stagea on snow
Video 1 -
Video 2 -
Video 3 -
Weird, that guy at the snow has the same name as me. :) Funny actually, I already know a guy called Alex who has a white S1 like me and a yellow S2 (both for sale)
260RS Stagea donuts, got no clue who is it though...... :(:happy:
Video 1 -
Dyno runs
Video 1 -
Video 2 -
Video 3 -
Video 4 -
Some burnouts
Video 1 -
Video 2 -
Video 3 -
Video 4 -
Video 5 -
Video 6 -
(Very angry exhaust)
Skid pans
Video 1 -
Video 2 -
Sliding
Video 1 -
Video 2 -
Enjoy!
Yeah, that Alex dude is one crazy MoFo! :laugh:
Nice work, I bet that was heaps of fun! Teh Stag slides very progressively, I've noticed... One of my mates has a long, slightly winding driveway leading to his house and that.
