R34 Front End Conversion
darrinspencer
I have started the front end conversion finally. Once complete I will do a "How to do step by step"
Process so far
Strip standard front and side skirts
Remove radiator, AC condensor, and all other parts fitted to radiator support
Remove radiator support
Fit fibreglass guards
Make custom bonnet hinge spacers
Mount bonnet hinges and bonnet and align bonnet and guards gaps
Fit front bar reo and headlights and align and fit front bar cover
Reshape inner guards/skirt behind radiator panel to suit r34 radiator support angle behind headlights
This is where I am up to. Need approx 1-2 more hours work fitting radiator support and one last trail fitment of the whole front. Once that is gone and perfect the radiator support panel can be welded in.
Then it will be just a respray of the full front and front doors, and put it all back together
More details and photo's to come, just need more time :laugh:
  • Replies 51
silly question time - why the fibro guards? are they any different to the OEM steelies?
Looks good BTW
oh and ummm... theyre not... fibro....
However, should you choose to use fibro guards, please use a water-based paint when you get to that point - it's better for you AND the environment! :(
Hey DS; looking hot! Good to see all our goodies have played their part in your build!
Can't wait to see the final result!
Unfortunitly R34 GTT bonnet hinges are different to GTR and the R34 GTT bonnet catch is the same as the Stagea, so I had to buy genuine new GTR hinges and GTR bonnet catch
Still have not fitted the R34 brakes yet, but will do soon.
Grille sold to EAG4IT
He's got an S1 :P what would he need it for?
Front bar still availiable, needs minor repair $300
My 40th coming up this weekend - I'll ask my good wife, she's feeling pleasant towards me atm.
