Car Booked In For A Tune Safc Ii
WogsRus
Ok so
so far the car has got all the supporting mods
Walbro Gss432 pump
adjustable fuel pressure regulator
full 3" exhaust with dump pipe
HKS pod and intake
boost regulator
SAFC II
FMIC
New 02 sensor
New ECU temp sensor
I am running 7psi at the moment, and when i got o tune the SAFC II i want to run 12psi and no more, less if i can get away with it.
The tunner told me that 160rwKw is basically what is actually posible, i have no idea why, that is only a 40kw increase over stock.
Now basicaly intake and exhaust is a good 10kW, pod 5kW, 5psi boost 40kW, remap, about 10kW so that should be a total gain of about 65kw. Now stock at the RW is about 120-130kW so that should be about 180-190rwKw in total
So what the helll is he on about.
Can people post up their output figures with the mods. I am not too sure if the tuner can be trusted but that is the only one poeple have recomended.
What sourght of power figures should i be looking at, and what do i tell the tuner to do, ie fuel air rations and recomendations to my tune.
HELP PLEASE, i want to get this right, as i am on a budget. Thanks.
SILLY ME. she's a 1995 R33 series 1.5. Opppsa
Edited by WogsRus
1.What car is this for btw? R32 Or R33 Or R34?
2. How much power is the car making now prior to installing SAFC + tuning?
3. What turbo are you running? stock?
4. If its a r33 with the mods you have listed on stock turbo i personally believe you'll be getting between 170-190rwkw as well. If its an r32 then 160rwkw is my guess.
my 2cents
remember auto's dont read aswell on dyno's as manuals do,
i was told by my tuner,he said it reads a little higher down low
(something to do with the torque) and read low up top.
89' rb20det r33 turbo+zorst & SAFC1 automatic = 165rwkw
12psi
    • Howdy friends, So this evening I had a need to remove the rear compressor turbo pipe (long story, but I'm replacing it due to a bolt snapping off in the pipe and managing to then snap an extraction bit in the broken bolt, fun times -_-). The rear bolt is a bit of a bastard and very little room to get good leverage. I was able to get a 12 mm socket onto the bolt head, but none of my ratchets were able to fit, so I put together a "stubby" socket wrench to get it out and it worked surprisingly well 🙂. In the past I've "made" tools by cutting down spanners and bending them with a torch etc, but this 3D printed wrench was way less effort. I'll be keeping this one in my "special tool draw" from now on for sure ^_^b https://www.printables.com/model/868973-half-inch-stubby-socket-wrench
    • It looks even better in Person
    • It's good, but not as good as some people make it out to be on social media. Yes, you can feel the torque come in earlier, yes, it does make the car feel more lively below 4000rpm, and yes, it does feel more responsive, but it's not this 'unicorn' mod.  Everyday driving? Below 100km/h on Australian roads, it's worth it. At 110km in 6th gear mine will sit on about 2860rpm. Doing a Motorkhana or a small circuit? Yes, it's worth it. Doing Texas style speed runs? Prob not. Do you use the gears more? Yes and No. Doing 60/70km on most roads, I'm using the gears just like any other Getrag. 80km and above, you use 5th and 6th more often. Absolutely no issues driving with the 33 A-LSD. Didn't change the front diff, only changed the C&P wheel. Some people say to upgrade to a Quaife etc, but i've had no issue with torque steer or having it wander all over the road. The one thing that no-one really addresses is the issue of the Speedo being out. It's either use a speedo corrector, find a 33 gearbox speed sensor, or use an aftermarket display with GPS speedo.
    • Anyone know or have the timing specs for these cams?   i have messaged JUN for two months with zero response    they are 288in/288ex 11.6 lift
    • That would be a rarity. You can emulate the function of the stalk just by bridging the appropriate pins in the connector. If you can make it function correctly by doing so, then the wiring etc is OK and it is the stalk.
