R33 Stereo Installation Guide
NS2500
  • Replies 130
That's a great guide :D . I will using it for the installation of my new head unit (although I don't have a factory head unit in the car). Where did you order the tray at the bottom from?
They're on the way... I just have to do the install first.
The tray is a current model Pulsar tray from Nissan.
Sorry about the size guys, sometimes I take cable for granted. I'll optimise the page better for dialup users tonight.
-Greg.
Nice guide :D The only suggestion I'd make is instead of using the terminal blocks, I would go to SuperCheap or similar and purchase a Nissan adapter. It plugs into the factory Nissan loom and has flying leads at the other end. No butchering of the factory wiring required! :)
If the speaker guide is as good as the head unit guide I'll use it too. Good job.
I'd love to but it's been about 18 months and I don't keep my packaging for that long :D
Here's what I do know: I bought mine from SuperCheap and it cost me about $5. You can get all kinds of adapters, like Nissan -> Kenwood, Toyota -> Pioneer etc, and also ones like the adapter I bought, which is a female Nissan plug going to flying leads, which you connect to the corresponding flying leads on the back of the plug supplied with your stereo.. If I go near SuperCheap (I live about a minute away) I'll get some more details and let you know.
The part I'm thinking of is an Aerpro AP7550 - Aftermarket Stereo to Nissan Harness. It was listed at $15.50 at SuperCheap, but as TT says, there's a pretty good chance they're not the only ones selling this kind of thing. Perhaps my price estimate was a little off though :D
I used an Aerpro double diversity antenna adaptor which I got from Autobarn, so I guess they stock them as well...
I wish I had of known about this earlier, oh well. :P
Here's the page with the wiring harness AP7550:
http://www.aerpro.com/cgi-bin/list.cgi?list=harnesses2
And the Nissan Diversity Adaptor AP348A:
http://www.aerpro.com/cgi-bin/list.cgi?list=antennas
Thanks heaps for the guide! Will be extremely useful (when I get my Skyline... soon).
I was just wondering, do you NEED to get the "Aerpro double diversity antenna adaptor" in order to get your antenna to work with your new stereo? Thanks.
King,
You don't necessarily -need- the adaptor if you can manage to rig up your own connector, but it's difficult as the factory connector is 2-pin (for the two antennas) combining two wires in to one.
  • 3 months later...
  • 4 weeks later...
    • Hi all, I need to get this HKS SLD attached to my stock ECU because I've now got the German autobahn and faster European circuits to contend with.  The car is a manual 2dr ER34 with an AT ECU and I've realised the AT ECU has two pins for speed sensor signals: Pin 29: Vehicle speed sensor signal (Vehicle speed sensor 2) Pin *58: Output shaft rotation sensor signal (Vehicle speed sensor 1) - *RB25DET A/T model only Before I go butchering this harness, is anyone sure of which pin is the correct one for signal adjustment? The attached document from HKS indicates pin 29 but I found this situation mentioned in the following thread on a different forum (R34 GTT Auto Trans Speed Cut Problem | Zerotohundred) mentioning pin 58 needing to be altered by member zephuros, albeit it seems to be for an RSM-GP and the info appears to be old.  R34_All_Workshop_Manual-pages-2.pdf R34_All_Workshop_Manual-pages-3.pdf R34_All_Workshop_Manual-pages-1.pdf HKS SLD Vehicle Pin out P59-P70 ER34-pages.pdf
    • What is the "compromise" that you think will happen? Are you thinking that something will get damaged? The only things you have to be concerned about with spherical jointed suspension arms are; Arguments with the constabulary wrt their legality (they are likely to be illegal for road use without an engineering certificatation, and that may not be possible to obtain). A lot more NVH transmitted through to the passengers (which is hardly a concern for those with a preference for good handling, anyway). Greatly increased inspection and maintenance requirements (see above points, both).   It is extremely necessary to ask what car you are talking about. Your discussion on strut tops, for example, would be completely wrong for an R chassis, but be correct for an S chassis. R32s have specific problems that R33/4 do not have. Etc. I have hardened rubber bushes on upper rear control arms and traction rods. Adjustable length so as to be able to set both camber and bump steer. You cannot contemplate doing just the control arms and not the traction arms. And whatever bushing you have in one you should have in the other so that they have similar characteristics. Otherwise you can get increased oddness of behaviour as one bushing flexes and the other doesn't, changing the alignment between them. I have stock lower rear arms with urethane bushes. I may make changes here, these are are driven by the R32's geometry problems, so I won't discuss them here unless it proves necessary. I have spherical joints in the front caster rods. I have experienced absolutely no negatives and only positives from doing so. They are massively better than any other option. I have sphericals in the FUCAs, but this is driven largely by the (again) R32 specific problems with the motion of those arms. I just have to deal with the increased maintenance required. Given how much better the front end behaves with the sphericals in there.....I'd probably be tempted to go away from my preference (which is not to have sphericals on a road car, for 2 of the 3 reasons in the bulleted list above), just to gain those improvements. And so my preference for not using sphericals (in general) on a road car should be obvious. I use them judiciously, though, as required to solve particular problems.
