Rb26 Stagea Dyno Videos :)
CruiseLiner
well finally after a huge long rebuild time of 12 months its finally got a go on the dyno, and it went alot better than expected on the low boost setting so im lovin it :O even blowing flames on over run which looks maddd :(
boost is on a low 13psi and rpm limit is 9000rpm. no power figures are gonna be published on here due to the amount of people in the non stagea sections wanting to slag on others results so i think ill keep it quite.
ive got a couple of power runs
turbo and manifold glowing as it boosts up
thats all i can do at the moment as i gotta goto work, ill post the others of the flames, etc after work.
stay tuned :(
Brad :wave:
Brad, simply out of a matter of interest (yes, Im interested in your total buildup, LOL, and Im NOT a slanger, far from it - backslaps all round, hear hear) - would love to know what the 2.7 pulled on low boost. :wave:
Let me tell you I was impressed and I don't impress easily.
:wave: cheers :O
Edited by Sydneykid
Guest Mashrock
Nice! good to see you have it up and going! hopefully no more little gremlins!
would love to know the figure also :dry:
Nice to see it all up and running!
Sounds very nice!
However (this is a good thing haha) i thought you were gonna go external gate or did you decide that it would be a little less offensive to plumb it back?
Either way can't wait to see Final Final (figures) result!
Keep up the good work!
Edited by MADGT4
Brad you want to swap my engine with yours? :)
what kind of parts did you used? and how much just for parts and how long did you take to rebuild this engine?
Sounds awesome Brad. Nice to see it doin what it does best! Whilst I understand your motivation in not revealing the figures for the other Skyline owners, its driving us fellow Stagea owners nuts!! :)
