Workshop & Autoparts Listing
Cubes
I am compiling a list of workshops in Adelaide to help us all receive the best possible price and quality of service.
Please ring them all, get quotes, ask your friends and make an informed decision for who you should choose to work on your pride and joy.
If you believe a workshop listed is not worthy due to bad customer service please PM me and explain the situation, I will then decide to pull it down or not.
This thread is locked, please PM me to add a workshop to the list.
Import Performance Tuning Workshops
  • WILLALL RACING
    Cnr Wilkins Rd & Browning St
    GILLMAN
    PH: 08 8341 0400
    AM Performance
    Andrew - 0401 865 373
  • Boost Worx, 8299-0621
    U8 8-12 William Street, Cavan
    PH: 8260 5566
http://www.boostworx.com.au
[email protected]
Southern HiTech Dyno Tune
8 Emanuel Crt, Melrose Park SA 5039
(08) 8277 4400
Fax (08) 8277 4422
[email protected]
BDT Performance, 8370-3450
2 Stirling Road, Blackwood
http://www.bdtperformance.com.au
Dyno Tuning Available
Graham West Workshop, 8277-5688
668 Marion Road, Park Holme
Mildren Race Engineering, 8443-8299
19 Phillips Street, Thebarton
http://www.mildrens.com.au
Morpowa Performance Specialists, 8264-2077
14 Famechon Cresent, Modbury North
http://www.morpowa.com.au
SA Performance and Service Centre
Unit 2/19-21 Thomas St
Cavan, 5094
Ph 8262 9785
email: [email protected]
  • Horse Power Innovations
    PH: 0408836384
    Fours N More Automotive
    5 Langford Ct, Pooraka
    (08) 82602011
    General mechanics work, engine conversions, dyno tuning etc
    Exhaust Specialists
    • Everlast Mufflers, 8396-3255
      31 Golden Grove Road, Ridgehaven
http://www.everlastmufflers.com.au
All your exhaust needs
Exhaust Technology
253 Goodwood Rd, Kings Park SA 5034
PH: 8272 7500
Paint & Body
Pro Finish Custom Paint
2/20 Famechon Cr, Modbury North
Joe - 0411234992
All Type Crash
1395 Main North Road, Para Hills West
PH: 8281 0130
Edwardstown Custom Body Repairs
21 Bennet Ave, Melrose Park
PH: 8277 8887‎
Alarm & Audio Installation
GT Autosound - www.gtautosound.com
34A Sunbeam Road, Glynde
83655455
Auto Perfection - www.autoperfection.com.au
281 Main North Road, Enfield
83426644
Marvey Tech - www.marveytech.com
Unit 2/14 Famechon Crescent, Modbury North
83965550 / 0405702292
Ministry of Bass - www.ministryofbass.com.au
1205 South Road, St Marys
82768668
  • Misc
    • Adelaide Belt & Hose Distributors, 8371-1699
      29 Croydon Road, Keswick
http://www.beltandhose.com.au
For all your hose needs
Captain Thread
MOB : 0407 077 414
All Clutch and Brake Service, 8277-8122
3 Pinn Street, St Mary's
http://www.allclutchandbrake.com.au
Aftermarket Clutch master/slave cylinders, brake master and calliper overhauls
Silicon Intake Systems
Online
http://www.siliconeintakes.com/
Well priced silicon and tbolt clamps in any colour size or shape you want
Fitch The Rubber Man, 8346-5193
2 George St, Hindmarsh
Top quality hoses but a tinny little bit more expensive. Definitely worth it!
TXS Silicon, (02) 9987-0395
Online or Phone Order
http://www.txs.com.au
Very well Priced Silicon Hoses & Accessories not to mention great variety
Cliffdales Pty Ltd
97 Mullers Rd.
Hampstead Gardens
G R H Supplies, 8243 0944 (clamps including t-bolts/worms and tools)
167-169 South Terrace, Wingfield
C+A Developements
Hydraulic Engineering
Race car fabrication
Ph. 08 8264 0844
fax. 08 8395 29
  • Here is a list of vehicles they can do
http://raws.dotars.g...ALE%20PTY%20LTD
  • Sleeka Spares
    (08) 83596446
http://www.sleekaspares.com.au/
Performance Parts & Accessories
Helps Metalwork
4/48 Morrow Rd, Lonsdale
0415153163
http://www.helpsmetalwork.com/
Automotive Engineering & Fabrication
  • 4 years later...
  • 10 months later...
Guest
    • Any recommendations on a decent replacement manifold that doesnt break the bank or require additional mods for the stock turbo setup? I figure if I'm going to pull the manifold off anyway to fix the studs might as well replace it.
    • So I checked the turbo out today. Very minimum play at all just enough for the oil to take up when it's running. I did find an exhaust leak at the manifold. 1 stud all the way in the front is missing and the one all the way in the back is broken off. Front has visible signs of an exhaust leak. I'll fix that soon but that's not my problem still.  I also found that the nipple coming off the turbo had the hose capped off and a hose ran from the j-pipe by the bov going to the wastegate. I removed that hose and capped that nipple and put the turbo nipple hose back on the wastegate.  There was a ton of oil residue all through the charge side of the intercooler piping going to the throttle bodg. I'm thinking that's from the pcv. Doesn't seem to be coming from the turbo that was all clean on the pipes side.  Haven't had a chance to check fuel pressure yet, haven't had time been having to pull a lot of doubles at work. I did pick up some carb cleaner to clean the iacv but wanted to make sure I had a fresh gasket in case the old one rips when I pull it off.  I'm waiting on a MAF that was supposed to be here today but delayed to Monday. Have a double Monday and Friday and work all of next weekend so going to try to find some time in the middle of the week to try that out. Did about a 10m trip around the block today and towards the end the issues were coming back. Fingers crossed on this MAF but if not just going to throw a fuel pressure gauge in and see where I'm at.  Did notice today that I can definitely hear the injectors pulsing. Very audible clicking coming from them. Assuming that's normal? Should also mean CAS is functioning somewhat properly. After it warmed up when I started it the intermittent misfires came in again. Did start doing that before it was fully warmed up.
