Mysterious Pfc Missfire In An R32 Gtr
It's good, but not as good as some people make it out to be on social media. Yes, you can feel the torque come in earlier, yes, it does make the car feel more lively below 4000rpm, and yes, it does feel more responsive, but it's not this 'unicorn' mod. Everyday driving? Below 100km/h on Australian roads, it's worth it. At 110km in 6th gear mine will sit on about 2860rpm. Doing a Motorkhana or a small circuit? Yes, it's worth it. Doing Texas style speed runs? Prob not. Do you use the gears more? Yes and No. Doing 60/70km on most roads, I'm using the gears just like any other Getrag. 80km and above, you use 5th and 6th more often. Absolutely no issues driving with the 33 A-LSD. Didn't change the front diff, only changed the C&P wheel. Some people say to upgrade to a Quaife etc, but i've had no issue with torque steer or having it wander all over the road. The one thing that no-one really addresses is the issue of the Speedo being out. It's either use a speedo corrector, find a 33 gearbox speed sensor, or use an aftermarket display with GPS speedo.
