I Learnt How To Drag Race On The Weekend.
Abo Bob
I've been quite frustrated by my bad drag times so far in my car. Even when I had the stock turbo I seemed to be way behind the pack. I've been to a few wednesday night street meets and in my unprofessional opinion they suck for everything bar socialising. Too many cars, not enough runs, too many rotaries dropping oil all over the track.
I figured what I needed was a private track day with lots of runs to practice so I went to the V8owners track day on sunday (I was invited by the organisers who know me) and I practiced.
First run 13.4
Second run 13.3
Third run 13.2
Fourth run 20.4
Fifth run 13.08
Sixth 13.4
Seventh 13.2
Eighth 12.9!!!!
At this point I rang 2rismo who gave me a little tip and told me I had a 12.8 in it. I didn't believe him and consequently stuffed the next 3 runs up.
Next I started paying attention and I got about 4 12.8's and then 3 12.7's each time dropping a few hundredths on my ET. My MPH on my final pb of 12.764 was about 105.xx but interestingly I got 107.95 and 107.88 on other runs so maybe I've got a 12.6 in it?
I've got steel wires sticking out my tyres now and a grin from ear to ear. I made lots of smoke and put some of the V8's to shame, although one guy made my 190km/h burnout over the start line look lame by burying me in his tyre smoke.
Thanks to 2rismo for the tips.
:) well done mate. it certainly is very addictive. i entered for the first time last wednesday night and i had a ball. hope you stick with it.
Big improvement there mate, I think i'll be happy if I can eventually get my R34 to run 12s. Would you mind posting up what you've done to your car and the power you're producing? I figure you've got 240rwkw+?
Great work, mate. You'll often find that your trap speed will be up as a direct result of a buggered launch. i.e. Your best ET and TS will rarely be on the same run.
In saying that, a 12.6 isn't out of the question with some new tyres. Those Nittos have sure seen some serious work in their lifetime and have almost certainly gone off.
Very good effort and a perfect example of why a private track hire is such a good thing to be part of.
Adrian
P.S. I hope you didn't fall over in the car-park afterwards....
255rwkw
auto
gcg highflow
tomei 260 degree poncams
nismo 480cc injectors
powerplay rom tune
The ground looked kind of hard so I thought I'd just say I fell over and sue rather than actually doing it. Got a few choice dirty looks.
It was an auto only tip. Basically I had one foot on the brake and the other stalling it up but the tip was to use the handbrake as well so as to hold it stronger. Got about 150 extra rpm which got me about 5 psi boost off the line.
I also utilised previous 2rismo tips in doing 3rd gear burnouts. Tyres were nice and warmed up although a couple of times when the burnout wasn't quite as big I found out how far down the track the prep went. Top of 2nd gear wheel spins anyone? It doesn't even do that on the street with my shitty Falkans.
i know everyone does a burnout when you come up to stage but it's useless with street tyres. save your rubber and spin the tyres only enough to get the water off them. unless you want to show off which is fine with the crowd :D
George, I nearly disagreed with you for a second until you said...
"unless you want to show off which is fine with the crowd :D"
    • Hi SAU community  Wondering what my 93 Very RARE TH1 Blue R32 GTR VSpec is worth these days?? Build is fairly dated now All Mods are Compliance Approved  Runs RB26 done only 10000ks Greddy T88 done only 8000ks HKS Cam 1000cc Injectors Full Titanium Exhaust Nismo Intercooler Nismo Oil Cooler HKS Oil sump Tein Super Street Coils Cusco Sway Bars RAYS TE37 19x10.5 DYNO street tune makes around 700hp on 98octane
    • It does sound like a fuse considering the indicators work..I’ll triple check when I’m free and report back.    thanks for the reply.
    • no, the car was a manual 5 speed from the factory and still is.
    • While going through data logs late last week, I spotted a small issue with my WMI. My WMI starts to progressively inject at 11psi of boost. I'm using a 25psi cut in pressure switch on my WMI as an added safety and if the curve is linear, I should hit that 25psi on my WMI system around 13-14psi of boost.  As per my data logs, my WMI pressure switch only activates around 19psi of boost. This is causing my non WMI 4D map to trim for WMI. I'm presuming this is caused by the mechanical switch response time, injection curve not being linear or both.  I ordered a 2-10psi adjustable cut in pressure switch which should correct this. If this doesn't resolve it before my dyno appointment on Friday, I'll just remove the pressure switch temporarily and more than likely replace it with a pressure transmitter afterwards.    BTW Speedtek has yet to refund me.
    • Yep PETG (Polyethylene terephthalate glycol), my 'go to' plastic, printed to precisely how long I wanted 🙂, about a finger length ha ha. I would usually grind up something but since I've got the printer I thought I might give it a try and it worked beautifully ^_^b So with regards to torque, there's a little bit of science behind the orientation of the print, fill density, fill pattern and number of external perimeters which can increase the strength dramatically, but you still need to work within the constraints of the material and the orientation of the model for sure. I certainly wouldn't be making a breaker bar out of plastic, but this little bugger is very strong for it's size that's for sure.
