R32: GTR Door Trim Removal
mazgtr
This is very simple and basic for most, but not me. So i thought id share my experience at doing this myself tonight, so other non-mechanically minded people can have a go..
For this tutorial, front of the door means closest to the engine when doors closed. Back of door is closest to the boot when door is closed.
Drivers Side.
2 screws at the front of the door midway up. Should be covered with little plastic circular covers, these pop off with a bit of force.
3 screws running along the bottom edge of the door from front to back.
1 screw in the little door handle cavity, also should be covered with little plastic tab.
Now use a small flat head screw driver and slowly/gentley lever the power window black control unit up and out of its spot in the door.
Once free, unplug the 2 plugs connected to it, and place somewhere safe.
Now use that same small flat head screw driver and slowly/gentley lever the door catch release trim from around it, it then slides off and away from the actual door release handle/tab.
Now go to the bottom back corner of the door and slowly apply force to the door trim until it pops away from the door. There are 4-5 little plastic pop clips that hold it in, all no higher up than half the door height.
Once you feel the trim is loose and has started to come welll clear of the door, use an upward motion to lift the top of the door trim up and out of the door sill (inbetween the glass and door).
It should lift up and away. Voila!!!
Passenger side.
Now just below the door handle (where the little black window switch is) theres a little tab hidden flush into the door trim. This needs to be popped out, to reveal another screw. This one is a bit of a bitch and is easy to drop behind the trim once you've undone it!!!!
Now use that same small flat head screw driver and slowly gentley level the door catch realease trim from around it, it then slides off and away from the actual door realease handle/tab.
Now go to the bottom back corner of the door and slowly apply force to the door trim until it pops away from the door. There are 4-5 little plastic pop clips that hold it in all now high up than half the door height.
Be carefull not to pull the door away straight away, as you need to reach in and down, to unplug the power window cable, its just a plastic white plug.
Done!!!
For both door trims i found the lever door release to be quite difficult to avoid fouling on while trying to pull the trim away.
Putting it back on.
Try and line it up so you can see the door release handle through the hole.
Start from the top, and try and slide the top of the trim down and into the cavity between the glass and the actual door.
Once it slides down and in, you might have to adjust it slightly front to rear or vice versa to get it lined up.
Once again the door release handle is the bugger to get lined up and through the little hole for it.
Once it all lines up , i quickly got 1 screw in so it didnt fall back off.
Try and push the plastic clips back into their spots, and then start doing up screws!!!
*Dont forget to replug in the passenger side power window plug!!!
*Dont forget to plug both plugs back into the drivers side power window unit!!!!
Also, the screw that hides under the little tab on the passenger side is a little bastard to get back in, make sure you've got a magnetised screw driver, otherwise you risk it dropping back in behind the trim, to rattle and annoy you till you take the door trim off again!!!
Cheers Matthew
  • 1 year later...
just adding to this...
on my R32 gts there was another screw on the passenger side door, it was hiding behind the power window switch. that black switch just pops out and there you see the screw in question
had me stumped for a few seconds
    • Vanos solenoid problems and basically all sensors die an early death
    • Yep, back in the day when you could pick up a Stagea RB25 NEO for $1,500 it was worth it. These days... just chuck your V8 or B58 in.
    • from my limited BMW experience: - they burn oil WTF (B48 FTW 170kW engine) - dump oil every 5,000km and you'll be ok.. until it drops a bearing and rebuild time. replace engine with B58
    • They absolutely are, but the thing is, if you're only exposed to these circuits for a while, what I normally think is good driving suddenly isn't so much. I was a pussy at the Nurburgring (GP) entering corners at 180kph - the difference in the balance of the car suddenly becomes so much more pronounced and I'm still a bit regarded at left-foot braking - something I now practice on my commute. So the (dream) plan with the E90 is to make it a 325i Cup car. Whether I get there or not is another matter. In my mind the simplicity of having the NA variant and cost made it a bit more appealing. Plus, like mentioned above, I'm actually too much of a pussy for big power. Of course I f**ked up by not researching enough on the N53 vs N52, the latter being more robust without the DI system.  Suspension-wise on the BMW, and I've been reading the technical requirements for the 325i cup, basically everything except struts has to be standard - bushes are free. I figure you get about 5-10mm adjustment with the rear camber bolts which should translate to 0.5- 1.5 degrees of adjustment. So with coilovers, lowered at 30/40mm I expect I can dial out some of the camber from a drop and attain -1.5 to -2. If necessary, I could get the same effect as the M3 arms with some offset bushes. There is a limitation on ARB width to qualify, although I absolutely want to get either M3 ARBs (can't say sway incase I upset GTSBoy) or the H&R ones - both of these are the cheapest options. Like mentioned, M3 arms are on the way and I should have them fitted within the next week. How are the BC Racing coilovers btw? Reviews are mixed but I think for me they would be fine; a friend of mine uses them on his R34 for track driving and has nothing bad to say. I'm looking at these or the ST coilovers (German brand, new to me) as prescriped the in Cup spec sheet. They're both similarly priced and offer camber adjustment. It's fine but it really upsets my OCD. I've got a couple of options for dialing out the rear camber and keeping my ill-fitting wheels: raise the rear a little bit, say 5mm, that should permit -2.5 camber or drop the front to restore that slight bias of more negative camber up front (not optimal with the roads here). The next alignment won't be until at least next year and I really need to rebuild the rear subframe. For now, I'm not using it at all on the streets except occasional blasts through the German countryside. I was covering about 10k kms p/year in Japan, I expect this to now be about 3-4k. You could say buy better sized wheels, and yes, I should have. But the wheels came from the Z and price of good wheels is just insane now. Again, a couple of options: get a new set (I want 17" RPF1s) or buy two used 9.5J TEs, both are about the same price excluding shipping.
