Updates On The R33
Mr-Toy33
Just a few pics of the update on the skyline.
Not much is yet to be released on whats been done as its only half way through the list of things to be done to it.
Before this weekends work was done. -
post-22617-1142209380.jpg post-22617-1142209431.jpg post-22617-1142209456.jpg
The after shots of what was done this weekend.
post-22617-1142209495.jpg post-22617-1142209515.jpg post-22617-1142209538.jpg
All work was done by Elite Racing (Dan - 3lit3 32). :)
The car goes in for tunning this week.
  • Replies 95
So what did you get done by Dan??????
fmic, front bar, front and rear struts, fuel pump, powerfc, 5000k service, couple of extra things as well.
gettin the new clutch put in tonight/tomorrow day by dan and will get the car back tomorrow night.
Multi-plate, 5-puck button, unsprung centre... that clutch is going to be a bitch in traffic lol! The pucks are pretty big though so might not be too bad, but geez dude, overkill!
But yeah, with a new set of wheels it'll be looking sweet :rolleyes:
Guest
    • @Butters I can't tell you why but the bigger HKS step 2 cams improved low and mid end immensely. Turbos started spooling about 1k RPM less than before and the idle/vacuum was rock solid, it was an absolute thrill to drive, 3rd gear pulls hit 180kmh where previously only managed 160. Conversely, the milder poncoms in there now have a funky idle making it harder to get off the line, drives poorly in lower revs, laggy and makes less power/torque throughout. Feels better after I swapped the EBC but unless I put it on the Dyno again, I can't say how much better.
    • Hi Sydney kid   do you still selling spring and blistein shocks for Nissan 260rs? Air any suspension upgrades? Please advice     yudy
    • Cams are not needed at this power level, they will create lag. The cam gears are a good idea though.
    • @Murray_Calavera yeah, I guessed as much, cooler temps, more boost, less knock, more timing, hello power. Unfortunately not quite within reach ATM, could upgrade my whole fuel system to support but still wouldn't have E85 to run it 😂  Anyway, I changed cams again, 260/260 poncam B and everything else the same except an EBC upgrade. Now I must say I was quite disappointed with the result as it was like running stock cams (didn't try to dial them in as they're supposed to be optimum already) but after awhile I suspected my new EBC was underperforming not to mention difficult to use. I recently swapped back my old EBC and it drives much better now, boost comes on sooner, more stable, no spikes etc, feels all quicker and faster than with stock cams. Planning to fiddle with the cam gears and see what happens but maybe skip the Dyno as I intend to revert to the HKS cams cos they really made the car come alive; low and mid end was unbelievable and it just wanted to rev to the moon, finally knew what people were raving about, RB26 really loves revs. Anyway, Dyno 03 is quite disappointing, in Dyno 02 although peak power was less and trailed off at the top, the low and mid end improvement more than made up for it.
    • @Darrel It's so tempting to say e85 is borderline magic. It cools the intake charge, so if you're flirting with the edge of the turbos compressor map it helps dramatically cool down the hot air the turbos are pumping. It is very resistant to detonation so you can crank the timing, I don't really want to say you won't be knock limited anymore.... but you probably wont be knock limited anymore lol. I wouldn't be surprised if you made 20% more power swapping to e85 (provided you have the fuel system to support them, bigger injectors maybe bigger pump etc).
