Power Fc In A Stagea
EGA41T
i have tried searching but couldnt find too much on this.
i was thinking of putting an r34 gtt power fc into my stagea (series 2 rs four s manual) will this work, and how will it affect things like climate control and AWD etc?
  • Replies 52
I've also done a search, and found nothing relevant on hardwiring the ATESSA system.
Does anyone know what's involved, and is it a simple or a major process?
I'm really keen to do this, as I'd like to find that balance between better fuel economy, more power, more responce, etc., and PowerFC is amongst the best solutions (closed loop and plug-and-play are major factors).
Its a simple process. Think along the lines of, stagea ecu has seperate outputs on the harness for the attessa requriments, where the GTST doesnt. Therefore, its just 2 wires coming out from the single pin.
Read from about post 8.
By the way, goldzilla....you even replied in that thread :D
http://www.skylinesaustralia.com/forums/in...c=92908&hl=GTS4
Mercury Motorsport said that the PFC they used didnt need the engine harness to be cut/modified at all, BUT, a guy from Japan that did Goldzillas car said the GTT plug doesnt fit, ALSO, the R34 GTT neo engine has infinatly variable VVT where the R33 engine has it only on/off. SO, not sure what MM did about that, but they wouldnt share...its a secret
By the way, goldzilla....you even replied in that thread :yes:
Yeah I did too, Alex! But that thread is so old I'd forgotten all about it and don't remember checking it for replies.
Hmm, the saving continues... Concentrating on the stereo for now (at least getting some replacement speakers, anyway). I can handle (and am quite enjoying) the power the car already has, and would like to get suspension and wheels first, once the stereo is at least partially sorted...
EDIT: Alex, did you end up taking your car to the PFC distributor to see what works/doesn't work before making your PFC purchase?
AlexCim, i see you purchased a power fc for your stagea, when will you be doing the manual conversion, and putting in the power fc?
...keep us updated...cheers EGA41T
    • my current daily - BiTurbo Diesel SQ5 8R with a remap and some light cosmetic mods. Which is sitting in front of my old daily that hasn’t been driven in 7 years now, home to numerous redbacks no doubt. MK4 Golf GTI with a boser hood extension, air ride airbag suspension, factory RHD Xenon’s from the Japanese R32 and stubby electric mirrors (also from Japan) sitting on custom made 18x10” Work Meisters for the golf’s bolt pattern and offset. one day I’ll revive it as a project, pull the engine out, put some forged bits in, chuck a big turbo on it and tune it to somewhere around 250kw and call it a barn find to make millions off YouTube views. Till then, it is a good breeding home for redbacks and the boot is good for storing my Christmas tree for 11 months of the year.
    • Thanks for jumping in guys, suggested @Sbluatx post here for help. Was hoping one of the guys with a RWD stages could confirm if the tank was the same as the AWD one
    • I got another MAF and installed it. Idle misfire was still present. Finally got the tank low enough to refuel and did so. Did a short drive to warm the car up and no issues, pretty short drive. Going to attempt soon to take a longer drive to see. I don't think the MAF fixed it if anything, definitely thinking it was fuel related. As soon as I put fresh fuel in the car felt so much better. But, still need a longer test drive to verify. I'll report back once done.  I'm definitely going to be getting monitoring and tuning parts soon as my next upgrade (decided on the link after talking with my tuner), just been real tight with just purchasing the car and sudden onset of issues. I've also ordered a new exhaust stud kit and gasket to fix that obvious problem. Once it's back up to par I'll start with the goodies
    • Meant it’s 2WD. And my tank is cracked.
