Hicas Locking Option?
nanuGTR
Hey everyone!
OK i want to remove my Hicas system on my BNR32 and all i want to know is is it ok to connect (rubber hose) the 2 power steering lines that come to the HICAS unit?
Is it ok to do this or will i see problems?? I will attact a picture so you guys know exactly what im talking about.
thanks
I ordred hicas lock from japan already. At the moment i cant take out the whole hicas system, i just wanna put on the Hicas lock bar and loop the lines if its alright, im not sure looping the lines is a good idea or not. If there is something else easier can someone edit the pic and post another idea please.
Really need your help
thanks
thanks
Which lock kit did you get? If it was the Tomei one you disconnect the solenoid valve which (I surmise) stops fluid being pumped tot he rear steering rack in any case.
Hey everyone!
thanks
By looping the oil flow at the rear, you will require high pressure fittings as the solenoids ensure sufficient pressure to move ther rack is availabe at the rear.
A better (easier and cheaper) solution is to do the looping at the front. Straight out of the power steering pump (rear stage) into the power steering cooler and back into the reservoir. I will mark up the schematic tonight, but I can't see the power stering cooler mentioned, maybe becaase it's just a loop of aluminium pipe they don't put it on the schematic.
:D cheers :D
I have marked up the HICAS schematic;
The Blue dot is the power steering cooler
The Red dots should be joined together, this bypasses the HICAS solenoids completely.
No cutting of pipes required, around those locations you will find the steel pipework has clamped rubber hose sections, just remove the (short) hoses and substitute them with the new (longer) piece of joining hose. If you are not removing the rest of the HICAs system, then block off the (no longer used) hoses to keep the crap out. There will be power steeing fluid trapped in the hoses, so make sure the capping is liquid proof.
:D cheeers :D
Edited by Sydneykid
  • Like 1
:( cheeers :)
Have a look at page CH-372 of the R32 GT-R manual. It shows the cooling loop forward of the solenoid valve. As a aside since having my HICAS locked out with the Tomei kit the power steering fluid doesn't get as hot as it once did. This may just be from not being pushed through small orifices in the valves and/or steering rack but is probably also due to the cooler.
;) cheeers :O
Another question where the blue dot is located, is it already going through the cooler or we have to make it go through the cooler?
*** Never mind i got it all figured out!! Thanks for you help guys!
Edited by nanuGTR
  • 2 months later...
Alright so i have finally removed my hicas about a month ago. I herd that you can unplug the HICAS ecu and the light on the cluster will stay off and the steering gets a little heavier, is that bad for the power steering pump? Is it better the leave the HICAS ecu plugg IN or OUT?
Plug it in to have your servo-tronic assistance (steering light at low speeds and gets heavier as speed increases) and take the bulb out of the cluster.
So your saying leave the hicas ecu plugged in and pull out the hicas bulb out of the cluster?
  • 4 months later...
This may seem like a silly question, but is this the same as the 32gtst? Cause it seems my hicas solenoid thingy has more pipes coming and going from it? I can definately locate the rear hicas lines, and the line coming from the cooling pipe, but there seems to be 2+ pipes going into the solenoid? Anybody have any thoughts on this? Thanks.
    • Seems bang on to me , g30-900 will make 900 crank on e85(on paper). Deduct ~25% for 98 and you are at 675 crank. Run that to the wheels and fact you are only running 26psi you end up about your number.  People forget how magic E85 is now that just about everyone is running it.   "Back in the day" you had to be north of 30psi on a 850+hp turbo to get 600 at the wheels on 98.
    • I can believe it if you're getting air into the pickup. Cavitation is tremendously destructive for pumps.
    • I think the pic in the first post is another car, and post 7 is OP's car with standard arms and swaybar swaybar swaybar. I can't tell what brand the silver coilovers are, and even if I could I don't know whether the spring rate is OK, if you can find a brand on the shocks and numbers on the springs that might help. Also, if you can measure the ride height from centre of your wheel to the guard that will help with advice too as handling suffers if ride height is too low
    • sadly, pics no work. that car must have spent a lot of time in a cryo bubble
    • In the first photo you posted, the colour of the control arms are the signature colour for Ikeya. Same for the swaybar, signature colour for Whiteline.  I like Hardrace, they also do hardened rubber bushes if your car is mainly a street car.  I like GKTech as well, but they use a lot of rose joints in their stuff so might not be the best choice for everyone.  The system might have been good back in its day, but it's a prehistoric system now. I suspect that most people have removed the HICAS as they want the car to do what they want to do, not what the car wants to do. From what I also understand, it isn't consistent in it's behaviour on track so it's hard to trust the car/know where its absolute limits are for track use.  Having said that, I think the HICAS eliminator kit was the first thing I installed when I bought my car. I don't personally have any experience with the HICAS system on a race track.
