My New Drifter, A Work In Progress ;)
Simon-S14
tad bored. chucking some pics up of the cefiro im getting, Started off yellow and purple from japan, now its being painted (should be ready by the end of the week/early next week) will be all GTR metallic Purple with a new URAS kit on it.
might look ok in the pics but the body was quite rough, typical japanese style the rear gaurds were flared with plyers. so i had it all smoothed out :)
The car currently has:
Kei office coilovers
2 way
adjustable castor rods and other shit
GTR cooler
Profec EBC
Nardi 330mm wheel
other stuff that i cant be bothered mentioning.
and what it looks like atm :blink: its in the paint shop getting painted and finished
PLANS:
Drift that bitch :)
upgrade turbo
getting some new rims soon too, wanna piss off the 15X8's
so yeah, give me a week and i'll have some updated pics ;)
Edited by simon-ae86
  • Replies 285
Posted Images
lol I was gonna comment on the hobo leaning against the car, but then I didn't wanna step on any toes :blink:
How coe you're getting rid of the kit currently on it... I reckon it looks quite nice. Every drift superstar and his goldfish has the Uras kit now <_<
    • What is the "compromise" that you think will happen? Are you thinking that something will get damaged? The only things you have to be concerned about with spherical jointed suspension arms are; Arguments with the constabulary wrt their legality (they are likely to be illegal for road use without an engineering certificatation, and that may not be possible to obtain). A lot more NVH transmitted through to the passengers (which is hardly a concern for those with a preference for good handling, anyway). Greatly increased inspection and maintenance requirements (see above points, both).   It is extremely necessary to ask what car you are talking about. Your discussion on strut tops, for example, would be completely wrong for an R chassis, but be correct for an S chassis. R32s have specific problems that R33/4 do not have. Etc. I have hardened rubber bushes on upper rear control arms and traction rods. Adjustable length so as to be able to set both camber and bump steer. You cannot contemplate doing just the control arms and not the traction arms. And whatever bushing you have in one you should have in the other so that they have similar characteristics. Otherwise you can get increased oddness of behaviour as one bushing flexes and the other doesn't, changing the alignment between them. I have stock lower rear arms with urethane bushes. I may make changes here, these are are driven by the R32's geometry problems, so I won't discuss them here unless it proves necessary. I have spherical joints in the front caster rods. I have experienced absolutely no negatives and only positives from doing so. They are massively better than any other option. I have sphericals in the FUCAs, but this is driven largely by the (again) R32 specific problems with the motion of those arms. I just have to deal with the increased maintenance required. Given how much better the front end behaves with the sphericals in there.....I'd probably be tempted to go away from my preference (which is not to have sphericals on a road car, for 2 of the 3 reasons in the bulleted list above), just to gain those improvements. And so my preference for not using sphericals (in general) on a road car should be obvious. I use them judiciously, though, as required to solve particular problems.
