Mv Automatics Shift Kit
AlexCim
Works a treat!
Chirps 1->2 shifts on smooth concrete.
Much tighter gear changes. Hardly noticable slight clunks when taking it easy. Shifts are almost instant. Will keep you all posted how the shifts work when I take it to the strip, but definatly a worthwhile upgrade for the automatic transmission.
I did it at home on jack stands, pisses fluid all over the place and there are so many damn bolts holding in the valve body.
Works a treat!
Pictures?
:laugh: cheers :D
Mmmmmmm can you tell me how much one of these kits are, how quickly does it change? Standard takes about 3 secs doesnt it? PM me if you dont want to post it on here. I have auto R34 and would be interested in this upgrade one day??
Got a few videos, some are quite shakey but thats coz of you SK and you kit, and a few are shakey on gear changes....thanks MV :)
Some are WOT, some are normal driving. Obviously the revving in the background will tell you what is what :ninja:
http://www.youtube.com/watch?v=IEBcaneDUZg
No offence to the guys with Skylines posting up in this thread, but I made the thread in the Stagea section for two particular reasons. We have heavy cars and we have 4wd cars. For this reason, I wouldnt compare the performance of a shift kit on a skyline to one on a Stagea.. sorry if that sounds rude but you understand I'm sure.
Comparing the shifts to the stock one is not possible. The stock shifts are just so damn slow, mine used to rev freely for about 1-2 seconds before it grabbed 2nd. Now as you can see in the videos its almost instant. I HIGHLY reccomend the upgrade to anyone with a Stagea.
The chirpies are coming from the front wheels too, not the rear.
Cost was $440 delivered including a service kit (new sump gasket and filter). The VB was 350, shipping 30, service kit 30 and GST on top (Yes, shifty bugger qouting GST free)......definatly worth it though. Honestly.
As far as the install, I will do a write up next week for everyone, the instructions that Mike gave were borderline, but I managed to guess it through :laugh:
I also find the auto goes through gears a HEAP more. Its always going between 3rd and fourth now, and its really quick too. I find it locks the converter up more easily now too. I can get lock up at 60kph and push just a slight bit of boost (around 0psi-1psi). Kick downs improved a lot and the throttle response from the gearbox has improved greatly too. I plant my foot, off i go. No more, plant, slip, slip, slip, kinda grab, go.
The job took me 4h, that was ciggie breaks, scratching my head breaks, waiting for my mate to come around mid way through breaks etc.
I could now do it in about 2-2.5h flat out. Maybe even less. DEFINATLY less with a hoist :woot:
Nice effort Alex. Loving the S1.5 youve got there mate.
Yeah my mech mate Ryan who did my turbo last week has done a few MV shift kits, like you mentioned the fluids goes everywhere when opening it up for the first time - hope you didnt catch tooo much of it in ya hair!
I was going to dismiss the MV valve body upgrade and not be bothered, but this thread may have changed my thoughts.
Meh, oil cooler and filter relocation kit is next job on the cards, then perhaps the shift kit.
edit: wow - no "flare" of the rpm when WOT. nice.
I was one of the benchwarmers watching alex fitting the kit. I have never seen so many f**king bolts holding together something, EVER!! The Nissans autos are vastly different from the Toyotas!!
Goes very well with the shift kit, very positive shift.
Alex do a ECU reset when its a bit cooler then take it for a boot! Itll chirp even harder!
I've also got the MV automatics shift kit installed in my s2 stagea so it also has tiptronic, which is greatly improved.
Being in SA I actually got it installed AT MV automatics. Cost me $440 and that includes a transmission service - which normally costs around $150 for a quality service. So for the money it is very good value.
It still drives very very smooth if you want to, or will slam into gear if you push it hard.
The difference from stock is pretty easy to imagine. When you go to kick back a gear you put your foot down to the floor. Then there is a short delay while the gearbox ecu works out what gear you want, and then bang, you're instantly in the gear. I'd guess that the delay is about 1/2 a second or less.
Its not the same as a manual by any means but sure is a lot better than the stock auto. The main thing is that its not at all rough and you basically only feel a clunk if you change gears at high revs...
As far as how long the box will last, I was told that this upgrade actually strengthens the gearbox... :woot:
no chirpies for me though... :(
Edited by pixel8r
would you need one of these in a tiptronic? my guess is yes?
it makes the gearchanges much quicker and snappier. :)
and when just cruising around I can slightly feel the 1st to 2nd gearchange but the later gearchanges are smooth enough to be unnoticeable. :)
    • Is WHC34 a 2 wheel drive Stagea?  4wd Stagea 100% fits, and I'd say 99% sure 2wd will too....they just used the GTR setup as that best suited the wagon floor. BTW I hope you saw Brett's post about potential reasons for a leak, unless you can see the plastic cracked somewhere, it is unlikely to be the tank itself leaking.  Can you see fuel dripping or is it just a smell when you park? Have you had any of the tank/pump holder apart?
    • They did get back to me. First response is from the mechanic that did the work. The problem is that the information that followed wasn't in the original report, which again, I let car inspect know should have been provided and influenced my decision to buy. Ball is back in their court and they have 5 more days to respond.  The actual structural damage was not a complete write off as they had me originally believe.  It just needed to be corrected properly and cleanly as opposed to the botch job of whoever did it last on the rad support and undercarriage. Smoothed out the scrappy welds and did it properly plus painted.
    • Haven't updated this is a while. -5 speed conversion is done. Then center console, parking brake handle, and mounting bracket can be adapted from a R34 since the S2 parts are all disco. Console is a slightly different grain pattern and color but works fine. R33/ R34 GTS (no booster) clutch pedal works as well as the matching master cylinder. Wiring is simple, jump the starter connector at the fuse box, note which wires are connected at which position on the auto neutral safety switch and cut off the switch harness and connect to the corresponding switch on the 5 speed. -Rear R34 rear subframe swap is completed. Full Nismo arm set, 2-way LSD set up soft, 322mm Brembo brakes, Ohlins Flag-R coil overs (need to drop the spring rate 1Kg) -RB swap is under way. HKS Step 2 High Response 2.8 BCD stroker kit / Step 2 V-Cam / GTIII 4R Kit I may not use the 4R kit but not sure yet as I've seen some pretty decent dyno sheets on it and it doesn't spool as slow as people think when you have v-cam. I have the wiring manual for the car and a spare 260RS harness so the wiring shouldn't be that bad but I just haven't had the time to invest in it. If anyone has a suggestion for someone who can handle it let me know! I have a bunch of spare 5mt swap parts and some Nismo 580 turbos if anyone needs/wants them hit me up. Located in California but willing to ship. As always, thanks to all the members who have answered my questions and helped this project keep moving!
    • Did Car Inspect get back to you? How bad was the actual "structural" damage? What front surgery was required?
    • I would be, however the last PS I owned was a PS1 and the last GT I played was GT1 lol. Also, how do you dads even have time to do anything? I barely have time to even sleep 7 hours a night!
