Post Up Your R33!
nizmo_freek
Nice work, are they the endurance caliper? Do they take a 36mm thick rotor and 30 mm thick pads?
Do you still run ABS? I can get mine to lock up for a tenth of a second before ABS kicks in and does its thing. Thats running RE55s tyres...
Like the pic in your sig, looks familiar....
Sweet pic dude. Yeh they are the endurance caliper with 36mm rotor and 30mm pads.
As you can imagine, they never fade. Ever.
No ABS on mine, have never used it. Find it kicks in prematurely in the GT-R's and you can brake better if you get your braking zones perfect.
On the other hand, it makes it harder, so I'm probably looking to go to something a bit less serious and a bit more street friendly.
F*CK YEAH. that is mint haha.
my 31 daily looked like that a few weekends ago :)
haha cheers :)
LOL WTF?!
if you aint layin rail you fail
LOL thats chapel st spec..
bro!
please
You need a chapel pass before it is true chapel spec lol
i used to live in werribee and im not ethnic.
needs more low :D
GTFO :D
I find the ABS to be idiot proof, just go in late and stand on the pedal has hard as you can!!!!
Without ABS it would be much trickier.
What brakes you running on the rear??
Just stockers. After driving mates GT-R's with upgraded rear brakes I definitely prefer a front bias. They all seem quite twitchy in the rear and I just can't justify the extra cash haha
that bumper looks like a pretty good fit aye
Where did you get it?
thanks mate! actually there is a slight bulge just below the grill which i havent got time to fix..! i got the front bar from japanautos wreckers located in redcliffe, brisbane.
S1: nice and clean and smooth, match's the lines of the car with nothing out of place.
S2: oops we forgot the indicators, does not matter just jam them in some where and use some sqaured off corners that dont match any of the lines of the car, people will love it coz its a S2.
The S2 indicators/fog lamps follow the 00<<>>00 style of the tail-lights...it balances the car, plus also to me it's bold, uncompromising, distinctive. The same S1 lights just look generic like off a camry or something.
I'd like to see someone use angel eyes in those fog lights.
S2 FTW! :)
Edited by Tony de Wonderful
No it's been proved to be more effective than any professional driver in perfect conditions.
It's one driver aid you can't argue against.
The only thing maybe is it encourages complacency.
    • Great for thrashing on the track - particularly if it is all corners. Otherwise, it is a recipe for massive tyre wear and reduced straight line traction. -1 is plenty for a streeter.
    • There are other MAP tapping ports. There's one that runs to the boost gauge MAP sensor on the firewall (over in the corner behind the brake booster). Start at that sensor and follow the hose to the plenum.
    • Japanese circuits have always looked tight to me on Youtube vids. They seem to be able to fit tracks into the smallest of spots. I've never experimented with camber in the rear. I'm running similar front camber to you (albeit in the E90) but I've been looking into what options I have in the rear. -3 rear seems like a lot. Yeah, mine is the N54. I had an N52 330i for about 7 years, it was awesome but I just needed a little more poke. The N54 is also DI. I'm running BC coilovers with the M3 front arms and a Whiteline front sway bar and the turn in and ride quality is brilliant. But I do still suffer from a bit of roll so I've been looking into that lately.
    • Thank you for explaining. Makes more sense now. I saw that diagram but wasnt sure if the MAC solenoid would use the same plumbing. So I just did what the stock looked like. Ill get that fixed. I even saw this image As for MAP sensor, When I place vacuum line from MAP to stock location vac reference ( port by BOV flange ) the car runs like crap. I think the port is clogged or something, cause when I moved the MAP line to plenum and connected the BOV to that line, I get compressor surge. This is why I moved MAP vacuum line to plenum where BOV is. Where can I T the MAP vacuum? Sources Ive read said to let MAP vacuum be its own and not to T.
    • You've done it wrong. I don't have time right now to type up enough. I'll have to come back to it or maybe someone else will in the meantime. The boost signal has to pass through the MAC valve from boost source (turbo outlet - effectively anywhere between the turbo outlet and the throttle body will do, but closer to the turbo outlet is best) to the wastegate. What you have done is connected it sort of like the stock solenoid. But it doesn't work the same way as the stock solenoid. That Tee piece that you have connected the solenoid to....? The solenoid itself serves that function. You should look up a typical MAC valve connection diagram for a single turbo internal wastegate application. You'll find one easily enough. Every single boost controller manufacturer that uses MAC valves will have one. Bugger it, I'll just grab the HP Academy one. The other thing you have to get right is that the boost source has to be connected to the correct port on the solenoid valve. This is because the solenoid makes the valve switch from connecting 2 of the ports when it is unpowered, to connecting one of those first 2 ports to the third port when it is powered. One inlet, two outlets. You will note from the diagram that the common port is port 3, the port to the wastegate is port 2, and port 1 is the vent (where the boost signal escapes when the solenoid pulses ON). As to the BOV.... the vacuum signal for the BOV simply has to come from the plenum. It must register boost when you're on boost and vacuum when the throttle is closed. That's all. The original location on the plenum is best. Best practice is never to interfere with the vacuum line running to the FPR. Just leave that one alone, as you will avoid causing unintended problems that might occur if you mess something up.
