RB25DET gearbox ratios
HOLD64
I'm trying to decide which box I should use behing my RB30.
Does anyone have the gear ratios for the RB25DET box (R33 if there is any difference?)
..stretching for info here but does anyone know the differences between the MX7(VL Commodore Turbo 5speed) and the RB25 box? I have an MX7 box but am thinking about purchasing an RB25 box as I've heard it may be better suited to my 4.11 diff. Would also like to know if it is any stronger than the MX7?
I know the RB25 box will be younger which is an advantage.
Cheers
don't remember were i got this info from but it was from one of these skylin sites:
1st 3.592 : 1
2nd 2.057 : 1
3 1.361 : 1
4 1 : 1
5 0.813 : 1
from memory the vlt box has a lower ratio for the 5th gear due to our top speed in australia is higher then that of japan, and we also run lower final drive ratios
This might help:
http://www.nitroware.net/~tony/skyline_book.pdf
Not sure that it has RB25DET ratios, but I am sure it has some in there - just my server is a bit slow at the moment, so got bored waiting:D
The skyline uses a 4.11 final too if I am not mistaken, so it should be a good match.
Not too sure about the strength comparsion, sorry.
Hope it helps anyway
Steve
The RB25DET gearbox is basicaly the same as a GTR gearbox (gear width, bearing size, shaft diameter etc) so it is a very strong gearbox. It's been a few years, but from memory a VL box looks to be smaller than a RB20DET gearbox which is way smaller than a RB25DET box.
We have used RB25DET boxes up to 620 bhp with no problems, so they are way tough.
This is my understanding of the ratios;
1 3.321
2 1.902
3 1.308
4 1.000
5 0.759
R 3.382
Diff 4.363
Hope that helps
my NA R33 started life with a factory 4.3 lsd but it developed a bad whine. The only replacement i could find was an R33 turbo lsd diff (4.11) (How's ya nuts slip?) :D
Rpm seems approx 100-200 lower now at the same speed (according to the speedo which is no doubt now out from the swap also)
The normall aspirated VL box is small and weak - around the same size or smaller than the RB20. But the MX7 or VL turbo gearbox looks pretty much the same as the RB25 box, same physical size. If you have the two of them sitting side by side you'd be lucky to tell them apart. I'm wondering if there is much difference inside them.
Might stick with the MX7 for the moment as I already have one - they are always a straight swap later if I feel the need.
Thanks for the info guys.
    • Yes indeed ; They offered it to me, I'm waiting for their quote 😉
    • Hey, thanks dude. Freedom to do whatever one wants to with their own car and build, but personally I don't want anything that's too precious. If I can't beat on it when I feel inspired, what's the point of having a car like this? And if I break something, it's me who's going to be fixing it myself...
    • https://files.fm/u/nrm9zrpkjj
    • Admin delete if not allowed please, I just purchased an r32 GTST with a Gtr front bar , grill I assume bonnet? (maybe) I have 2 questions he told me it had an RB25det I’m new to the RB world, and this is the photo I have taken and also I noticed a piece near my suspension broken is this fixable , will update new photos tomorrow once I have lifted her up and removed the LHS wheel I want to know if there is ways around this , I didn’t notice anything as it drove with no knocks on the suspension or weird feeling    the car feels sluggish, and the rpm cluster literally goes to 3.5-4k rpm and when you put your foot down it dances around like the local girl on Canterbury road or Sefton playhouse the car sat for 8 years he said the oil was dropped and re done , I noticed the oil was very clean car starts no problems by all means it’s not a clean car it is a project but doesn’t need much, knowing me I will go overboard the colour is horrible car has 88k kms hardly driven needs a few things but it’ll be fun to build properly    so guys is this an rb20 or rb25 and what is this bracket called? Can it be fixed thanks
    • found this on the forum , suggests I am in the range  ----------------------------- From the segmented (potentially incorrect) information I've found that;  Early R32: RB26000XXXX to RB26002XXXX  Mid R32: RB26003XXXX (V-Spec I RB26-03XXXXX - Reference Classic Register) Late R32: RB26004XXXX (V-Spec II RB26-042XXXX - RB26-045XXXX - Reference Classic Register) Early R33: RB26005XXXX Mid R33: RB26006XXXX (as per the engine in this R32 V-Spec II, which is what I'm concerned about from legitimacy perspective) Late R33:  RB26007XXXX Early R34 (2000+):  RB26008XXXX ----------------------
