IPB
4 Pages V   1 2 3 > »
> Transmission Cooler
Sydneykid
post 22 Dec 2004, 11:52 PM
Post #1
RB31DET
Group Icon
Trader Rating : 49
I have finally fitted the large (Davies Craig) auto transmission cooler to the Stagea. The part number I chose was 678 which is the largest universal (280 X 216 X 19) I could find with 3/8" fittings. The catalogue specifies for engines "4.2 litres and over"
I don't own or work for a workshop and I don't know everything.
Wanted standard front and rear strut tops for R32/33/34 Skylines and Stageas plus 200SX S15 & S14
Group Buys on for Road & Track Kits (Whiteline, Eibach & Bilstein) for R32GTST, R32GTR, R32GTS4, R33GTST, R33GTR, R33GTS4, R34GTT, R34GTR and Stagea, plus Road and Track Kits for 200SX, S15 & S14
Profile CardPM
Go to the top of the page
+Quote Post
Googlebot
Post #
Trader Rating :
> Google Ads
Quote Post
Jay95R33
post 23 Dec 2004, 08:55 AM
Post #2
Rank: RB30E
Trader Rating : 40
Good stuff, thanks SK.
Is there any performance difference with running a bigger cooler (nicer/quicker shifts) or it mainly for a safe gaurd for towing ?
I noticed on mine there's a smallish cooler up the front, but not sure if this is for the gearbox or power steering.
J
Profile CardPM
+Quote Post
Sydneykid
post 23 Dec 2004, 09:13 AM
Post #3
RB31DET
Group Icon
Trader Rating : 49
QUOTE(Jay95R33)
J
Hi J, the cooler in front of the radiator is for the transmission, it is in series with the usual coils in the bottom tank of the radiator. I am going to replace it with the new much larger one, but still keep it in series with the radiator coils. The same as the std cooler, the transmission fluid is cooled by the radiator water first, then cooled some more by the new cooler. This ensures that the trans fluid going back to the transmission is as cool as it can be.
It's a bit tricky to mount as I want to make sure the FMIC will fit when I get around to doing it. Don't want to have to move the trans cooler again.
The trans cooler will ensure minimum transmission wear, excessive heat really kills them. They start to get slow and slip on the gear changes before they eventually fail. So I guess it's a performance advantage by keeping the gearbox functioning at its optimum. Sorta like forged pistons, doesn't make the car go faster on its own, but makes sure it KEEPS going fast
Unike the R32, which has hydraulic HICAS, the Stagea (without any HICAS) doesn't have a power steering cooler. There are some small fins on the return pipe to the power steering fluid reservoir between the radiator fan and the engine. I don't think I will need better cooling on the Stagea like the R32 race cars do, even though they don't have HICAS anymore. I am going to recycle the standard Stagea trans cooler as a power steering cooler to replace the simple loop of pipe that serves as the standard cooler on the R32 GTST.
Pictures shortly:cheers:
Profile CardPM
+Quote Post
Sydneykid
post 23 Dec 2004, 10:18 AM
Post #4
RB31DET
Group Icon
Trader Rating : 49
The Davies Craig cooler is somewhat larger than the standard cooler plus it is a full tube and fin style, not a U bent piece of pipe with fins like the standard cooler.
As you can see I attached it to the standard bracket. I drilled 2 extra holes in the cooler mount and bolted it to the bracket using the standard top stud and I drilled a new lower hole to match the cooler bracket. Tools used where a 10 mm socket and drive, cordless drill and a 6 mm drill bit.
I had to remove the top horn while I worked as it was in the way, it also needed a slight bend upwards in the bracket to clear the new trans cooler. So did the lower horn, it need a slight bend forwards. Note that you need a 12 mm socket for their bolts.
As you can see from the pictures I had to mount the cooler a liitle lower than would be ideal for it to line up with the Stagea upper grill. The bonnnet latch and the standard pipework limited the postion, so I compromised. It is in line with the engine fan which draws a lot of air through all of the cooler, so it should work great.
I had to put a loop in each of the supplied rubber hoses to line up with the standard pipework. I used a couple of cable ties to hold the looped rubber hoses to the standard brackets as I don't like the weight of the hoses swinging off the 3/8 fittings on the cooler. The cable ties take the weight and stop any vibration loading from swinging hoses. I used thin green cable ties so they showed up in the photos, but I will change them to thick black ones later. Tools used where a medium philips head screw driver for the supplied hose clamps (I couldn't find my 6.5 mm socket), and the trusty 10mm socket and rachet.
It is a pretty simple job, it really only took me about an hour to actually do the work. As usual, it took me 2 hours to work out exactly where to put it and how to mount it. So I hope I have saved you that time.cheers.gif
PS; Don't forget to top up the transmission fluid, the new cooler and longer hoses will lower the level.
Profile CardPM
+Quote Post
Jay95R33
post 23 Dec 2004, 10:39 AM
Post #5
Rank: RB30E
Trader Rating : 40
Great work SK, thanks for the info. Looks pretty straight forward too.
Sorta off topic a tad, but have you had any experience with shift kits for auto transmissions? Apparently they speed up the shift and lenghten the life of the box etc..
J
Profile CardPM
+Quote Post
burkey22
post 23 Dec 2004, 10:45 AM
Post #6
Trader Rating : 1
I want to thank you too SK. And good question Jay. I've been wondering the same thing. Gee I can't wait til after christmas so I can start spending money on my car again.
Then I met a man who had to walk with his hands.
Born into a world he couldn't stand.
Blessed with life.
Cursed as man.
Still he walks taller than most of us can.
Profile CardPM
+Quote Post
Sydneykid
post 23 Dec 2004, 10:51 AM
Post #7
RB31DET
Group Icon
Trader Rating : 49
QUOTE(Jay95R33)
J
Hi J, I drove an R33 GTST in SA a while back that had a new (performance) valve body fitted. Cost around $500 if I remember rightly. It certainly sportied up the change and reduced the slip. That car had 240 +rwkw and it wheeled up on the 1st to 2nd change. It was a bit harsher than standard on light throttle up and down changes, but not intolerable.
I think you would need a more solid shift when the power gets up, otherwise the gearbox will kill itself with slippage. I will try mine at my power target (200 awkw) first, if it slip/slurs on changes I will grab one of those valve bodies and replace the standard one.
Profile CardPM
+Quote Post
Jay95R33
post 23 Dec 2004, 12:28 PM
Post #8
Rank: RB30E
Trader Rating : 40
Interesting stuff.
I think at around 200kw with awd the shift kit may be a good thing. Lots of traction and a heap of power could see the box slip heaps. The cooler will help a lot though smile.gif
$500 is pretty good if you compare it with the cost of a decent HD (or twin plate) clutch in a manual.
I still haven't had a chance to get that fuel pump in in mine sad.gif then I'll book it in to see how the Unichip and boost controler goes with the auto transmission.... So damn busy sad.gif
J
Profile CardPM
+Quote Post
Sydneykid
post 23 Dec 2004, 02:07 PM
Post #9
RB31DET
Group Icon
Trader Rating : 49
The auto is pretty tough bugger, I have seen it in all sorts of Nissans from 300ZX's TT's to Patrols since the late 80's. It seems to be THE auto that Nissan uses in anything BIG. The insides are pretty tough, if you keep them cool and change the transmission fluid and filter regularly they last a LONG time.cheers.gif
Profile CardPM
+Quote Post
Jay95R33
post 23 Dec 2004, 02:32 PM
Post #10
Rank: RB30E
Trader Rating : 40
I was just thinking. Are the performance valve bodies electronically switchable in anyway ? Would be perfect if you could hook it upto the 'power' switch so it was on when in power mode.
Profile CardPM
+Quote Post
Burns
post 26 Feb 2005, 03:58 PM
Post #11
Trader Rating : 1
How much did the Davis Craig kit cost?
I have a few coolers lying around that I could probably make fit but it might not be worth the trouble if the Davis Craig kit is not too expensive and is proven to be an easy fit.
The silver and copper coloured one would probably be my best bet.
Stagea RS4
Dato 1600 Rally Car
Gemini Turbo Diesel
66 Mustang
Profile CardPM
+Quote Post
Sydneykid
post 26 Feb 2005, 06:28 PM
Post #12
RB31DET
Group Icon
Trader Rating : 49
QUOTE(Burns)
The Davies Craig trans cooler kit was $150 retail.
I am not a fan of the "bent pipe with fins hanging off it" style. I prefer the
"tube and fin" style, so the black one in the top left of your photo looks the go.cheers.gif
Profile CardPM
+Quote Post
Abo Bob
post 26 Feb 2005, 07:31 PM
Post #13
SAU NSW President
Group Icon
Group Icon
Group Icon
Car(s): R34 GTT
Real Name: Bobbeh
Trader Rating : 28
The one you're referring to looks just like the R34 GTT one is size shape and everything.
Jay, They are physically changing the channels and valving so there would be no elctronic switching with this type of setup.
Profile CardPM
+Quote Post
Lone
post 28 Feb 2005, 02:12 PM
Post #14
Trader Rating : 0
Where did you purchase it from at $150 retail SK? Cause here at work we are a distrubutor of davies craig products and their listed $260 retail!
Profile CardPM
+Quote Post
