30 Oct 2005, 09:04 PM
RB25DET ![]() ![]() ![]() ![]() Posts: 295 Joined: 16th February, 2005 From: Brisbane Trader Rating : 2 |
Just want to know what the first signs are of the diff wearing out. And what is a easy replacement also without going for a GTR one what would a cheap but good option be?
Not that it needs it, just woukld like info |
30 Oct 2005, 10:00 PM
![]() JUN RB27DET - HKS T04Z ![]() ![]() ![]() ![]() Posts: 433 Joined: 29th May, 2005 From: Perth WA Car(s): GTR wagon, VS Berlina Trader Rating : 0 |
ive got a complete rear diff from my rs four stagea for sale if u get desperate (postage might be abit)
$100+ postage and its yours, if u interested i can weigh it to find out postage cheers Brad -------------------- |
30 Oct 2005, 10:12 PM
Thanks but no thats i'm just redearching
30 Oct 2005, 10:13 PM
Can someone point out to me how difficult it is to replace the stagea diff with a GTR one?
I mean, it may be smart for me to buy thise one off you Stage and work on it off the car and when time comes, just do the swap.. or do i get a new housing and everything? NISMO GT PRO are made for Stageas. Look at around 1600 landed brand new though |
30 Oct 2005, 10:14 PM
QUOTE(emanuelt @ 30 Oct 2005, 10:12 PM) Thanks Brad but I think I need to research a bit more first. Also Mine is still good it just clicks sometimes. What condition is yours in? Didn't you snap something. Well I could get it for spear parts for later on ??? Yes postage would be heaps though.WA to QLD. yer i broke an axle not the diff, it was quiet as, but dont rush cause i aint advertising it really and no one wants it either haha just let me know in the future if u want it -------------------- |
30 Oct 2005, 10:25 PM
QUOTE(AlexCim @ 30 Oct 2005, 10:13 PM) Can someone point out to me how difficult it is to replace the stagea diff with a GTR one? I mean, it may be smart for me to buy thise one off you Stage and work on it off the car and when time comes, just do the swap.. or do i get a new housing and everything? NISMO GT PRO are made for Stageas. Look at around 1600 landed brand new though the diff internals fit str8 in the stagea diff housing, therfore the mountings for attessa pumps still bolt up as gtr pumps are elswhere, and u can use the stagea diff plate rear cover so it fits with no mods, or gtr cover allows for more oil and has fins on it, but requires slight massage of rear crable (very minimal, like 2mm change needed) with a pair of vice grips it look 5 min and isnt even noticable. u need to use the gtr rear brake hubs which have gtr mountings for the fork end rear shocks (stagea have eye end instead), everything bolts on, except the brake line fitting is different but i got braided rear lines made up for like $100 i think. only issue is u need one gts4 (gtr ones are alot shorter) LONGEST side axle (cant remember which side is the longer of the two off the top of my head), and that will fit perfectly on the stagea shorter side, then u have to get a custom length made from a driveshaft shop which wouldnt cost too much. and u gotta change the main diff crown wheel(largest gear in the diff) to the stagea one so it keeps the 4.3 ratio same as the front. cheers Brad -------------------- |
31 Oct 2005, 07:19 AM
#7
I think its best if i just get the aftermarket diff.
Doubt ill snap an axle then with ~250awkw plus, its going to be a 1.5way and brand new/tight...also a lot less work. I just want an LSD, not a full rear conversion. |
31 Oct 2005, 05:24 PM
#8
QUOTE(AlexCim @ 31 Oct 2005, 07:19 AM) I think its best if i just get the aftermarket diff. Doubt ill snap an axle then with ~250awkw plus, its going to be a 1.5way and brand new/tight...also a lot less work. I just want an LSD, not a full rear conversion. What aftermarket diffs are available for Stagea? and costs? |
1 Nov 2005, 04:09 PM
#9
![]() Advanced Motorsports ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 3,310 Joined: 24th August, 2005 From: Newcastle NSW Car(s): S13 Onevia RB20DET Real Name: Chris Trader Rating : 1 |
NISMO GT PRO - Around $1600
8 Feb 2006, 10:24 PM
#10
I am getting some serious clunking from the rear of the car.
I only get it on slower tyre corners and when changing into D. Its not a click like above, its a full on "thud/clunk" I dont get any noise when going straight hard acceleration, or around fast corners or anything. Only on tight uturn style turns, where the wheels have a big difference in rolling distance. Of all the possible things it could be, the diff would be the most likely culpret right? Brad, what would it cost to send me the diff here to Melbourne? If i was to go an aftermarket NISMO diff, would there be any issues with the car being auto or 4wd or anything. I know that sounds stupid, but just wondering. Am i just better off with an open wheel diff in a car like this, or would an LSD provide me benefits in the hills? Thanks and sorry for digging up an old thread, better then starting a new one. |
8 Feb 2006, 11:07 PM
#11
Rank: RB25DET ![]() ![]() ![]() ![]() ![]() Posts: 1,401 Joined: 2nd January, 2006 Trader Rating : 8 |
hey alex doesnt sound good, well i'd be checking underneath and jacking up whole car so all the wheels are off the ground. then get underneath with it in nuetral and turn the rear tailshaft connecting to the diff and then turn it back the other way and see if it has any slack or play in it and see if it clunks, then turn the rear wheels the same and back the other direction and see if it makes a clunking noise. it could be a a tailshaft uni joint worn out or something similair so i'd be checking the slack on the rear shaft compared to the axles. it may be easier to unbolt the rear tialshaft off the diff as turning the snout of the diff will be easier and u can turn it in both directions quickly to see if it has any slack. could be axle uni joint, or maybe even a wheel bearing, plenty of possibilities before blaming the diff itself.
does yours have a tow bar on it or been used for towing at any stage as that may have worn it out extra quickly. give it a go and let us know cheers Brad |
8 Feb 2006, 11:23 PM
#12
Crud..
Its getting worse and worse lately. I guess I will take it easy with the car. I am sure whatever spare parts I need I can count on you brad seeing as you are not using basicially the whole rear of the car? Ill jack the car up tomorrow after work and do the wheel turning trick see where the noise is coming from. BTW, towbar isnt on yet. No towing been done so far AFAIK |
9 Feb 2006, 06:12 AM
#13
![]() Speed... I am Speed ![]() Posts: 3,452 Joined: 15th June, 2003 From: Bathurst Car(s): VT Commonbore Wagon Real Name: Leshy Trader Rating : 8 |
Have you checked your attesa fluid or transmission fluid? i remember on my old automatic kingswood (yes i know it's completely different) i was getting a massive clunking noise and i thought the diff was stuffed. turns out the fluid was low and when i went around corners slowly the fluid would slosh to the edge of the reservoir and essentially the transmission wouldn't have any fluid running through it. start with the simple things first, then work your way to more expensive things (ie:diff)
9 Feb 2006, 08:29 AM
#14
atessa fluid in the boot is between max and min on flat ground.
9 Feb 2006, 08:42 AM
#15
QUOTE(AlexCim @ 9 Feb 2006, 06:29 AM) in the gtr workshop manual it says u gotta make sure the ignition is ON when checking the attessa fluid level. id also check the auto tranny fluid as mentioned, and just when turning the rear wheel to see if it clunks might not work because it being non-lsd only the wheel u turn will turn and the tailshaft/other side wheel wont even move at all, so u wont hear any noises, so the diff snout is the easiest way to check and its easy to unbolt the tailshaft, only 4 allen key bolts i think. |
9 Feb 2006, 09:07 AM
#16
![]() RB31DET ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 11,111 Joined: 31st January, 2003 From: Sydney Car(s): R32GTST R33GTST Stagea Trader Rating : 49 |
Diffs don't usually clunk when they wear out, they wine and howl. Sounds more like a joint to me, drive shaft, cv or tailshaft uni. I would be doing the "rotate and look for slack" test.
-------------------- I don't own or work for a workshop and I don't know everything. Wanted standard front and rear strut tops for R32/33/34 Skylines and Stageas plus 200SX S15 & S14 Group Buys on for Road & Track Kits (Whiteline, Eibach & Bilstein) for R32GTST, R32GTR, R32GTS4, R33GTST, R33GTR, R33GTS4, R34GTT, R34GTR and Stagea, plus Road and Track Kits for 200SX, S15 & S14 ![]() ![]() ![]() |
