IPB
6 Pages V   1 2 3 > »
> Stagea Air Deflector
Sydneykid
post 9 Nov 2004, 02:14 PM
Post #1
RB31DET
Group Icon
Trader Rating : 49
Next project on the Stagea is to make up an air deflector to go between the grill and the top of the radiator support panel. At the same time I want to make up a scoop to make sure the standard inlet to the air filter gets enough ambient air to feed the engine. It will bolt up to the radiator support panel and fit into the standard slot in the top of the Stagea grill.
First job was to make up a rough cardboard template, picture follows;
Then I will cut the 2mm aluminium sheet to the shape of the template. I will make it out of 2mm for a bit of extra rigidity, as it will only be supported/bolted at the rear and slot into the grill at the front.
More next installment:cheers:
I don't own or work for a workshop and I don't know everything.
Wanted standard front and rear strut tops for R32/33/34 Skylines and Stageas plus 200SX S15 & S14
Group Buys on for Road & Track Kits (Whiteline, Eibach & Bilstein) for R32GTST, R32GTR, R32GTS4, R33GTST, R33GTR, R33GTS4, R34GTT, R34GTR and Stagea, plus Road and Track Kits for 200SX, S15 & S14
Profile CardPM
Go to the top of the page
+Quote Post
Googlebot
Post #
Trader Rating :
> Google Ads
Quote Post
Jay95R33
post 9 Nov 2004, 03:10 PM
Post #2
Rank: RB30E
Trader Rating : 40
Wow, you've been busy with your Stagea.
I'll be keeping a keen eye on this thread.
J
Profile CardPM
+Quote Post
mcnamg
post 9 Nov 2004, 06:13 PM
Post #3
Group Icon
Group Icon
Car(s): Jeep Wrangler & Territory
Trader Rating : 1
ill be keen to see what this turns out like I cant wait for the pic smile.gif
Profile CardPM
+Quote Post
gtst25
post 20 Nov 2004, 08:31 PM
Post #4
gtst25
Car(s): r33 gtst, JZS147 Aristo
Real Name: Glen
Trader Rating : 1
Looks good SK
Would be good on my '33 - hmmm... materials - there's so many options - aluminium, carbon fibre, plastic.....
I'd like to see the end result!
Profile CardPM
+Quote Post
mcnamg
post 21 Nov 2004, 12:16 AM
Post #5
Group Icon
Group Icon
Trader Rating : 1
best to use something that wont get too hot i suppose
Profile CardPM
+Quote Post
Sydneykid
post 21 Nov 2004, 09:45 AM
Post #6
RB31DET
Group Icon
Trader Rating : 49
Hi guys, a little progress, this is the cut out alloy deflector. It is 2mm thick, which is a bit much. Around 1.5 mm would have been OK, but I didn't have a piece large enough. What's a few grams extra weight here or there compared to the weight of a Stagea?
The next step is a test fitting on the Stagea, which I will do this afternoon. Then I can cut out and bend the air feed (scoop) for the air filter inlet. I will post up some picures of that later on:cheers:
Profile CardPM
+Quote Post
Jay95R33
post 21 Nov 2004, 03:07 PM
Post #7
Rank: RB30E
Trader Rating : 40
J
Profile CardPM
+Quote Post
ICE12
post 21 Nov 2004, 03:48 PM
Post #8
Trader Rating : 0
You will have to make two so that you can use it as a mould for the CF one, I'll be in on that SK.
Cheers ICE
Profile CardPM
+Quote Post
mcnamg
post 21 Nov 2004, 04:51 PM
Post #9
Group Icon
Group Icon
Trader Rating : 1
yeah would look cool in carbon fibre you could even get even tricker and make it up so that is forms a really wide mouth for the air intake
Profile CardPM
+Quote Post
Sydneykid
post 21 Nov 2004, 09:10 PM
Post #10
RB31DET
Group Icon
Trader Rating : 49
Ok did a quick test measure, cut out and bent the scoop for the air inlet to the standard snorkel......
The next step is to put some sides on the scoop, I will be using some right angle aluminium and then rivet it to the scoop. More pictures tomorrow:cheers:
Profile CardPM
+Quote Post
mcnamg
post 21 Nov 2004, 09:34 PM
Post #11
Group Icon
Group Icon
Trader Rating : 1
looking good are you going to paint it?
Profile CardPM
+Quote Post
Sydneykid
post 21 Nov 2004, 09:44 PM
Post #12
RB31DET
Group Icon
Trader Rating : 49
QUOTE(mcnamg)
I haven't decided what to do. I would normally use the plastic coated aluminium sheet, so it doesn't get marked while you work. Then I would simply peal it off and it would polish up nice. This one is a bit marked, I might paint it, or stick some carbon film on it, or I might polish it with a pattern, I don't realy know yet:cheers:
Profile CardPM
+Quote Post
mcnamg
post 21 Nov 2004, 10:31 PM
Post #13
Group Icon
Group Icon
Trader Rating : 1
what do you cut the metal with?
Profile CardPM
+Quote Post
Sydneykid
post 22 Nov 2004, 05:55 PM
Post #14
RB31DET
Group Icon
Trader Rating : 49
QUOTE(mcnamg)
I have a number of cutting devices. I mostly used the band saw on this, for closed holes I used the jig saw, too lazy to use the hacksaw.cheers.gif
Profile CardPM
+Quote Post
Sydneykid
post 25 Nov 2004, 11:30 PM
Post #15
RB31DET
Group Icon
Trader Rating : 49
The last steps before I fit it. First, pop rivet the sides to the scoop, then I polished it with Scotchbright to help hide the scratches;
I just have to drill the mounting holes and hopefully the next pictures of it will be when it is fitted to the Stagea.cheers.gif
Profile CardPM
+Quote Post
Terminal
post 26 Nov 2004, 12:46 AM
Post #16
