IPB
2 Pages V   1 2 >
> Stagea 5000km Service
Tangles
post 6 Apr 2006, 11:01 AM
Post #1
Rank: RB30ET
Group Icon
Car(s): Nissan Stagea RS-Four V
Trader Rating : 12
whistling.gif Hiya's all, after a little bit of info from you'se all!
My Stagea is due for a 5000km oil change, etc. Its done just under 5000kms since I bought it, but in that time Ive had a couple of dyno sessions, etc.
Id like to drop the oil, change it, and do the oil filter as well. Thats going to happen tomorrow (fri 7/4/6) when my castor bushes are installed and the suspn work retightened 9after the initial 100km rundown).
What oil would you all suggest? Im thinking Mobil 1? Also, is the oil filter the same as a standrad R33 one, and if thats the case, does anyone know the genuine Nissan part number?
Also, what else should be 'touched' at a basic 5000km oil change?
Cheers, Brendan
Profile CardPM
Go to the top of the page
+Quote Post
Googlebot
Post #
Trader Rating :
> Google Ads
Quote Post
Sydneykid
post 6 Apr 2006, 11:15 AM
Post #2
RB31DET
Group Icon
Trader Rating : 49
Hi Brendan, we only use Castrol lubricants in all the cars, so my Stagea has Edge 10W60 in it. At 5,000 k's I do the usual fluids check, radiator, auto trans, washer bottle fill, brake fluid, tyre pressures, ATTESA reservoir, all the globes (there is always one out somewhere, usually dash), brake pad thickness and brake hose condition. Then I do a quick whip around with the spanners and check the tightness of all of the non standard stuff. Lastly I make sure the wheel nuts can be removed by the female drivers (that's not more than 70 ft/lbs on the tension wrench).
I don't own or work for a workshop and I don't know everything.
Wanted standard front and rear strut tops for R32/33/34 Skylines and Stageas plus 200SX S15 & S14
Group Buys on for Road & Track Kits (Whiteline, Eibach & Bilstein) for R32GTST, R32GTR, R32GTS4, R33GTST, R33GTR, R33GTS4, R34GTT, R34GTR and Stagea, plus Road and Track Kits for 200SX, S15 & S14
Profile CardPM
+Quote Post
Tangles
post 6 Apr 2006, 12:01 PM
Post #3
Rank: RB30ET
Group Icon
Trader Rating : 12
QUOTE(Sydneykid @ 6 Apr 2006, 11:15 AM) *
Ta mate! Thanks for that advice.
I know the globes are all good (besides one in the A/C dash area), and the tyres are 2 weeks old, so thats all good too. I'll ask him to have a quick look at the fluids of the car - cheers. With the toe and camber settings I'll leave that until I have a wheel alignment!
Query: is the castrol Edge better than mobile 1? I thought Mobile 1 was premium oil......... I used to use it in my V8 BT1 commodore.
Brendan
PS Gary - Got to say, Im a fan of the suspension components I bought from you - thank you very much again for all of that. The Bilstein shocks are a touch hard, but nice nonetheless; they have done 30kms now! And Im happy that Im using the standard springs. Heights are 370mm all round, so I might drop 1 circlip at each corner, eventually. The standard shocks were weeping, and basically rooted. Glad I did the group buy.
Profile CardPM
+Quote Post
AlexCim
post 6 Apr 2006, 07:39 PM
Post #4
Rank: RB30E
Trader Rating : 9
I use castrol GTX3 at the moment, but my next change will be with Synthetic R, it might be 3 times the price, but i do give it a pretty hard life, might as well spend that extra $10 a month and give her the best, so i can treat her like i do tongue.gif
Profile CardPM
+Quote Post
3intheBack
post 6 Apr 2006, 10:08 PM
Post #5
RB25DET Neo
Car(s): 1 mellow yellow S2
Real Name: Wazza
Trader Rating : 1
Aaahhh good ol Mobil 1. I remember my bike riding days in the mid 80's when we used Mobil 1 'cause a racer friend swore by it and it cost a little under $30 for 4L. But then good oil in those days was around $10-15. Then everyone else found out Mobil 1 was good, then the price went up to $40. Then $45. Stopped buying it then as a personal protest at the price. The rest is history and $30 looks cheap.
Bob Romano has seen a 30Hp increase on the dyno in large (old) V8s just with an oil change from basic oil to Mobil 1.
Brendon, The oil filter part no. is elsewhere on a thread. I believe RYCO is 145A.
I recently used a Fleetguard SF 3434 filter. $9, available from any industrial filter shop - trucking good quality. Oil was Nulon 10W40 cheap for 6L - you'll need 5 min.
Wazza
P.S Good idea to hose the subframe around the filter before pulling it off as I dont know of anyway you can avoid spilling some out of the filter when you undo it.
P.P.S The crush washer you will need for the sump plug is only about 12-13mm in dia.
Profile CardPM
+Quote Post
Tangles
post 7 Apr 2006, 09:26 AM
Post #6
Rank: RB30ET
Group Icon
Trader Rating : 12
QUOTE(3intheBack @ 6 Apr 2006, 10:08 PM) *
cheers, Wazza
Thanks HEAPS
Profile CardPM
+Quote Post
MrGTST
post 18 Jun 2006, 11:44 AM
Post #7
Its ALIVE!!!
Car(s): Stagea RS4 Type S
Trader Rating : 2
Hi Guys,
Just picked up my stagea and doing the once over.... first thing I have notcied is that the 4wd fluid in the back wagon section of the car is really low... i have some Castrol TQ Dexron III auto trans fluid... can anyone tell me if that suitable for the 4wd fluid? Would like to know so I can top it up????
QUOTE(Wildcat @ 20 Mar 2006, 01:09 PM) [snapback]2032911[/snapback]
you only liked it cause you were able to see her ass while she was dancing!!
your the biggest perve i have ever met...your wife is standing next to you and you walk closer to her to have a look!! lol
QUOTE(GTS-t VSPEC @ 20 Mar 2006, 01:18 PM) [snapback]2032933[/snapback]
Top effort Brett, your a legend :D
Profile CardPM
+Quote Post
Tangles
post 18 Jun 2006, 12:39 PM
Post #8
Rank: RB30ET
Group Icon
Trader Rating : 12
QUOTE(MrGTST @ 18 Jun 2006, 11:44 AM) *
Hi Guys,
http://www.skylinesaustralia.com/forums/in...opic=61606&st=0
see page 1; reading that Id suggest that yeah your fluid would be suitable - I better check mine too!
or see alexcim's setup: http://www.skylinesaustralia.com/forums/in...117723&hl=fluid
Profile CardPM
+Quote Post
MrGTST
post 18 Jun 2006, 01:54 PM
Post #9
Its ALIVE!!!
Trader Rating : 2
Cheers... Thanks for the push in the right direction....
Profile CardPM
+Quote Post
skidkid
post 18 Jun 2006, 05:39 PM
Post #10
Car(s): '98 RS-4 Stagea
Real Name: Jason
Trader Rating : 5
I have used 'Penrite' oils for the last 10 years. I used it when I raced my RX2 as a club car for 4 years, that was a good test. Never had a need to change brands. Since owning the stagea I have used HPR 10 eng. oil. Have been quoted MGO75 for Attessa (am going to double check), SIN 75 for the diffs. I fitted DC tranny cooler 2day and topped up with SIN ATF.
IPB Image
Profile CardPM
+Quote Post
StageaGirl
post 29 Jul 2006, 12:37 AM
Post #11
Ban Stupid People, Not Dogs!
Car(s): 1997 Stagea
Real Name: Kylie
Trader Rating : 4
sorry for being a girl but I need to know a bit more about this sump plug washer?? Where can I get one?
The reason a dog has so many friends is that he wags his tail instead of his tongue.
Profile CardPM
+Quote Post
stasis
post 29 Jul 2006, 08:16 AM
Post #12
Autech 260Rs
Group Icon
Car(s): 260Rs, Landcruiser 100
Real Name: Yudy
Trader Rating : 0
QUOTE(Tangles @ 6 Apr 2006, 11:01 AM) *
Cheers, Brendan
I use Mobil synbthetics 15w/50. Castrol oils and mobil oils works very different from each other. And im not going to disscuss this over the forum w/o getting shot myself from people. All in all Castrol do not make their own oils pinch.gif . That infor is from years ago the sub contract it out. So that tells you all. And thats the only thing im prepared to say.
I have been using Mobil 1 synthetics for all my cars. My lancruiser even uses Mobil Super S anf now its clocking 200k on the dial and still smooth as silk.
Tnangles we can discuss this over MSN if you want later in the afternoon after i get back or if not tommorow.
- 236.5kw@4wheels tuned by Racepace.
Mods :
-Power Fc w/ hand commander.
-Factory boost controller @ 1 bar.
-Aerospeed Cam gears In/Ex.
-Full 3" Front pipe (Hks competition), Nismo cat back exhaust.
- High flow BeeR Cat.
- Drop in replacement filter by K&N.
- Dolphin R speedo. (300km/h limited)
- Hid head lights.
- Tein HA Coilovers. Oz valving. Spring rates F:9kg/mm R:8kg/mm, Tein adjustable Castor Rods. Nismo Front upper and lower Arms, Rear adjustable Upper Camber arms.
Profile CardPM
+Quote Post
oxford1327
post 29 Jul 2006, 08:55 PM
Post #13
CIRCLE THE WAGON'S
Car(s): S2 RS4S,APRILIA RSV1000R
Real Name: daniel
Trader Rating : 8
hey stageagirl have a look at the groupbuy section for the quick change oil valve and you won't need to find/buy a crush washer ever again!!!
i think i worked out how to put in a link ? have a look here and see what ya reckon?
oh and by the way i agree with you on the ban stupid people, not dogs bit!
http://www.skylinesaustralia.com/forums/in...127757&st=0
Profile CardPM
+Quote Post
Tangles
post 31 Jul 2006, 10:51 AM
Post #14
Rank: RB30ET
Group Icon
Trader Rating : 12
QUOTE(stasis @ 29 Jul 2006, 08:16 AM) *
Fair enough - heard that myself on the grapevine too.
We used Penrite 5-60w oil.... seems the goods. Might go back to Mobile 1 when I do a highflow turbo, either that or Castrol Edge or the current Penrite stuff. Plenty of time tho, only do around 8000km per year. By the next oil change I hope to have one of the quick release valves too Ox!
Profile CardPM
+Quote Post
stasis
post 31 Jul 2006, 12:01 PM
Post #15
Autech 260Rs
Group Icon
Real Name: Yudy
Trader Rating : 0
QUOTE(Tangles @ 31 Jul 2006, 10:51 AM) *
Mobil engine oil is able to absorb the carbon deposits from the engine keep the engine clean. thats why mobil oil wil always be black and gooy and castrol will be clean.
Mods :
-Aerospeed Cam gears In/Ex.<
