IPB
> Save Sk Wasting His Time... Online Spring Rate Calculator, Just jwo of thousands available online.
URAS
post 24 Jun 2007, 07:28 PM
Post #1
Rank: RB30E
Car(s): S13(RB26) and 1977 LTD
Real Name: TRENT
Trader Rating : 3
i got sick of doing the same thing on ns.com years ago here are a few good calculator sites. It is a simple calculation.
http://faq.f650.com/FAQs/ShocksSpringRateF...te%20Calculator
http://www.iroczone.com/calcs/chassis.htm
this one will give you a Kg/mm result also
Metric and imperial result
Profile CardPM
Go to the top of the page
+Quote Post
Googlebot
Post #
Trader Rating :
> Google Ads
Quote Post
Scandrew
post 24 Jun 2007, 09:47 PM
Post #2
Rank: RB20DET
Car(s): N15 S2 SR20DET
Trader Rating : 0
I've tried calculating it using them but I'm not too sure what measurements they're suppose to be entered as. I assumed in inches (") and tested a few of the measurements in SKs' thread but can't manage to get the same rates as him so I'm not sure if I'm doing it right?
Profile CardPM
+Quote Post
URAS
post 25 Jun 2007, 12:00 AM
Post #3
Rank: RB30E
Real Name: TRENT
Trader Rating : 3
Remmember the above calcs are imperial, i have a spreadsheet i made in metric. here is the equation for those who would like to know how the calcs work so you can make your own.
11,250,000 - Torsional Modules For Steel (Constant)
CSPWD - Coil Spring Wire Diameter (How thick is the wire?)
8 - Constant
NOAC - Number Of Active Coils (Coils that are free to move. Not coils seated. It may be that 1/2 of the top and bottom coil is seated causing a spring with 8 coils to have the distance of 7 free.)
CMD - Coil Mean Diameter (The diameter from center to center of the coil. Measure the diameter of the coil from wire center to wire center. If you know the coil is .5 inches thick and the outside diameter of the coil spring is 3 inches, then the Coil Mean Diameter would be 2.5 inches)
(11,250,000 x (CSWD x 4))
(8 x NOAC x (CMD x 3))
All Measurements in inches - calculate as decimal ie 1/2 inch as 0.5
Profile CardPM
+Quote Post
Scandrew
post 25 Jun 2007, 12:14 AM
Post #4
Rank: RB20DET
Trader Rating : 0
With your calculator and the following measurements I have an end result of 46037.96138.
Wire ID: 11mm
Coil ID: 64mm
Coils: 7
Profile CardPM
+Quote Post
URAS
post 25 Jun 2007, 12:27 AM
Post #5
Rank: RB30E
Real Name: TRENT
Trader Rating : 3
QUOTE(Scandrew @ 25 Jun 2007, 12:14 AM) *
Wire ID: 11mm (0.433in)
Coil ID: 64mm (2.522in)
Coils: 7
did you input inches or mm? it needs to be in inches.
using http://www.racingsuspensionproducts.com/spring%20rate.htm i get 14kg/mm or 794Lb/in
Profile CardPM
+Quote Post
Scandrew
post 25 Jun 2007, 12:33 AM
Post #6
Rank: RB20DET
Trader Rating : 0
I think I've got it now. I used a unit converter to convert mm to inches.
Looks like I've got a 8F 7R kg/mm spring rate.
Profile CardPM
+Quote Post
Scandrew
post 25 Jun 2007, 12:37 AM
Post #7
Rank: RB20DET
Trader Rating : 0
URAS, you wouldn't happen to be able to recommend spring specs for 4F 3.5R kg/mm rateswould you? biggrin.gif
i.e If I have a coilover currently using a 64mm spring ID, would I be able to use a 61mm spring ID on it?
Profile CardPM
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 24th November, 2008 - 04:55 AM
