18 Jul 2006, 07:35 PM
![]() Why isn't anyone clicking? =-[ ![]() ![]() ![]() ![]() ![]() Posts: 1,911 Joined: 7th May, 2003 From: NSW - Northern Beaches Car(s): R33 GTST Series 2 Real Name: Steve Trader Rating : 7 |
I just finished the job last night, once I remembered to grab my caulking gun!
Things you will need: * Black windscreen sealant - costs around $10 from superCheapAuto. * A caulking gun * Thick rubber gardening gloves * A ratchet and/or spanner - 10mm * A philips-head screwdriver 1) You need to remove the trim that covers the rear inner of the boot. Use the philips-head screwdriver to unscrew and back the clips off, and then they just pop out by hand. Next, there are 5x 10mm nuts holding the tail-light assembly onto the body, which are accessible from the inside of the boot where you removed the trim. 2) There are also 4x 10mm nuts holding the Skyline panel on. On my car, it had to come off for the tail light to start moving out. As you can see, the tail-light has a little strip that sits behind the Skyline panel. You may need that spanner to get to the nuts on the right-hand side. I did, but that's also where my remote boot-release solanoid is. 3) With gentle, but firm pushing, the tail-light should start to come out without the aid of a hairdryer. I tried the hairdryer, but it made no difference. I pushed mainly on the threads that the nuts were on, using a small piece of wood so that I didn't puncture my hand. 4) Don't forget to unplug the wiring harness before you completely remove the tail-light assembly. It's just the one white plug. As you pull the assembly all the way out, take care that all that black sticky stuff doesn't get stretched like cheese on a pizza, as it will probably stick to your rear bar and be VERY difficult to remove. The old black sealant gets seperated between your tail-light and the body of the car. I don't know what a paid professional would do, but I took to removing ALL the old stuff. 5) 2 hours later, it's all gone. It took another hour to get it off my hands. I tried turps, metho, acetone... eventually I cracked the shytes and poured mower fuel over my hands. Instant dissolve! I now recommend the use of thick rubber gardening gloves instead of bare hands. Scrape a chunk of the sealant off, roll it into a ball, then dab and rip it off the remaining sealant. If you do it bit-by-bit, eventually the rest of it will follow. Don't experiment with solvents or anything like that on your paint. Ever. 6) The tail-light cleaned up nicely too. Check for any obvious cracks in it, as water could get in there, then out one of the breather holes in the rear of the assembly. Now is a good time to unscrew the globes and clean the contacts, and to blow a hairdryer into the sockets to get the water and moisture out. 7) This is where I ran the new stuff with the caulking gun. Notice I went around the top middle and bottom middle threads... The water from the boot gallery goes down over the top-middle thread, so I figured it's not a bad idea to divert the water away from this, as I think that's where some of the water was coming from. Additional to this, I put a TINY bit on each threaded rod, just incase water was getting in that way. When using the caulking gun, and the tube of sealant, I did it without the screw-on tip that comes with most tubes of stuff, simply because the tube itself gave a much thicker flow of sealant. One trip round the whole assembly at a slow pace did the job nicely. The new sealant is not as sticky or adhesive as the old stuff was, so I also used one finger to press it down to completely fill the little channel where it is supposed to go. This should tell you whether you have applied enough. 8) No picture... put the tail light back in firmly, then hand-screw the nuts back on, then slightly tighten each nut in a star-shape pattern until they are all evenly tight. (top-left, then bottom-right, top-middle, etc etc) Don't do one up completely tight, then the next, as you could snap or crack some plastic like that. Use the same principal as putting wheel-nuts back on, basically. Hopefully this has done the job... I think i'd have to dry the carpet first and then let it get wet to really tell if the leak is gone. I'll be smearing a light coat of silicon over that rusty seam on the inside of the boot... I couldn't see any sign of it on the outside. UPDATE: The tail-light is completely dry now, and it rained all last night. I beleive the problem is solved for me! DIY in response to this thread: http://www.skylinesaustralia.com/forums/in...20958&st=20 -------------------- Sydney RC Drifters My tutorials: Dash bulb info! (R33) Reseal bootlights (R33/generic) LED's in A/C unit. (R33/generic) Bought/Sold: ECR033, Campbell, Nismo Gtst, 99GTT, = SUPERMAN =, supraholic86, phat_r33, memph, Michael 1882, enilyks33r, skidkid, NiSmO`ChiCk, J34, mlt15e |
19 Jul 2006, 12:08 AM
![]() Team Trabant ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 5,458 Joined: 14th December, 2002 Car(s): broken Real Name: Chairman Kaga Trader Rating : 47 |
If you want to be pedantic, you can use Nissan OEM tail light / headlight butyl sealer
It's available cheap here (though it's from USA)... search by the part # on the boxes below... the Aus dealer cost is $$ ![]() ![]() -------------------- GTR - from the land of the rising credit card debt!
Successful traders: Maxx, BU5TER, DoughBoy, Roy, Croat, Dsturbd, Nismo32R, Boj01, TurboX, RowdyR32, JETR-32, ALL_GTR, rmahnovetsky, BATMBL, wrxkilla, CeffyNSW, meep, SydneyKid, nuR.spec, giant, Marko R1, Spoolup, cln, twisted, Tommyk, GTRgeoff, exXU1, Parker, femno, GTR090, rickhead, AlexCim, sullivan_a, CameronBNR32, gexenon, r33skyline, lang, nismo350z, tridentt150v, Scudboy, Cerbera, Hotwire, robbieraver, KLR32, jnr32r, NIZ-26T, tom_g, Simonster, MADGT4, darrrinspencer, sven, legend01 |
19 Jul 2006, 09:27 PM
![]() Rank: RB25DE ![]() ![]() ![]() ![]() Posts: 114 Joined: 28th October, 2004 Trader Rating : 0 |
heres the stuff you buy and how to cut the tip so it goes on nice and thick, also turps removes it trust me i have worked with this stuff lots of times
the stuff you need to buy from super cheap ![]() how to cut the nozzle ![]() |
26 Jul 2006, 02:05 AM
Thanks for the response with the turps and cutting tips. I didn't want to try turps or anything like that on my paint... I didn't know whether or not it'd be harmful.
According to car audio install places, "wax and grease" remover is what is used to remove the same sealant from your door-trims. I'll be giving that a try when I get time to sound-deaden my doors. ;o) -------------------- Sydney RC Drifters My tutorials: Dash bulb info! (R33) Reseal bootlights (R33/generic) LED's in A/C unit. (R33/generic) Bought/Sold: ECR033, Campbell, Nismo Gtst, 99GTT, = SUPERMAN =, supraholic86, phat_r33, memph, Michael 1882, enilyks33r, skidkid, NiSmO`ChiCk, J34, mlt15e |
15 Oct 2006, 05:29 PM
![]() SAUWA gimp ![]() Posts: 1,980 Joined: 20th August, 2005 From: WA, Perth, SOR Car(s): 1989 R32 Gts-t M spec Real Name: Jamie Trader Rating : 0 |
is it ok to use silicon or do you reccomend using the windscreen stuff ?
20 Oct 2006, 01:29 PM
![]() The Burninator ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 5,643 Joined: 5th June, 2002 From: Melbourne Car(s): 91 Harley & Dragon Wagon Real Name: Trogdor Trader Rating : 4 |
8 Nov 2006, 01:01 AM
#7
Rank: RB20DET ![]() ![]() ![]() Posts: 56 Joined: 18th June, 2006 Car(s): nissan skyline R33GTST Real Name: anthony mcgrath Trader Rating : 1 |
did this myself - worked a treat
8 Nov 2006, 02:36 AM
#8
yeh ive done it myself since posting, was easy and looks wayyy better
8 Nov 2006, 10:46 AM
#9
![]() aiight ![]() Posts: 17,186 Joined: 4th April, 2006 From: gympie Car(s): 99 magna Real Name: hugh jorgan Trader Rating : 8 |
did this on the weekend. my reverse light was half full of water.
i still have moisture in there cause i was too lazy to stand there with the hairdryer till it was all gone. but atleast now my boot doesn't leak. -------------------- Alright Stop!!1!ty... Hammer Time QUOTE Ivan says: some bitch is chasing me. im scared. shes calling my mates looking for me. do not want marc says: is it corinne? |
10 Nov 2006, 02:20 AM
#10
![]() Fringe Dwelling since 2003 ![]() ![]() Posts: 2,576 Joined: 15th October, 2003 From: Brisbane Car(s): R33 GTS-T + 05 R6 Real Name: Lee Trader Rating : 4 |
Nice DIY i might give this a try on the weekend
11 Nov 2006, 03:17 PM
#11
![]() Skys the limit ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 6,397 Joined: 15th September, 2004 From: the desert Car(s): r33, m3 Real Name: Joe Trader Rating : 26 |
the correct name for the windscreen stuff is urethane, automotive paint supply stores also stock it.
its top stuff.. we use it for almost everything. -------------------- ![]() All powder coating by Craved Coatings. The QUICKEST hiflowd vg30'd, auto, yellow, r33 gts-t in the WORLD! thanks to: Murnane Motors |
17 Sep 2008, 07:43 PM
#12
![]() VRRRRR WSSSSSSHHHHHH ![]() Posts: 369 Joined: 22nd October, 2006 From: Rosemeadow Car(s): R33 SII Real Name: Andrew Trader Rating : 14 |
brilliant topic! just what i was looking for when i only just discovered water was getting into my rear tail light as well!
-------------------- WINNER WINNER CHICKEN DINNER!!
i swear i do not have a gambling problem. |
Lo-Fi Version | Time is now: 5th December, 2008 - 07:13 AM |
