9 Jan 2004, 07:44 PM
![]() rb25 > rb20 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 23,199 Joined: 18th November, 2002 From: Goldcoast Real Name: Gordon Trader Rating : 36 |
Before you begin
============= Nothing worse than starting a job and not having everything you need onhand before you begin! So therefore you will definitely need: 1x Socket set (and ratchet), with 10mm and 12mm sockets (most are 10mm) 1x long socket extender - definitely recommended. Makes thing *much* easier in spots, increased leverage to get stubborn bolts undone as well. 1x stumpy philips head - for the tight spaces and general screws 1x long philips head - when you need to get to a screw with a long reach 1x flat head - mainly for helping to pop stuff out. 1x adjustable wrench - for stubborn nuts, etc 1x water! Before you begin tackling the main dash: Follow Pushead's guide to get the front facia off... here: http://www.skylinesaustralia.com/forums/sh...ead.php?t=31182 Then continue onto this one |
9 Jan 2004, 09:29 PM
Gearshift Surround
================ 1. Unscrew shiftknob, remove ashtray, and undo 2x screws behind. Rest is just clips. Unclip out: 2. Undo top facia screws. Lower scews connecting to centre console also need to be removed. |
9 Jan 2004, 09:33 PM
Stereo removal
============= 1. Undo top facia screws. Lower scews connecting to centre console also need to be removed. 2. Remove bottom four screws shown above to remove head unit. The whole bracket should slideout. Disconnect all connections to face unit. Fiddle with or replace stereo as necessary then move onto... Climate Control box ================ 1. Remove top 2x screws in last pic after stereo has been removed. Unplug 2x plugs on back to remove control box completely. mmmm...spaghetti! Its not quite as bad as it looks (really!) |
9 Jan 2004, 09:39 PM
Glovebox Removal
=============== 1. Remove glovebox assembly, undo red circled screws and unclip green circled clips. Trickiest one is the one bottom right, which you'll have to do with the glovebox open, and using a long philips head to get in there. 2. After that you'll have to kind of pop the clips out which attach to the upper part of the dashboard. I snapped one because its hard to do it without doing that but superglue will fix it. 3. You will need to undo the catch screws, as these also hold it in. 4. Carefully remove entire assembly and set aside. http://www.skylinesaustralia.com/forums/at...tachmentid=9901 |
9 Jan 2004, 09:43 PM
Below Steering wheel
================ 1. Remove the bonnet popper. 2x screws as shown in pic #1.. should drop down as shown. Don't worry, won't spring back - can still pop the bonnet if needed at any time like that. 2. Remove screws as shown in pic #2. Unclip from position shown, breaking clips in process 3. Remove screw on right for main dash (pic #3) |
9 Jan 2004, 09:50 PM
RHS footwell plastic
=============== This is just to your left leg. Remove screws as shown, and drop down, or just remove if you don't have turbo timers, etc attached A-pillar covers =========== 1. Drivers side is easy, as no handle to be unscrewed first. Unclip clips shown (pretty stubborn). May have to pop out the first bit of the quarter window plastic it sits under. 2. Remove a-pillar cover. Kind of sliding it out from where it meets the dash. 3. Do passenger side same, except you'll have to remove handle (2x screws under plastic caps). Use flat head to pop off caps. |
9 Jan 2004, 09:53 PM
#7
Top vents and Sun sensor
=================== 1. Use a flat head (as shown) to pop out the RHS vent 2. Reach out under the dash and popout the sun sensor. Disconnect it from its connector 3. This should make removal of the LHS vent easy. Which should now pop out. 4. Take random pick of surroundings (optional) |
9 Jan 2004, 10:01 PM
#8
Dash main
======== Ok, here comes the final removal of the dash. 1. Remove steering wheel (if not done already). Mine was nice and simple, good ol' momo! 2. Remove top two screwbolts. Best to use a socket extender at angle into sunsensor hole, and corresponding hole on RHS. 3. Remove screws from bottom RHS and bottom LHS of dash, if not already 4. Remove centre nut (just above steering wheel) You may also have to slip your car into 4th gear or so to get the gearshift out of the way to help you get the dash structure out. This is it for the disassembly! Now to get that big chunk of plastic out... 5. Slowly remove entire dash by pulling forward, checking for any screws still holding it in that may have been left. 6. Angle up and I think its easiest to manuveur whole dash through passenger side. I managed to lift it out by myself without damage, but a helping hand could make it much easier. It weights about 8kg. 7. Stare in wonder with what lies beneath (last photo) |
9 Jan 2004, 10:04 PM
#9
So that is pretty much it!
Reassembly is a reversal of the above process (i've always wanted to say that Removing the full dash will allow you to get at a few useful things: main fan, airconditioning cooler, heater (and heater radiator) and the loom that goes through to the engine. |
9 Jan 2004, 10:22 PM
#10
![]() Rank: RB30E ![]() ![]() ![]() ![]() ![]() ![]() Posts: 2,870 Joined: 21st April, 2002 From: Canberra Trader Rating : 40 |
Holly crap !! that picture of the dash off looks scary !!
Well done on the DIY write up One thing, did you do this up at the park? Looks like it J |
9 Jan 2004, 10:39 PM
#11
![]() Expert Monkey Bike Stunt Rider! ![]() ![]() ![]() ![]() ![]() Posts: 1,221 Joined: 9th May, 2003 From: Sunny Lynbrook Car(s): R33 4dr Navara '49 Riley Real Name: Danny Trader Rating : 0 |
Nice thread this will get stickied. More people should take the time to do this! Well done. I always carry out complex repairs and wish i had got snap happy in the process!! however the how to install remote start paging alarms with boot release central locking , window roll up, sunroof closure etc etc would take way too long and give me nothing to do as a result!!! Keep up the good work!
9 Jan 2004, 11:06 PM
#12
![]() The 'ians ![]() ![]() ![]() ![]() ![]() Posts: 1,914 Joined: 25th July, 2003 From: melbourne Car(s): R33 SII GTS-T, 510 Z18-T Trader Rating : 5 |
good work!
10 Jan 2004, 07:47 PM
#13
Jay95R33: it looks worse than it is in the photo, plugs going everywhere - but generally a plug will only fit the one socket so its hard to get it mixed up putting all back together.
Autotrust: lol - i guess if you do it all the time like you it becomes 2nd nature. Still, there will always be a market for people to get others to do this sort of thing. I mean it takes hours, and unless you're really keen - who really does want to pull apart their car. |
10 Jan 2004, 10:07 PM
#14
![]() Rank: RB25DET ![]() ![]() ![]() ![]() ![]() Posts: 758 Joined: 30th May, 2003 From: Qld Car(s): Silvia Trader Rating : 1 |
great guide. i took apart mine completely in about 1.5hrs.
but then again, i didn't have to worry about trying to put it together again |
10 Jan 2004, 10:54 PM
#15
Rank: RB25DE ![]() ![]() ![]() ![]() Posts: 301 Joined: 18th March, 2003 Trader Rating : 1 |
sweet as dude. great guide.
