14 Sep 2006, 10:46 PM
![]() RB25DET Neo ![]() ![]() ![]() ![]() Posts: 365 Joined: 28th December, 2005 From: Gympie Car(s): 1 mellow yellow S2 Real Name: Wazza Trader Rating : 1 |
I had a problem with the rear passenger door glass hitting the hard rubber surround along the top edge whenever I shut the door with the window up.
This would always cause an air leak sound even at low speeds. So I had to lower then raise the window everytime the door was opened. Stagea, in their infinite wisdom, put in adjustment screws to help with this problem and the following was my attempt to fix the glass level. Screwdriver shows where to prize off the door handle plastic surround - On the top front edge. Picture of the back of the plastic surround shows the single clip. Underneath is the mounting screw for the panel. 10mm socket works easier than the phillips screwdriver. The rest of the panel comes off by simply pulling around the edges to release the clips. A short, sharp yank with your finger tips is all that is required. See pictue below for where the mounting holes are situated. Be sure to disconnect the electrics - a small screwdriver is needed to release clip, then slide out. All off and admiring the view. Plastic weather protection will need to be removed along the top edge to get at the level adjustors. Pull gently on the plastic without stretching it out of shape and it will stick back into place. If you look carefully, you'll be able to see the holes where the plastic mounting clips go - so you'll know where to pull on the door trim. Check out the quality of those speakers - the factory must have spent a whole $5 on those babies! And $1 on the foam. This picture shows the level adjustors with increments. You can see by the worn ring mark in the paint where it used to be and how far I had to drop the glass. There are two adjustors - one for the front edge and one for the rear. I only needed to adjust the rear to fix my problem. This picture shows the little cloth pads that the glass runs against when moving up and down. They can also be adjusted to change the angle of the glass on the 'in and out' plane - if that makes any sense. I believe they need to be left with a reasonable amount of play in them as the window changes angle as if feeds up and down. Keep these clean or you will scratch the glass. The best position to have the glass is where it will just pop under the edge of the hard plastic surround on the body without getting caught on it. I hope this help you enjoy noiseless motoring and to avoid breaking something unnecessarily. Happy tinkering, Warren |
14 Sep 2006, 10:51 PM
All good now!
15 Sep 2006, 08:27 AM
![]() Driver of The Terrifyingly Terrible Trajet of Tangible Tawdrynes ![]() Posts: 22,492 Joined: 26th November, 2003 From: Rockhampton, QLD. Car(s): Bogan-mobile Real Name: Cyrus Trader Rating : 11 |
Beatuful, GREAT writeup! This might get lost in the Stagea section, so you might want to think about having it moved to the DIY section, either way, I am putting a link to it in the "Mega Stagea Link" thread
Again very nice writeup! Thanks! -------------------- |
15 Sep 2006, 09:34 AM
![]() Rank: RB30ET ![]() Posts: 5,292 Joined: 6th April, 2005 From: Adelaide Car(s): Nissan Stagea RS-Four V Trader Rating : 12 |
Thanks mate - got to do that to my front passenger window too, has a leak at 100kmph+ once door is opened and window wound down then up again.
cheers ! -------------------- ![]() |
15 Sep 2006, 10:30 AM
![]() Rank: RB25DE ![]() ![]() ![]() ![]() Posts: 356 Joined: 12th December, 2005 From: Tassie Car(s): '98 RS-4 Stagea Real Name: Jason Trader Rating : 5 |
Sweet, thought our car was the only one that did this, passenger rear leaks, and passenger front has a bit of a whistle over about 90k's. Looks like I've found a job for Jason on the weekend, thanks Warren
17 Sep 2006, 11:44 AM
All my windows are OK up to the speed limiter, but i did notice all the adjustments when doing the stereo istall
STAGEA LOVE! -------------------- |
4 Oct 2007, 07:35 PM
#7
Autech 260Rs ![]() Posts: 1,354 Joined: 4th April, 2006 From: Central Vic Car(s): 260Rs, Landcruiser 100 Real Name: Yudy Trader Rating : 0 |
i did it the other day but i cant remove the damn plugs to the power controls. How did you unplug it? the side morrow adjuster can be unplugeed easy but not the power window one. Lemme know. thanks
Yudy -------------------- - 236.5kw@4wheels tuned by Racepace.
Mods : -Power Fc w/ hand commander. -Factory boost controller @ 1 bar. -Aerospeed Cam gears In/Ex. -Full 3" Front pipe (Hks competition), Nismo cat back exhaust. - High flow BeeR Cat. - Drop in replacement filter by K&N. - Dolphin R speedo. (300km/h limited) - Hid head lights. - Tein HA Coilovers. Oz valving. Spring rates F:9kg/mm R:8kg/mm, Tein adjustable Castor Rods. Nismo Front upper and lower Arms, Rear adjustable Upper Camber arms. |
5 Nov 2007, 06:30 PM
#8
All the electrical plugs use the same locking system. You need to push in the little clip on the side. Use a screwdriver are similar. It can be a prick of a job as you need two hands to unplug it and two hands to hold the door fab.
6 Nov 2007, 08:37 AM
#9
![]() Rank: RB30E ![]() ![]() ![]() ![]() ![]() ![]() Posts: 3,679 Joined: 16th March, 2007 Car(s): 2000 Stagea Real Name: Sean Lucas Trader Rating : 0 |
yes thanks very much for taking the time and effort to write that up !
very informative.. not that I have a use for it now.. but in the future I might! |
29 Nov 2008, 03:11 PM
#10
![]() Rank: RB25DET ![]() ![]() ![]() ![]() ![]() Posts: 648 Joined: 21st October, 2006 From: SA Car(s): S2 Stagea, S2 Bluebird Real Name: Dave Trader Rating : 1 Garage: Stagea Series 2 |
i did it the other day but i cant remove the damn plugs to the power controls. How did you unplug it? the side morrow adjuster can be unplugeed easy but not the power window one. Lemme know. thanks Yudy Having this same problem, driver's side front on S2... power controls plug (the big one) doesn't matter how far the locking tab is depressed, it's stuck like glue. Yet I know it's not glued 'cause I plugged it in myself not 4 months ago. |
Lo-Fi Version | Time is now: 5th December, 2008 - 05:35 AM |
