IPB
2 Pages V   1 2 >
> Rb25 Turbo And Cam Gear Results, definately a worthy modification!
WazR32GTSt
post 29 Apr 2006, 11:20 AM
Post #1
V35 coupe
Car(s): V35 350GT premium
Real Name: Warren
Trader Rating : 18
after a dormant year of mods, have finally done something extra to the ol rb20..
car:
1992 R32 GTSt automatic with 140,000kms
previous mods:
- 3" dump/front
- 2.5" gutted cat
- 3" cat-back
- boost controller 12psi (made same power at 14psi)
- high-flow air filter in stock airbox
- rb26 cams
- some kind of chipped ecu, not sure exactly what has been changed
- FMIC with custom piping
- auto tans cooler
This setup made 132rwkw with 14psi and fairly advanced timing... keep in mind this is an automatic car
new mods:
- rb25 turbo (series 2 with nylon compressor)
- HKS cam gears: inlet and exhaust
- walbro fuel pump
- 3" high-flow cat (note: went from gutted cat to normal cat, so this would have actually robbed some power...)
the narrative:
For the new mods, i Visited the great team at Mercury Motorsport in Newmarket, Brisbane for the installation and tune. They installed the rb25 turbo
and cam gers, and set them at 0 and 0.
The first dyno run was in this state and made 133rwkw with 11psi but was leaning out with AFRs approaching 14. this is when the fuel pump went in...
The next dyno runs were to adust the cam gears and turn the boost up. ended up having 14psi with normal timing and made 154.8rwkw (see attached dyno sheet)
In its final state, the cam gears were set at:
inlet --> +3
exhaust --> -5
as you can see by the dyno graphs, it made a huge improvement than over the standard confiuration. I asked them to set it up for low-to-mid improvement rather than top-end power, which they did.
How it feels to drive:
Down low, is exactly as before with no noticable difference in lag at all. I was quite surprised actually and i put it down to the cam gears bringing boost on earlier and the added mid-range torque.
Up top, it pulls very hard compared to before, and all the way to redline smile.gif
overall summary:
1. making 155rwkw with rb20 automatic
2. very happy with the way the car drives and the increase in power
3. recommend cam gears to anyone that is thinking of this as a future modification
Am open to any advice, comments, or suggestions that anyone might have smile.gif
cheers,
Warren
NEW:
V35 specific section of the forums:
http://www.skylinesaustralia.com/forums/in...p?showforum=170
Profile CardPM
Go to the top of the page
+Quote Post
Googlebot
Post #
Trader Rating :
> Google Ads
Quote Post
WazR32GTSt
post 29 Apr 2006, 11:23 AM
Post #2
V35 coupe
Real Name: Warren
Trader Rating : 18
Picture of the dyno graph is attached
red line = rb25 turbo, 11psi, stock fuel pump
blue line = as above, but with walbro fuel pump / 13psi / gears adjusted
Attached thumbnail(s)
NEW:
Profile CardPM
+Quote Post
paulr33
post 29 Apr 2006, 11:39 AM
Post #3
SAU VIC Member 0064
Group Icon
Group Icon
Group Icon
Group Icon
Car(s): 1997 R33 GTS25TML
Real Name: Paul
Trader Rating : 1
well done warren, good to see you've made some good progress. thanks for offering the info for other to see as well, which is always helpful for other members. good stuff cheers.gif
i am no longer accepting pm's any more - i've had enough
if you want to know something about the powerfc search in the faq
if its not in there i dont know the answer
-> Apexi PowerFC FAQ has been updated (April 08) - ChangeLog
Profile CardPM
+Quote Post
bbe
post 29 Apr 2006, 01:21 PM
Post #4
Trader Rating : 1
hmm did u do a run with the pump 25 and boost set at 14 ? then do another run just with the adjustment only of cam gears ?
cos i have heard many people say gears on the rb20 are a waste of time im just asking not implying
TOOLBAGS
Profile CardPM
+Quote Post
fEkuaR
post 29 Apr 2006, 02:12 PM
Post #5
Car(s): R33 GTS-T :D!!!
Real Name: Dan
Trader Rating : 0
He also has rb26 cams however so this is going to be a manjor factor aswell ...
Profile CardPM
+Quote Post
predator
post 29 Apr 2006, 02:50 PM
Post #6
rb25 > rb20
Group Icon
Real Name: Gordon
Trader Rating : 36
is it laggy? i know mine so slow up to around 4000..then it was all on..
QUOTE
drag strip son..
Profile CardPM
+Quote Post
WazR32GTSt
post 29 Apr 2006, 04:44 PM
Post #7
V35 coupe
Real Name: Warren
Trader Rating : 18
QUOTE(bbe @ 29 Apr 2006, 01:21 PM) *
i wasn't there for the tuning, as i had uni to go to
they did, however do that. that's why the cam gears are set up as they are, because it made an improvement. otherwise they would be left at zero
you'll see when i can get the graph up, its like the graph has been shifted left. i think this was the gears smile.gif
the mechanic actually said that they came out really good and was very happy with the upgrades i had chosen. he said they worked well together..
NEW:
Profile CardPM
+Quote Post
WazR32GTSt
post 29 Apr 2006, 04:49 PM
Post #8
V35 coupe
Real Name: Warren
Trader Rating : 18
QUOTE(predator @ 29 Apr 2006, 02:50 PM) *
drag strip son..
is it laggy?
i can't feel any loss in low-rpm power. not that it had much to begin with, though
definately has power up to 4000rpm.. haven't done a big tester yet so can't say where i hit full boost etc.
actually, on the rb20 turbo, it felt as though it would spool up early, but still wouldn't get moving until it had reached full boost
now, it is ever so fractionally later in spooling, but gets moving as the boost rises so it actually feels the same, if not better in the low-to-mid region
yeah, drag strip will be on the cards. a mid-14 should be achievable i think/i hope.
NEW:
Profile CardPM
+Quote Post
WazR32GTSt
post 29 Apr 2006, 05:11 PM
Post #9
V35 coupe
Real Name: Warren
Trader Rating : 18
graph has been uploaded finally!
not that this was done in 2nd gear as it is an automaticand that the intake temp is close to air temp which means the results are realistic
(i find that the more the intake temp is above the air temp, the higher the dyno figure is, with about 1deg = 1rwkw)
NEW:
Profile CardPM
+Quote Post
dangerous_daveo
post 29 Apr 2006, 06:14 PM
Post #10
CA31
Car(s): 88 Cefiro & 08 Jetta
Trader Rating : 1
First thing, you need to get the ECU re-tuned. I think it will seriously make another improvement, and be well worth the money. That or get another chip that can be tuned. Whatever, just do it.
Reason for saying that. My graph is very very similar to yours (same power as well), just I dont have cams, or an RB25 turbo, or a FMIC. I think with some more tuning, that will be a very smartly modded car, with very good power for the mods.
Either way, thats a pretty good gain for a fairly low outset of money. Just do something with the ECU.
Four Doors For Life!
Sedans for Style!
'08 VW Jetta 2.0 TSI
'88 Nissan Cefiro Factory manual turbo, FOR SALE, $14k, RB25 Gearbox, SK suspension, many other mods, PM me if you want it. Its gotta go!
Profile CardPM
+Quote Post
ellie
post 30 Apr 2006, 10:59 AM
Post #11
Car(s): R32 gts-t
Real Name: Secret Squirrel
Trader Rating : 0
What I want to know is = there was a huge thread on fitting RB26 cams in an RB20 with no success, many breakages, cars would only stall for the very few that got them in and with the eventual revelation that you also needed to convert your entire valvetrain to a solid lifter setup! So my question is with now seeing a few people successfully running this setup, how did you get it to work and how did it run?
Cheers in advance!
JDM disciple
Profile CardPM
+Quote Post
WazR32GTSt
post 30 Apr 2006, 12:11 PM
Post #12
V35 coupe
Real Name: Warren
Trader Rating : 18
i didn't do them myself, had them put in by my mechanic. so i don't know how they went in exactly
this thread is about the cam gears and rb25 turbo, so can we keep it on topic? there's already 3 or 4 threads about rb26 cams in rb20
thanks in advance
NEW:
Profile CardPM
+Quote Post
xRHETTx
post 2 May 2006, 11:46 AM
Post #13
Vic Member #045
Group Icon
Car(s): R32 GTSt Type-M
Real Name: Rhett
Trader Rating : 4
Awesome result.. Its still running really rich down low though, so ECU upgrade or ROM burn etc would be the logical next choice?
Living the high life - thread bumpin', post whorin'...
Dyno junkie - 155.1 rwkW! Mods - pod filter, 3" split dump, 5" metal cat, 3" catback and R34 GTT smic - now with GTR fuel pump.
Profile CardPM
+Quote Post
GTST
post 2 May 2006, 12:09 PM
Post #14
Rank: RB30E
Trader Rating : 6
man the A:F before the pump were getting kinda too lean..
now if you got ECU chipped, the part from 75km onwards would gain power if it came back up to 12:1 as well.
Profile CardPM
+Quote Post
WazR32GTSt
post 2 May 2006, 12:38 PM
Post #15
V35 coupe
Real Name: Warren
Trader Rating : 18
yeah i wanted to hold off on the pump due to $$ issues, but when they called me saying the AFRs were 13:1 i said go for it..
i might have to wait for the next QLD visit by Dr Drift...
i'd prefer this to an SAFC which is really my other choice being an automatic
what does everyone think?
NEW:
Profile CardPM
