24 Jan 2006, 10:56 PM
![]() Rank: RB25DET ![]() ![]() ![]() ![]() ![]() Posts: 1,268 Joined: 17th February, 2004 Trader Rating : 2 |
hey guys thinking of putting a 25 box in the ceff
ok i know i will need a 25 box + tailshaft, is there anything else i need? i know i will also need to modify the tailshaft to fit and i have heard a couple of ideas about 'bearbox' crossmember???? can be slightly modified to suit (whatever this is) and SLAVE CYLINDER????? also not bothered about speedo HELP -------------------- FULL TUNE |
25 Jan 2006, 03:02 AM
Rank: RB20DET ![]() ![]() ![]() Posts: 40 Joined: 16th November, 2005 Car(s): Cefiro Real Name: Roger Rodriguez Trader Rating : 0 |
I would also like to know if the rb25det gear box would bolt up to the rb20e engine
25 Jan 2006, 08:11 AM
![]() Rank: RB30E ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 2,217 Joined: 5th June, 2002 Car(s): S13 Track - VY Daily Real Name: Ando Trader Rating : 5 |
Okay once again from the very VERY limited knowledge i have it is all a pretty easy swap but i think the 'yoke' needs to be shortened??????!!!
Good source of knowledge for conversions to Cefiro's is this site d1nz.org.nz/forum Since the Kiwi's get the cheaper RB20e auto versions 90% of the time they all are conveting them! My useless 2c ahaha Ando -------------------- S13 Nugget
25 Jan 2006, 11:18 AM
Rank: RB20DET ![]() ![]() ![]() Posts: 53 Joined: 17th November, 2005 From: on ur screen Car(s): Cefiro A31 Real Name: Lanun Trader Rating : 0 |
For front tail shaft from A31 to be shorten & change the yoke to R33 due spline shaft re bigger than A31.
The Rear tail shaft exacly from A31 but the rear coupling change A31. |
25 Jan 2006, 11:25 AM
For Gearbox crossmember : From R32 re totally different with A31 but R33 re same with A31.
In my case, I'm using R33 meter so the electronic spedo can be use |
25 Jan 2006, 11:53 AM
![]() name = cc ![]() Posts: 3,842 Joined: 8th May, 2003 Trader Rating : 4 |
When you get it done can you please do a short document or post it up here and I'll publish it on cefiroz?
Seems to be a common question. -------------------- Team I need $
25 Jan 2006, 12:57 PM
#7
no worries
also from my calls today - the 33 yoke is needed and keep the ceffy tailshaft - just needs to be modified also all the gear selector etc is interchangable from what i've been told can also use rb20 gearbox crossmember possibly need the transtunnel 'massaged' a little wider... -------------------- FULL TUNE |
25 Jan 2006, 06:11 PM
#8
![]() CA31 ![]() ![]() ![]() ![]() ![]() ![]() Posts: 4,373 Joined: 1st July, 2003 From: Brisbane Car(s): 88 Cefiro & 08 Jetta Trader Rating : 1 |
Ok I've had it done.
Transtunnel is fine. Dont need to touch it. Obviously clutch, fly wheel etc all the same. You will need an R33 clutch slave, I got mine new from nissan for $88.00. Yes you need the R33 yoke, then you need the cef tailshaft, the idea would be to shorten this. However if your center bearing is stuffed like mine, then you might want to look at getting a 1 peice shaft as this is cheaper than replacing the center bearing apparently (lighter also, so you get back some of that extra weight of the gearbox + less rotating mass) Rb20 cross member is fine, we just moved mine and put some spacers in. You might need an engineer to look at this to make sure its legal. Mine is actually mod plated. The speedo... You need your red gear off the R33 speedo sender (the one that goes in the gearbox) this then needs to be attached to a navara speedo drive (32702 - 02G17 pinnion assembly), should be about $22-25 new from nissan, this then connects up to your speedo cable like normal. Just test it tho, should be pretty accurate. Get some of the seals replaced on the box if they need it. You REALLY dont want oil leaking on to your clutch. Get your fly wheel/pressure plate/clutch all checked out while the box is out. I had to replace mine that was a cost I didnt allow for. And why does the gear selector matter? Wouldnt your RB25 box come with one? I dont belive we used my RB20 one. But yeah, once its done your more afraid your crank is going to snap in your poor little rb20 than your gearbox -------------------- Four Doors For Life!
Sedans for Style! '08 VW Jetta 2.0 TSI '88 Nissan Cefiro Factory manual turbo, FOR SALE, $14k, RB25 Gearbox, SK suspension, many other mods, PM me if you want it. Its gotta go! |
25 Jan 2006, 07:13 PM
#9
![]() A31 Love ![]() ![]() ![]() ![]() Posts: 229 Joined: 30th June, 2005 Trader Rating : 0 |
AWSOME Article DD... this needs to be stickyed in the parts list of these forums...
shame u didnt type it out when i needed it 4mths ago -------------------- Softy......Its NOT a Sexual Thang!!!
WWW.KANSAIAUTOMOTIVE.COM |
25 Jan 2006, 11:32 PM
#10
thats exactly info i needed thanks heaps DD
gearbox i'm getting has got yoke etc - clutch was just fitted recently also . now the hunt is on for a r33 clutch slave and if its that cheap to get speedo working i'll do that aswell whats it look like? and where? thanks again - awesome info -------------------- FULL TUNE |
25 Jan 2006, 11:55 PM
#11
go B/NEW on slave
ill msn further -------------------- Softy......Its NOT a Sexual Thang!!!
26 Jan 2006, 09:04 AM
#12
Yeah dude, just go down to nissan and get the slave $88 cant go wrong.
OOOH!!! BIG BIG BIG ONE!!! You MUST get an S1 gearbox. If you get an S2 your going to have a LOT of stuffing about. The clutches are different (ie one pull ther other push) -------------------- Four Doors For Life!
26 Jan 2006, 09:05 AM
#13
QUOTE(Softy @ 25 Jan 2006, 07:13 PM) AWSOME Article DD... this needs to be stickyed in the parts list of these forums... shame u didnt type it out when i needed it 4mths ago Hehe, dude thats prob when mine was getting done -------------------- Four Doors For Life!
26 Jan 2006, 04:37 PM
#14
hmmm shit well unsure which one i just got - but got a 25 box of some sort now :S
26 Jan 2006, 05:12 PM
#15
Rank: RB25DE ![]() ![]() ![]() ![]() Posts: 188 Joined: 3rd September, 2005 From: new zealand Car(s): r33 skyline Real Name: Geoff Trader Rating : 0 |
hey, im doing the opposit of you guys in a way. im putting a r32 rb20det in to my rb20e powerd r33. i have the electric speedo. what i have been told is that i need the r32 gtst drive gear. what does it look like and where does it go?
cheers -------------------- my car at 2hot2handle(silver one) http://homepages.ihug.co.nz/~bushtim/DSC00132.JPG
RB30 power!!! 15.2 at 93mph |
26 Jan 2006, 07:23 PM
#16
LUCKILY i got an early model box with push type clutch
