| Guest_TR34GT_* |
9 Apr 2008, 09:07 PM
Trader Rating : |
Hi SAU members.
As promised, my son and I now post the pictures and instructions for the DIY induction box, which is now finished, installed, and working like a treat. The best thing about this exercise, was that the whole deal cost just $40. (with a few bits lying around too) The car had an HKS Superflow pod filter, which we were trying to make legal. The steps we took were as follows: 1. Buy a pices of 2mm thick cardboard from the paper shop.......around 400mm x 600mm - $2.00 2. Cut to the approximate shape to house the filter (car specific fit) using the existing GTT mounting points and trial fit until you get the approximate correct fit. The dimensioned template we made is shown in the attached pictures. 3. Buy a 900mm x 250mm x 2mm think peice of scrap aluminium polished sheet - $20 4. Mark out your template on half of the aluminum sheet and cut out with a jigsaw 5. Mark out the approximate fold lines on the aluminium 6. Fold by hand across the fold lines in the directions with a gentle constant pressure across a rolled flat edge 7. Drill 5mm dia holes in each of the end lugs 8. Trial fit a million times to get it right, and keep filing, cutting and massaging until you get the thing to fit perfectly. 9. Cut out two 80mm x 30mm peices, and round edges to for the top fixing mounts, bend at 90 degrees, after drilling two x 5mm holes in each lug side (see photos) 10. Fit top fixing mounts to side as shown using 2 x 5mm x 25mm high tensile steel hex bolts, washers and nuts. 11. Install your new heatshield using the existing mounting bolt and one new 25mm x 5mm dia high tensile steel bolt (see pictures) - $6 12. Cut shape of top out of same cardboard and trial fit so that it does not touch any of the chassis edges of the engine bay. 13. Cut out the top out of the other half of the aluminum using your template. 14. Mark out exact drilling points through top, to match fixing points and position in engine bay. 15. Trial fit another million times until its just right. 16. Remove all, and hang by lugs in a fairly dust free sterile environment (sure, we used the garage) 17. Spray Knights grey primer on all areas (touch dry in 15 minutes) - $7 18. Spray Knights engine enamal (gloss black etc) covering all areas till desired effect is achieved. - $7 19. Leave for at least one hour 20. Fit and glue on a rubber / foam edging across the bottom. 21. Fit all as shown, and dress with whatever vinyls you want (Mines in this case) The project took a full day. The installation is solid, with no vibrations or noise, and I think its now made that pod filter legal. (At least we hope so) Anyone wanting any help, or any additional information, just email me. Regards TR34GT (Jim) |
9 Apr 2008, 10:03 PM
![]() Rank: RB25DET ![]() ![]() ![]() ![]() ![]() ![]() Posts: 1,681 Joined: 22nd November, 2007 From: The West of the East. Car(s): lOo _R34_oOl Real Name: Shanil Trader Rating : 4 Garage: Skyline GT25 |
mate this is awesome.
well done and thanks. -------------------- Want to join SAU NSW? CLICK HERE!
Looking to buy a P-plater friendly car that looks the goods for a reasonable price? Buy my car! 1998 R34 GT25 and SAU Advertisement Haha. No way. In person these boys haven't got the balls to say the shit they post on here. 'Keyboard Warrior Syndrome' or KWS is what it's called. ;) |
10 Apr 2008, 01:48 AM
![]() Rank: RB30E ![]() ![]() ![]() ![]() ![]() ![]() Posts: 3,698 Joined: 15th September, 2006 From: melb Car(s): mcr r34 gtt Trader Rating : 22 |
very nice! i'll have a go at this myself.
do you have larger versions of the pics? more importantly pics of the measurements as they're too small thanks |
10 Apr 2008, 09:47 AM
Rank: RB20DET ![]() ![]() ![]() Posts: 32 Joined: 31st March, 2008 Real Name: Angelo Trader Rating : 0 |
very nice job man, looks heaps pro.. Just a quick question. With the stock snorkel gone, where is the heatshield pulling air from? I know its pretty tight on the underside of the filter esp. with the stock cooler piping there, did you route a CAI into the guard too?
Also, did u notice a difference? is it quieter? more power? |
| Guest_TR34GT_* |
10 Apr 2008, 10:43 AM
Trader Rating : |
very nice! i'll have a go at this myself. do you have larger versions of the pics? more importantly pics of the measurements as they're too small thanks R-Spec, Many thanks. If you open up each pic in your browser and in the bottom right hand corner, increase the magnification to 200%, the pics should be ok. One thing I didn't mention is that at the chasis mounting points, I used a 4mm thick x 6mm dia reinforced rubber fuel injection hose between two washers, around the 5mm bolts, as anti vibration mounts. Don't forget those. I hope all works out. Remember to trial fit 500 times and the result should be good. Regards Jim |
| Guest_TR34GT_* |
10 Apr 2008, 10:50 AM
Trader Rating : |
very nice job man, looks heaps pro.. Just a quick question. With the stock snorkel gone, where is the heatshield pulling air from? I know its pretty tight on the underside of the filter esp. with the stock cooler piping there, did you route a CAI into the guard too? Also, did u notice a difference? is it quieter? more power? Angelo, On the GTT, there is a direct opening below the pod filter position which leads straight to the left hand grill openings in the front bumper and behind the the bumper. No air piping needed. (I hope) The noise from the pod filter was not reduced, however, if you were to also line the box with some sound deadening material on the inside, you might just quieten the ride. As far as more power, there doesn't seem to be a difference, however, I'll try and route some 3" flex tubing directly to the pod, and see what happens. I'll let you know. Regards Jim |
6 May 2008, 06:02 PM
#7
Rank: RB20DE ![]() ![]() Posts: 21 Joined: 16th March, 2008 Car(s): r34 wrx Real Name: rob Trader Rating : 0 |
I lined my carbon airbox with sound deadiner and found it no quieter.
19 May 2008, 02:37 AM
#8
![]() SAU VIC Member #83 ![]() Posts: 4,876 Joined: 21st August, 2002 From: Melbourne Car(s): Nissan Skyline R34 GT-T Real Name: Daniel Trader Rating : 2 |
for vic peeps, if you're running a FMIC, even having a boxed pod is illegal yeah?
19 May 2008, 10:20 PM
#9
![]() I was a Pizza Boy, now a Plastic Boy ![]() Posts: 1,329 Joined: 5th December, 2005 From: Gosnells Car(s): R32, Swift GTI, 180sx Real Name: Gordon Trader Rating : 3 |
where would ya get a aluminum sheet from and you can seriously cut it with a jig saw wow
19 May 2008, 10:36 PM
#10
![]() Rank: RB30ET ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 6,383 Joined: 5th August, 2006 From: SE Melb Car(s): ECR33 Real Name: Niroj Trader Rating : 32 Garage: R33 GTST-t |
for vic peeps, if you're running a FMIC, even having a boxed pod is illegal yeah? correctamundo -------------------- |
21 May 2008, 04:28 PM
#11
![]() Rank: RB20DET ![]() Posts: 91 Joined: 23rd February, 2008 From: Vic Car(s): 1998 R34 GT-T Real Name: Mike Trader Rating : 0 |
Sweet final product! Love the black gloss and Mines Vinyl!
Lo-Fi Version | Time is now: 20th March, 2010 - 06:28 PM |
