9 Nov 2006, 12:24 AM
![]() Rank: RB25DET ![]() ![]() ![]() ![]() ![]() Posts: 934 Joined: 2nd October, 2005 From: Sydney - NSW Car(s): R33 Series II RB25DET Trader Rating : 6 |
Hey Guys, thought to share this with you... i just installed an R34 GTT SMIC onto my R33 GTST and boosted to 10psi + ECU Reset
Current Mods: 3" Split dump + 5" S/Steel CAT + 3" CAT back exhaust + Turbotech Results: Car comes onto boost MUCH smoother & revs to redline MUCH easier.. there has been a HUGE increase in pull through out the rev range especially in 1st and 2nd gear... Dyno would be nice, any one offering a free dyno pass? lol Recommendation: Definitely worth the upgrade if you have stock turbo... Proior to this upgrade, the car felt held back and restricted, now the car feels much freer and has noticably unleashed more power... Throws you right back in the seat Note: Prior to the SMIC installation, i flushed it with degreaser/hot soapy water and i couldn't believe the amount of black crap that came out! had to reflush about 4 times before it was 100% clean... then ran warm water though to get rid of the soap/chemical residue... i then stuck an old hair dryer in one end and let it sit there for 30min untill it was drip dry.. worked a treat! Look at the size difference between R33 SMIC Vs R34 SMIC! Here is a couple short videos while driving home tonight, its just to show the smoothness of boost and ease of rev... (excuse the bad footage due to holding my phone while recording and driving) Hope you like!
video_0004.mpg ( 510.12K )
video_0003.mpg ( 939.3K )
Number of downloads: 344Regards, Sarkis |
9 Nov 2006, 06:54 AM
![]() Why isn't anyone clicking? =-[ ![]() ![]() ![]() ![]() ![]() Posts: 1,911 Joined: 7th May, 2003 From: NSW - Northern Beaches Car(s): R33 GTST Series 2 Real Name: Steve Trader Rating : 7 |
OH good work! I've already put the 34GTT cooler in, and the turbotech controller... Got all the exhaust parts, but haven't fitted them.
When that's done, i'll shove it up to 10psi... same as you have. Hopefully it'll feel the same! Can't play vids though =-/ -------------------- Sydney RC Drifters My tutorials: Dash bulb info! (R33) Reseal bootlights (R33/generic) LED's in A/C unit. (R33/generic) Bought/Sold: ECR033, Campbell, Nismo Gtst, 99GTT, = SUPERMAN =, supraholic86, phat_r33, memph, Michael 1882, enilyks33r, skidkid, NiSmO`ChiCk, J34, mlt15e |
9 Nov 2006, 07:27 AM
Rank: RB26DE ![]() ![]() ![]() Posts: 15,283 Joined: 20th June, 2002 Trader Rating : 10 |
Vids don't work. :S
9 Nov 2006, 08:05 AM
Does this ^ make my ass look big? ![]() ![]() ![]() ![]() ![]() ![]() Posts: 4,457 Joined: 30th May, 2006 From: Sydney Car(s): R33 GTST Real Name: Tony Trader Rating : 15 |
video no workie
-------------------- nuffin'
9 Nov 2006, 08:11 AM
Rank: RB25DE ![]() ![]() ![]() ![]() Posts: 101 Joined: 21st August, 2006 From: Sydney Car(s): 94 R33 gts-t Real Name: David Trader Rating : 2 |
vid workie for me
9 Nov 2006, 08:29 AM
#7
![]() Rank: RB25DET ![]() ![]() ![]() ![]() ![]() Posts: 578 Joined: 21st April, 2006 Car(s): R33 GTS25T Trader Rating : 1 |
I wonder if a change from a R34 SMIC on a GTT to a FMIC will show the same benefits No, you will not mate the R33 and R34 turbos are much the same except for a slightly larger exhaust housing on the R34. So unless you upgrading your turbo keep the stock GTT cooler. Its a good unit and you wont loose any throttle response to that of a large frontmount. always good to see these cheep mods work. cheers -------------------- |
9 Nov 2006, 08:51 AM
#9
Dav,
How you get vid worky? Mine comes up with quicktime and then fails and drops a question mark in it. I'd assume something to do with codec. |
9 Nov 2006, 09:12 AM
#10
![]() Some people call me the STIG!!! ![]() ![]() ![]() ![]() ![]() ![]() Posts: 1,417 Joined: 12th July, 2006 From: Liverpool Car(s): R33 GTS-T 96 S2 Real Name: Brendan Trader Rating : 5 |
I was thinking of doing this upgrade but thought if i do end up wanting bigger power i wouldnt want to do another upgrade to fmic. so im just going to get a big fmic, but good luck with your mods!!
-------------------- Help Me! Help Me!! Help Me!!!
I need to borrow/buy the following... stock cat back exhaust, stock airbox and stock boost soleniod. Im also looking for a 4.5" exhaust silencer. PM if you have one you are willing to get rid of... |
9 Nov 2006, 10:48 AM
#11
![]() Im looking at you! ![]() ![]() ![]() ![]() ![]() Posts: 715 Joined: 30th November, 2005 From: QLD - Brisbane Real Name: Chris Trader Rating : 0 |
I installed a blitz front mount in mine the other week and I was expecting a a change in throttle response but to my amazement it wasnt that bad at all.
Chris |
9 Nov 2006, 11:12 AM
#12
Hey Guys, the video's were recorded in mp4 format and wouldn't upload onto SAU i had to change the file extension to .mpg for it to work... if you guys try and open it into real player they will work.. or download any divx codec pack and will work in windows media player...
Just a reply to Nismo God, i am planning for big power in the future, however until i am financially ready for a larger turbo + rebuild + injectors + fuel pump .etc. the R34 SMIC upgrade will give you the full potential out of the stock turbo and setup... these SMIC's have been known to hold anything up to 14psi and 200 - 230rw/kw which is more then the stock turbo, injectors and fuel pump will ever handle... so in my opinion, full exhaust + boost control + R34 SMIC + PFC will give you the maximum and most reliable tuned power out of a stockish R33... and wont break the bank.. Not to mention will not give you any issues with the boys in blue as a FMIC would Cheers, Sarkis |
9 Nov 2006, 11:17 AM
#13
Ahh yes thats it.
Just save the files and rename the php to mp4. |
9 Nov 2006, 11:27 AM
#14
Hahah glad to see they work cubes... any feed back would be great guys!
Cheers, Sarkis |
