29 Aug 2006, 05:59 PM
![]() Why isn't anyone clicking? =-[ ![]() ![]() ![]() ![]() ![]() Posts: 1,908 Joined: 7th May, 2003 From: NSW - Northern Beaches Car(s): R33 GTST Series 2 Real Name: Steve Trader Rating : 7 |
I've flipped the outline image to match it with the dash pic. Seems the Airbag light is LED, and the others are a combination of high and low wattage bulbs. I'm not sure how some of the incandescent globes change to red, but the "A" globes have the blue silicon caps on them. A - High wattage incandescent globe with silicone cap. B - High wattage incandescent globe. "WL" could be LED also? C - Low wattage incandescent globe. D - LED. Seems to be only for the airbag light? I guess you never want that one to fail? E - Same as C? R33 GTST Left: 1 - Door Open | 2 - Air Bag 1 - blank | 2 - Fuel low | 3 - ABS | 4 - Hand Brake Top Center: 1 - Left Blinker | 2 - High Beams | 3 - Right Blinker Bottom Center: 1 - Blanked | 2 - HICAS Right: 1 - Seat Belt | 2 - Check Engine 1 - Oil Low | 2 - Cat Temp High | 3 - Battery Low ================================= R33GTST w/Active Limited Slip Differential Left: 1 - Door Open | 2 - Air Bag 1 - blank | 2 - Fuel low | 3 - ABS | 4 - Hand Brake Top Center: 1 - Left Blinker | 2 - High Beams | 3 - Right Blinker Bottom Center: 1 - SLIP | 2 - ALSD Right: 1 - Seat Belt | 2 - Check Engine 1 - Oil Low | 2 - Cat Temp High | 3 - Battery Low ================================= R33GTS4 Left: 1 - Door Open | 2 - Air Bag 1 - blank | 2 - Fuel low | 3 - ABS | 4 - Hand Brake Top Center: 1 - Left Blinker | 2 - High Beams | 3 - Right Blinker Bottom Center: 1 - 4WD | 2 - SLIP (need to confirm 1/2) Right: 1 - Seat Belt | 2 - Check Engine 1 - Oil Low | 2 - Cat Temp High | 3 - Battery Low ================================= R33 GTR Left: 1 - Door Open | 2 - Air Bag 1 - blank | 2 - Fuel low | 3 - ABS | 4 - Hand Brake Top Center: 1 - Left Blinker | 2 - High Beams | 3 - Right Blinker Bottom Center: 1 - 4WD Right: 1 - Seat Belt | 2 - Check Engine 1 - Oil Low | 2 - Cat Temp High | 3 - Battery Low ================================= R33 GTR V-Spec Left: 1 - Door Open | 2 - Air Bag 1 - blank | 2 - Fuel low | 3 - ABS | 4 - Hand Brake Top Center: 1 - Left Blinker | 2 - High Beams | 3 - Right Blinker Bottom Center: 1 - 4WD | 2 - SLIP (need to confirm 1/2) Right: 1 - Seat Belt | 2 - Check Engine 1 - Oil Low | 2 - Cat Temp High | 3 - Battery Low ================================= Glossary: Door Open Air Bag - Failure or testing. Fuel Low - Sender reports low fuel level. ABS - Anti-skid Braking System failure or testing. Hand Brake - (on R32 models, this can also mean that your brake fluid reservoir is low) Left Blinker High Beams - Not related to fog/spotlights. Right Blinker 4WD - GTR/GTS4 4WD Attessa system failure or testing. HICAS - Four wheel steering failure or testing SLIP - Active LSD Traction Control on at testing and on when traction loss ALSD - Active Limited Slip Differential failure or testing Seat Belt - Drivers seatbelt only Check Engine - Usually means an engine sensor is faulty. Oil Low - Oil level low. Oil pressure is read from the oil pressure guage Cat Temp High - Catalytic converter probe reading above normal temperatures. Battery Low - Output voltage from alternator is lower than normal I will update the others as I find out. If you know the missing ones, please advise! -------------------- Sydney RC Drifters My tutorials: Dash bulb info! (R33) Reseal bootlights (R33/generic) LED's in A/C unit. (R33/generic) Bought/Sold: ECR033, Campbell, Nismo Gtst, 99GTT, = SUPERMAN =, supraholic86, phat_r33, memph, Michael 1882, enilyks33r, skidkid, NiSmO`ChiCk, J34, mlt15e |
29 Aug 2006, 07:13 PM
![]() SAU VIC Member 0064 ![]() ![]() ![]() ![]() Posts: 21,925 Joined: 15th February, 2003 From: Gladstone Park Car(s): 1997 R33 GTS25TML Real Name: Paul Trader Rating : 1 |
There is no "traction" light on the R33 gtst.
Also the GTSTML spec has SLIP and ALSD in the centre of the tacho See here http://members.dodo.com.au/paul/pics/mycar...SCF0009_JPG.jpg -------------------- i am no longer accepting pm's any more - i've had enough
if you want to know something about the powerfc search in the faq if its not in there i dont know the answer -> Apexi PowerFC FAQ has been updated (April 08) - ChangeLog |
29 Aug 2006, 08:37 PM
Ah yeah... That might be for another model.
I saw the SLIP (traction) on my mates R33 GTS4... which is not a GTST, as you pointed out. Where in the centre for the "L" version? Instead of HICAS and whatever my other blanked one is? -------------------- Sydney RC Drifters My tutorials: Dash bulb info! (R33) Reseal bootlights (R33/generic) LED's in A/C unit. (R33/generic) Bought/Sold: ECR033, Campbell, Nismo Gtst, 99GTT, = SUPERMAN =, supraholic86, phat_r33, memph, Michael 1882, enilyks33r, skidkid, NiSmO`ChiCk, J34, mlt15e |
29 Aug 2006, 08:57 PM
![]() People know me... ![]() ![]() ![]() Posts: 28,949 Joined: 6th August, 2005 From: Melbourne Car(s): '98 R33 Real Name: Michael Trader Rating : 44 |
in between fuel low and handbrake is the ABS light.
the 1 to the left of the fuel low light is blank so its actually 1 - blank | 2 - Fuel low | 3 - ABS | 4 - Hand Brake and the blanked off 1 next to the HICAS light is the 4WD light in the GTR -------------------- |
29 Aug 2006, 09:17 PM
Champion, Dezz!
31 Aug 2006, 03:56 AM
Rank: RB20E ![]() Posts: 1 Joined: 31st August, 2006 Car(s): R33 II GTS-T skyline Real Name: Luke Trader Rating : 0 |
31 Aug 2006, 09:43 AM
#7
what is a ML spec? R33 GTS-T with Active LSD i'd imagine... -------------------- |
1 Sep 2006, 04:15 PM
#8
yeah, I'm not familiar with it either, but that's what paulr33 calls his optioned M-spec... might be easier to denote options with a * ?
1 Sep 2006, 05:11 PM
#9
TYPE M!!!!!!!!!!!!!!!!!!!!!!!!
24 Nov 2006, 11:24 AM
#10
![]() Rank: RB25DET ![]() ![]() ![]() ![]() ![]() Posts: 1,257 Joined: 4th July, 2002 Real Name: The Sig Trader Rating : 1 |
geez wish there was something like this for the r32 gtr
24 Nov 2006, 11:35 AM
#11
geez wish there was something like this for the r32 gtr why not just make one ? -------------------- i am no longer accepting pm's any more - i've had enough
24 Nov 2006, 11:39 AM
#12
HICAS - Rear wheel steering failure or testing SLIP - Active LSD Traction Control on at testing and on when traction loss ALSD - Active Limited Slip Differential failure or testing GTST Active LSD model has SLIP and A-LSD lights in the centre GTS4 version has SLIP and 4WD lights GTR only has 4WD light GTR Vspec has SLIP and 4WD lights -------------------- i am no longer accepting pm's any more - i've had enough
#13
'cause i'm currently working on articles for the wiki.
and quit following me around paul. -------------------- |
24 Nov 2006, 11:40 AM
#14
ah nuts alright, i'll look into it this afternoon.
24 Nov 2006, 02:39 PM
#15
![]() .:PROJECT R33:. ![]() |
