2 Jul 2009, 09:57 AM
![]() GO21LA ![]() ![]() ![]() ![]() ![]() Posts: 1,845 Joined: 20th January, 2004 From: Sydney Car(s): RB26/30 GTR Trader Rating : 14 |
Hi All,
I've had a few members ask me about the progress on my rb26/30 build for my R32GTR so i thought i'd add this thread. I started my research back in late 08, got the ball rolling in feb 09 & after 4 months i have reached my destination with 350km on the clock. As they say, good things come to those who wait (i hope). Here are my specs: 'NISSAN' rb30 block (note the word 'NISSAN' not holden or forklift hehe) RB26 head porting by ProEngines (over 10 hours) match ported exhaust manifolds by ProEngines Garrett low mount -10's (combined rating @ 920hp) RIPS custom sump (extended with baffles) RIPS diff adapter plate RIPS oil pick up RIPS inspired modified catch can (return to sump) JUN crank collar ACL race bearing set Cometic head gasket Mahle piston & ring set Argo rods Camtech/Kelford billet cams (a bit of NZ flavour) Performance valve springs (a bit of Aust flavour) ARP main/head studs N1 oil/water pump HKS intercooler (120mm?) Sard fpr Bosch 044 lift pump with 2 external Bosch 044's & surge tank PFI dual entry fuel rail (to accommodate larger 14mm entry injectors) Delphi Rochester 1000cc injectors Ross Metal Jacket harmonic balancer OS Giken cam gears Jim Berry 4000lbs race clutch (good timing whilst the engine was out, twin & triple plate was doing my head in) Nismo engine/gearbox mount kit (good timing whilst the engine was out) Blue silicone heater/intercooler/radiator hose kit (good timing whilst the engine was out) 52mm dual core alloy radiator Power FC My run-in tune results came to 270.9awkw @ 6500rpm on 10psi (cams are still set @ 0). My goal was to crack over 400awkw with strong midrange delivery, after i do my run-in km's with higher rev limit, boost & set cams im sure this will be achievable i am also contemplating with running E85, my tuner suggested "lets see what we get with 98 then make a decision" Just a quick thanks for the following people who put me in the right direction & put up with my indecisive 'qualities': RIPS (Rob Ward) ProEngines (Greg) Dirtgarage (Paul) N1GTR (Steve) CRD (Andrew & Jim) maybe i've left a few others out...in fact, i bet i have regards, Marko. -------------------- “I'm just really stunned for words. I can't believe the reception. I thought Australian race fans had a lot more going than this. This is a bloody disgrace. This is going to remain with me for a long time...
you're a pack of arseholes!” Jim Richards, October 1992 Bathurst. ![]() ![]() |
2 Jul 2009, 10:22 AM
![]() Official RH9 club member ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 6,938 Joined: 23rd September, 2005 From: Newcastle Australia Car(s): 9.4 sec street GTR Trader Rating : 43 |
Marko, as always it has been a pleasure (albeit sometimes frustrating) assisting you with your package.
Time to enjoy...if want to put a few K's on it? come up to Newcastle and say g'day. |
2 Jul 2009, 10:58 AM
good idea paul - there is nothing worse than driving in circles to get the km's up
u got some of that coopers red chilled -------------------- “I'm just really stunned for words. I can't believe the reception. I thought Australian race fans had a lot more going than this. This is a bloody disgrace. This is going to remain with me for a long time...
2 Jul 2009, 11:06 AM
![]() Team Wraith ![]() ![]() ![]() ![]() ![]() ![]() Posts: 2,421 Joined: 21st April, 2008 Car(s): R32 Real Name: T Trader Rating : 3 |
no offence now but just out of curiositiy is it still fine to run Jimberry clutches??
i remember reading how they blew up on how loads with GTRs and othersuch.. i am and most likely wrong but just wanted to clear the air thats all sorry. -------------------- |
2 Jul 2009, 11:07 AM
![]() Modifier ![]() ![]() ![]() Posts: 13,828 Joined: 18th April, 2002 From: Sydney Car(s): R33 GTR & WRX Trader Rating : 202 |
Nice work Marko, who put the engine together for you in the end?
-------------------- Built and Tuned by
Croydon Racing Developments: (02) 9648 4264 Dart Automotive: (02) 9534 8144 Just Jap: (02) 9545 0532 Parts For Sale Brand New Tomei Expreme Dump Pipe Set - R32/R33 GTR - Click! Apexi Power FC PRO & Hand Controller - R32/R33 GTR - Click! |
2 Jul 2009, 11:18 AM
no offence now but just out of curiositiy is it still fine to run Jimberry clutches?? i remember reading how they blew up on how loads with GTRs and othersuch.. i am and most likely wrong but just wanted to clear the air thats all sorry. you hear good & bad with all clutches, however, based on pauls 470awkw drag car & 3 yrs of abuse it held up fine - apparently it is still 'alive' in his mates street car if u drove a JB clutch u would be surprised, ive had an os giken triple & exedy twin which were both terrible (handbrake starts on hills in heavy traffic etc, you know the stuff that gets your heart pumping) in fact i smashed 3rd gear in my other gtr which i think that triple plate was the root cause -------------------- “I'm just really stunned for words. I can't believe the reception. I thought Australian race fans had a lot more going than this. This is a bloody disgrace. This is going to remain with me for a long time...
2 Jul 2009, 11:23 AM
#7
Nice work Marko, who put the engine together for you in the end? hey nick - i had greg @ proengines build the long engine & i did the r&r (with workshop manual & correct torque settings) that was fun although i must admit im nowhere near as fearful of the car though, the advantage of doing it yourself is taking the time & checking over everything, washing all the bits with a toothbrush someone else i forgot to thank: Craved Coatings (Chris) for the top covers, intake paint & plenum powder coating -------------------- “I'm just really stunned for words. I can't believe the reception. I thought Australian race fans had a lot more going than this. This is a bloody disgrace. This is going to remain with me for a long time...
2 Jul 2009, 11:27 AM
#8
Job well done - Looking forward to seeing what sort of numbers it produces once its run in and leaned on
I am still searching for replacement GTR, apparently I am too picky as I haven't found a suitable base yet. -------------------- Built and Tuned by
2 Jul 2009, 11:34 AM
#9
![]() Rank: RB30ET ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 8,203 Joined: 17th October, 2006 From: Canberra Car(s): R33 GTS-30T Trader Rating : 10 |
you hear good & bad with all clutches, however, based on pauls 470awkw drag car & 3 yrs of abuse it held up fine - apparently it is still 'alive' in his mates street car if u drove a JB clutch u would be surprised, ive had an os giken triple & exedy twin which were both terrible (handbrake starts on hills in heavy traffic etc, you know the stuff that gets your heart pumping) in fact i smashed 3rd gear in my other gtr which i think that triple plate was the root cause did you get the sprung center or solid center version of the jim berry clutch? i was very surprised by how easy mine is to use compared to other heavy duty singles/twins i have tried. -------------------- |
#10
^ just get a silver or black 35 & be done with it
2 Jul 2009, 12:04 PM
#11
![]() Twin Turbo Terrorist ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 4,557 Joined: 28th October, 2004 From: sydney Car(s): r32 gtr, 71 capri Real Name: Norm Trader Rating : 29 |
looking good
2 Jul 2009, 12:16 PM
#12
thanks - im driving it with the rev limit set @ 5000rpm
i can honestly say though it feels very strong in midrange delivery even on 10psi, the -10's start spooling quite hard around 3000rpm (that extra 400cc has made a massive impact on turbo response) they seem to come on earlier than my gtss setup on the rb26 -------------------- “I'm just really stunned for words. I can't believe the reception. I thought Australian race fans had a lot more going than this. This is a bloody disgrace. This is going to remain with me for a long time...
2 Jul 2009, 12:45 PM
#13
Rank: RB30E ![]() ![]() Posts: 4,447 Joined: 28th January, 2007 From: STATUS TUNING Car(s): Too many, bikes FTW. Real Name: TRENT Trader Rating : 5 |
Very nice, good luck with the final tune. Should be quite a ride.
2 Jul 2009, 12:49 PM
#14
![]() My drinking team has a racing problem. ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 4,882 Joined: 5th November, 2002 From: Far far away! Car(s): R33 GTST Real Name: Guilt-Toy Trader Rating : 23 |
you hear good & bad with all clutches, however, based on pauls 470awkw drag car & 3 yrs of abuse it held up fine - apparently it is still 'alive' in his mates street car if u drove a JB clutch u would be surprised, ive had an os giken triple & exedy twin which were both terrible (handbrake starts on hills in heavy traffic etc, you know the stuff that gets your heart pumping) in fact i smashed 3rd gear in my other gtr which i think that triple plate was the root cause Jim Berry clutch's are great. I had a Nismo GMAX Twin plate in my car and it died in 3 months. Put in a JB Full Monte Race Clutch and it has been the best clutch i have ever used, it feels light as stock and it has has put up with many slow rolling 30psi anti lag 3 gear drops and just asks for more. Anthony Martook uses them in his race cars, results speak for themself. Look at this youtube vid of one of those 375rwkw 3rd gear drops www.youtube.com/upyas Anyone who talk shit about JB clutch's are idiots without a clue. -------------------- Owner Built & Tuned - 11.11 second quarter @ 128. MPH with 374rwkw. =)
thanks again to Anthony :))) am going to stick your picture on my rides hood:)) Guilt-Toy now testing E85. Emissions Tuning my Skyline Guilt Toy Runs a 11.3 @ 130MPH Remote Control Power FC tuning thread I use and recommend these Workshops / Products Hunter All Wheel Dyno - www.hunterdyno.com.au - Top of the range AWD Mainline Dyno! -Red R Racing - Vipec ECU's -Techedge Wide Band - Gizzmo K-Mon |
2 Jul 2009, 12:55 PM
#15
^ i think we have a loyal JB customer here ^
im on the same page mate! -------------------- “I'm just really stunned for words. I can't believe the reception. I thought Australian race fans had a lot more going than this. This is a bloody disgrace. This is going to remain with me for a long time...
2 Jul 2009, 01:00 PM
#16
Im not a loyal JB customer as ive now jumped ship to NPC...but only because i couldn't see my trusty single plate holding 1000hp. My old clutch now been onsold again and is now in a 3rd car...what a top piece of kit.
2 Jul 2009, 05:15 PM
#17
![]() If You Only Knew ![]() ![]() ![]() ![]() ![]() Posts: 853 Joined: 9th February, 2006 From: skyline heaven Car(s): R33 GTST M SPEC 1.5 Real Name: BS Detector Trader Rating : 7 Garage: , R33 gtst s1.5 |
well done koobaro marko you have to show me the finished product when you come over this week. when are we starting to build my back up engine..lol
-------------------- Nismo thermostate,Nismo high flow fuel pump,Nismo strong release fork pivot,Nismo engine mounts,Nismo gear box mounts,jim berry full monte clutch,Short shift kit,Eagle conrods,ARP head studs,Arias pistons & rings,Acl engine bearings
Custom Radiator 40mm,splitfires coil packs,Sard magnetic oil pan plug,Sard annodised aluminium cooling oil block,sard fuel injectors 850cc,Sard fuel regulator,Nissan N1 oil pump,Nissan water pump,Apex power FC,Greddy boost controller,Greddy oil catch can,Greddy type R blow off valve,Greddy intake plenum,HKS 3-3.75 inch exhaust,Catco stainless high flow cat converter,HPI duel dump pipe,HDI 94mm Front mount intercooler with 2.75"turbo side & 3" intake side,Q45 throttle body,H/D valve springs,HKS cam 256-intake 264-exhaust,HKS turbo kit 3037 pro s,HKS wiring harness for Z32 AFM,Bosch Z32 air flow meter,Billion radiator cap,Billion super solid coolant line,Greddy oil cooler, 12.2@123MPH .309kw ATW water methanol with progressive controler,zex nitrous kit with progressive control. no time posted as i have no traction lol DETROIT CUSTOM BODYWORKS SPONSORED CAR ![]() ![]() |
2 Jul 2009, 06:41 PM
#18
World Leader ![]() ![]() Posts: 12,250 Joined: 13th June, 2005 From: The Switch Car(s): Gtr aka Garden Gnome Real Name: Shane Trader Rating : 8 |
Lookin good marko! Now to get out, run some k's up and wind the wick up
Im not a loyal JB customer as ive now jumped ship to NPC...but only because i couldn't see my trusty single plate holding 1000hp. My old clutch now been onsold again and is now in a 3rd car...what a top piece of kit. Last time u said it was due to sponsorship requirements -------------------- |
2 Jul 2009, 07:00 PM
#19
Lookin good marko! Now to get out, run some k's up and wind the wick up Last time u said it was due to sponsorship requirements f*ck off idiot...do i have to go into it...ok just for you. Croydon Racing sponsored the car at the time...they wouldn't allow me to continue running a single plate with the power we were planning on running. They insisted i run at least a twin plate...it was something that was agreed was the best way to go. Happy ? |
2 Jul 2009, 07:08 PM
#20
f*ck off idiot...do i have to go into it...ok just for you. Croydon Racing sponsored the car at the time...they wouldn't allow me to continue running a single plate with the power we were planning on running. They insisted i run at least a twin plate...it was something that was agreed was the best way to go. Happy ? lol whats up ur shirt? if you dont like it paul u shouldnt put ur head on the chopping block -------------------- |
Lo-Fi Version | Time is now: 31st July, 2010 - 09:25 PM |
