6 Oct 2006, 05:24 PM
Rank: RB30E ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 2,153 Joined: 24th October, 2002 Car(s): R33 GTR V-Spec Trader Rating : 212 Garage: Skyline R33 GTR V-Spec |
Nissan Rb 100,000km Service Kits -=Transaction Instructions=- -=If you have not already created an account on our website, click here to do so before proceeding with any orders.=- All transactions are conducted via a portal to our website, usually indicated by the button. Upon clicking this button a new browser window/tab will be opened and the item added to your shopping cart. At this point I would recommend logging (located within "My Account"), this will ensure that the item is added to the permanent cart attached to your account; otherwise it will be lost at the end of the session.Please remember if you have not already made an account on our website than do so here, if you use any links besides that found on SAU you will not receive the appropriate discounts. Please Note:
Details: Within the following listings you will find the main components to conduct a 100,000km service on your RB engine. Each vehicle has it's own listing so please be sure to select to one that corresponds to your needs. Item Coding: Timing Belts/Bearings 01. NSK/NTN Idler & NSK/NTN Tension Bearing, Tensioner Spring, Genuine Nissan Cam & Front Main Seals 02. Genuine Nissan Timing Belt 03. Trust Heavy Duty Timing Belt *Please note that NSK & NTN are the original equipment manufacture (OEM) of the Nissan timing belt idler & tensioner bearings. Water Pumps & Cooling 01. Genuine Nissan Water Pump 02. Genuine Nissan N1 Water Pump *The N1 Water Pumps Can be installed with any RB engine however use with the RB20 and R32 RB26DETT will require extra care, details can be supplied however I would suggest being installed by someone knowledgeable. 03. Genuine Nissan Thermostat Upgrades: 01. Trust/GReddy Adjustable Cam Gear, Intake 02. Trust/GReddy Adjustable Cam Gear, Exhaust 03. Trust/GReddy Clear Cam Gear Cover Popular Kits Nissan RB20DET Silver Top (R32, A31, C33) Basic: 1, 2, 1 & 3 - Only $402.60 ![]() Heavy Duty Kit: 1, 3, 1 & 3 - Only $477.40 ![]() Tuners Kit: 1, 3, 1, 3, 1 & 2 - Only $818.40 ![]() Nissan RB25DE (R33, C34 Non Neo Engine) Basic: 1, 2, 1 & 3 - Only $462.00 ![]() Heavy Duty Kit: 1, 3, 1 & 3 - Only $548.90 ![]() Nissan RB25DET (R33, C34 Non Neo Engine) Basic: 1, 2, 1 & 3 - Only $462.00 ![]() Heavy Duty Kit: 1, 3, 1 & 3 - Only $548.90 ![]() Heavy Duty+ Kit: 1, 3, 2 & 3 - Only $738.10 ![]() Tuners Kit: 1, 3, 2, 3 & 2 - Only $908.60 ![]() Nissan RB25DE (R34, C34 Neo Engine) Basic: 1, 2, 1 & 3 - Only $432.30 ![]() Heavy Duty Kit: 1, 3, 1 & 3 - $507.10 ![]() Nissan RB25DET (R34, C34 Neo Engine) Basic: 1, 2, 1 & 3 - Only $518.10 ![]() Heavy Duty Kit: 1, 3, 1 & 3 - $592.90 ![]() Tuners Kit: 1, 3, 1, 3 & 2 - $763.40 ![]() Nissan RB26DETT (BNR32) Basic: 1, 2, 1 & 3 - $402.60 ![]() Heavy Duty Kit: 1, 3, 1 & 3 - Only $477.40 ![]() Tuners Kit: 1, 3, 1, 3, 1, 2 & 3 - Only $913.00 ![]() Nissan RB26DETT (BNCR33, BNR34 & WGNC34) Basic: 1, 2, 1 & 3 - Only $462.00 ![]() Heavy Duty Kit: 1, 3, 1 & 3 - Only $548.90 ![]() Heavy Duty+ Kit: 1, 3, 2 & 3 - Only $738.10 ![]() Tuners Kit: 1, 3, 2, 3, 1, 2 & 3 - Only $1,173.70 ![]() You Also May Wish To Replace
13 Sep 2008, 11:48 AM
All service kits now also include a new genuine Nissan thermostat.
15 Sep 2008, 09:54 AM
![]() Sunny Coast ![]() ![]() ![]() ![]() ![]() Posts: 639 Joined: 30th December, 2006 From: Sunshine Coast Trader Rating : 0 |
I stand behind these kits!!!! Keep up the good work.
29 Sep 2008, 06:44 PM
![]() back in black ![]() ![]() ![]() ![]() ![]() Posts: 1,491 Joined: 11th March, 2006 From: Vic, Sth east burbs Car(s): Black R33 GTS-T Real Name: Brett Trader Rating : 5 Garage: ECR33 |
any chance of getting one of these by the end of the week?
vic 3200 -------------------- |
29 Sep 2008, 06:47 PM
I can have one to you as soon as Wednesday
1 Oct 2008, 12:28 PM
I can have one to you as soon as Wednesday As promised, arrived at 8:35 this morning. -------------------- |
1 Oct 2008, 12:45 PM
#7
I'm glad I was able to help out
1 Oct 2008, 09:41 PM
#8
![]() Rank: RB25DET ![]() ![]() ![]() ![]() ![]() ![]() Posts: 605 Joined: 23rd January, 2008 From: Sydney, Bankstown Car(s): Nissan Skyline R34 25GT Real Name: Vicky (vikZ) Trader Rating : 0 |
Whats the best i can do for my RB25DE NEO, because while im under there, i want to make sure i upgrade all the parts that im gonna' be replacing. Instead of putting something low on now, then having to upgrade again later.
MRXTCZ -------------------- Source: Pioneer AVHP5950DVD
Front: Rockford Fosgate T162S Splits Rear: Rockford Fosgate T162C Coaxials Subs: 2 x 12" MTX Thunder X Amps: Jaycar Response 2 Channel (2x150) Jaycar Response 5 Channel Full Range Wiring: Aerpro Dual Amp Kit and Stinger RCA's and Speaker Cable Future Mods: CAI, 2 1/2" Cat back & Lower front and rear. |
2 Oct 2008, 03:31 PM
#9
MR XTCZ: PM Sent.
7 Oct 2008, 10:09 AM
#10
Rank: RB25DE ![]() ![]() ![]() ![]() Posts: 182 Joined: 10th June, 2006 Real Name: Rob Trader Rating : 0 |
Check your website please. It it VERY slow.
Also, it does not work properly with vista IE7, says needs cookie enabled. But its already set to medium. I had to put the setting all the way down to get it to work. |
7 Oct 2008, 10:38 AM
#11
PM Sent
7 Oct 2008, 12:41 PM
#12
Rob, your order has been dispatched; you can expect to take delivery tomorrow.
