11 Feb 2006, 12:05 PM
![]() Stagea RSFOURV ![]() ![]() ![]() ![]() ![]() ![]() Posts: 616 Joined: 13th February, 2005 From: The Terrace Car(s): Stagea RSFOURV Real Name: Brendan. Trader Rating : 8 |
Does anybody know if the Nismo Keys that are gettin around fit a Stagea?
I asked Nengun, and they said they don't think it will cos the Stagea is similar to the ER34, not a definate answer so i thought someone on here would know for sure. |
12 Feb 2006, 05:30 PM
![]() Driver of The Terrifyingly Terrible Trajet of Tangible Tawdrynes ![]() Posts: 22,455 Joined: 26th November, 2003 From: Rockhampton, QLD. Car(s): Bogan-mobile Real Name: Cyrus Trader Rating : 11 |
I got a second key cut and they are exactly the same as a patrol key, so how similar are nismo keys to patrols keys?
12 Feb 2006, 08:39 PM
![]() RB25DET ![]() ![]() ![]() ![]() ![]() Posts: 676 Joined: 25th August, 2005 From: Melbourne Car(s): STAGEA Trader Rating : 1 |
I've got a nismo key (blank) that l'm using for my other car, which supposedly fits most skyline's, so l'd be under the assumption it would be fine, as l can't see there being much difference between the stagea key barrell & the R33's.
12 Feb 2006, 10:42 PM
![]() Rank: RB20DET ![]() ![]() ![]() Posts: 68 Joined: 26th September, 2004 From: Adelaide Car(s): Stagea RS Four Real Name: Daniel Trader Rating : 3 |
It does fit, just make sure you get the right one as they come in two lengths.
http://www.rcdevelopments.com/manufacturers/Nismo/key.html Cheers Daniel -------------------- Stagea Cruise clip http://www.youtube.com/watch?v=rAUE2AnEqss
or 84MB HQ version http://www.zshare.net/video/14055119fd732afc/ |
12 Feb 2006, 10:55 PM
Cheers Daniel, that answers my question
14 Feb 2006, 01:56 PM
![]() HULK MAD - AAAAARRRRGGGGHHH!!! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 6,029 Joined: 25th June, 2002 From: Parramatta, NSW Car(s): Stagea RS-Four manual Real Name: Nick T. Trader Rating : 0 |
Also, make sure whoever cuts it does a good job, as obviously replacing it will be a rather more expensive proposition!!!
I'd probably take it to a keycutter rather than your local hardware store who might cut maybe 2-3 keys a week... It's not like you've just shelled out for a key that you could have bought directly from the cutter for $2 (or whatever a blank key costs nowadays). -------------------- STAGEA: punching Volvo-shaped holes in the horizon... Spotted one? Post here! Do you WANT SAU merchandise? Click here!!! Got any ideas? Click here!!! Not an SAU-NSW member? Got questions? Want to join? |
14 Feb 2006, 11:24 PM
#7
Thats exactly what i'll be doing, they should be able to use the number off my original key, and punch it out on the nismo key, i've had that done before.
Much more acurrate than cutting with the grinder when they copy a key. |
17 Feb 2006, 12:50 PM
#8
Hmm, oddly enough, the numbers on my keys have been ground off......
19 Feb 2006, 09:13 PM
#9
QUOTE(AlexCim @ 17 Feb 2006, 01:50 PM) Mine too, I found that a bit strange... -------------------- STAGEA: punching Volvo-shaped holes in the horizon... Spotted one? Post here! Do you WANT SAU merchandise? Click here!!! Got any ideas? Click here!!! Not an SAU-NSW member? Got questions? Want to join? |
19 Feb 2006, 09:18 PM
#10
Mines still got the numbers on it
Oh by the way, i emailed Greenline and they have confirmed that the Nismo key, that they and Nengun sell will fit the series 1 stagea, don't know about the series 2 though. |
22 Feb 2006, 09:48 PM
#11
Rank: RB20E ![]() Posts: 3 Joined: 30th March, 2005 Trader Rating : 0 |
on the subject of keys, does anyone know how to program the chip in the key hob to enable remote locking?
i cut a blank nissan key to match the original for a spare. the hob of the key has 2 buttons: lock & unlock. the newly cut key starts the engine fine (i was suprised!) and now I want to know how to program the chip in the key hob so remote locking works. sometimes there is a bizarre sequence of actions like insert & remove key 5 times in 10 secs, open/shut door etc. any suggestions? |
22 Feb 2006, 10:14 PM
#12
My cousin had a key programmed for her N16 Pulsar, can't remember where she bought it, but had it programmed by a Nissan dealer.
It might be an idea to ring your local dealer and see if they can do it, surely the sequence can't be too different between models. Also, I believe there are some places who cut keys who are also able to do the programming for you, if you still can't manage to find the sequence or process to do it yourself. -------------------- STAGEA: punching Volvo-shaped holes in the horizon... Spotted one? Post here! Do you WANT SAU merchandise? Click here!!! Got any ideas? Click here!!! Not an SAU-NSW member? Got questions? Want to join? |
23 Feb 2006, 06:07 AM
#13
![]() Speed... I am Speed ![]() Posts: 3,452 Joined: 15th June, 2003 From: Bathurst Car(s): VT Commonbore Wagon Real Name: Leshy Trader Rating : 8 |
i only got one key with my car, and for some reason it's bent. it still starts the car, but i doubt i could get a key cut for it. some genious has ground off the numbers on the key as well.
to get a key cut fresh, i'm assuming i'll need to take the car to a dealer or locksmith for them to get a number off the ignition barrel? |
23 Feb 2006, 06:16 AM
#14
I have been told that the transponder in the hob of the keys are exactly the same as patrol keys, so any half decent locksmith place should be able to program it for you.
23 Feb 2006, 08:03 AM
#15
![]() Prestige touring wagon ![]() Posts: 810 Joined: 19th August, 2002 From: Brisbane Car(s): 2000 Stagea RSfour Real Name: Simon Trader Rating : 4 |
23 Feb 2006, 08:10 AM
#16
![]() Driver of The Terrifyingly Terrible Trajet of Tangible Tawdrynes ![]() Posts: 22,455 Joined: 26th November, 2003 From: Rockhampt |
