3 Jan 2008, 06:07 PM
![]() If You Only Knew ![]() ![]() ![]() ![]() Posts: 425 Joined: 9th February, 2006 From: skyline heaven Car(s): R33 GTST M SPEC 1.5 Real Name: BS Detector Trader Rating : 3 |
these thought all started by a forum member that had me thinking for a while and i need answers now (bastard)
the first pic is your seen this 1000 times manifold sold in performance shops and ebay.from $200-$800 so far people say there shit. the second i have not seen many times and am wondering if they would be any good or if any one has one,they look ok to me but maybe to a high quality forum specialist might be able to advise me. also these 6boost manifold dose any one have proof that they work,i know people say they don't crack but is there proof of gains.ive read posts in the past but after a while still no real answer!! Quick list of mods,greedy intake manifold,hks gtrs,hks cams,forged pistons&rods,power fc,nismo injectors +++++++ all mods if anyone can help that would be nice. first pic ebay copy second hpi manifold,copy or not i dont know. -------------------- Nismo thermostate,Nismo high flow fuel pump,Nismo strong release fork pivot,Nismo engine mounts,Nismo gear box mounts
Nismo flywheel,Short shift kit,Excedy custom clutch,Eagle conrods,ARP head studs,Arias pistons & rings,Acl engine bearings Custom Radiator 40mm,splitfires coil packs,Sard magnetic oil pan plug,Sard annodised aluminium cooling oil block,sard fuel injectors 850cc,Sard fuel regulator,Nissan N1 oil pump,Nissan water pump,Apex power FC,Greddy boost controller,Greddy oil catch can,Greddy blow off valve,Greddy intake plenum,HKS 3-3.75 inch exhaust,Catco stainless high flow cat converter,HPI duel dump pipe,Front mount intercooler,Custom turbo intake pipe,ARC air box,HKS valve springs,HKS oil cap,HKS cam shafts 256-intake,HKS cam shafts 264-exhaust,HKS turbo kit 3037 pro s,HKS wiring harness for Z32 AFM,Bosch Z32 air flow meter,Billion radiator cap,Billion super solid coolant line 12.2@123MPH .304KW ATW as of 18/10/08 309kw atw |
3 Jan 2008, 06:12 PM
![]() Rank: RB25DET ![]() ![]() ![]() ![]() ![]() Posts: 803 Joined: 2nd May, 2005 From: Sunshine Coast Car(s): ECR33 Series 1 Trader Rating : 6 |
I believe dangerman4 may have some words based on good experiences with the 6boost.
3 Jan 2008, 07:47 PM
Rank: RB20DET ![]() ![]() ![]() Posts: 82 Joined: 18th April, 2007 From: frankston vic Car(s): R33 GTS T Real Name: dan Trader Rating : 0 |
i Bought the first manifold off ebay and it didnt even fit.
Had to drill the holes out bigger for it to fit onto the studs then i finally got it on it would hit the mount tat supports the intake pipe just before the butterfly. -------------------- |
3 Jan 2008, 07:49 PM
![]() Move Your assss!!! ![]() ![]() ![]() ![]() ![]() Posts: 1,015 Joined: 19th October, 2004 Car(s): r33 gtst , datto ute Trader Rating : 11 |
my mate has a vl turbo with the 6boost manifold with a stock internal engine and a t66 turbo. The spool time is almost instant. Its farkin insane
i have met kyle and he has showed me his manifolds and the merge collector on them is awesome. A+ quality and a top dude. Also Mark from godzilla motorsports that has a r32 gtr, that now i believe runs 8.34 has a 6boost manifold on his car. If ya looking at a manifold go check out 6boost first. -------------------- [font="Arial Black"][/font][size="5"][/size][color="#0000FF"][/color] Madrootas[/url]
3 Jan 2008, 08:34 PM
my mate has a vl turbo with the 6boost manifold with a stock internal engine and a t66 turbo. The spool time is almost instant. Its farkin insane i have met kyle and he has showed me his manifolds and the merge collector on them is awesome. A+ quality and a top dude. Also Mark from godzilla motorsports that has a r32 gtr, that now i believe runs 8.34 has a 6boost manifold on his car. If ya looking at a manifold go check out 6boost first. thanks for the info does your mate have a before and after ,power wise -------------------- Nismo thermostate,Nismo high flow fuel pump,Nismo strong release fork pivot,Nismo engine mounts,Nismo gear box mounts
3 Jan 2008, 08:43 PM
thanks for the info does your mate have a before and after ,power wise I can find out for you. he is doing 11.2 with it now though and has blown his gearbox. -------------------- [font="Arial Black"][/font][size="5"][/size][color="#0000FF"][/color] Madrootas[/url]
3 Jan 2008, 08:46 PM
#7
I can find out for you. he is doing 11.2 with it now though and has blown his gearbox. thanks for you help -------------------- Nismo thermostate,Nismo high flow fuel pump,Nismo strong release fork pivot,Nismo engine mounts,Nismo gear box mounts
3 Jan 2008, 09:32 PM
#8
![]() compulsive tinkerer ![]() ![]() ![]() ![]() ![]() ![]() Posts: 2,796 Joined: 6th April, 2003 From: Sydney Car(s): bent r32, hello kitty s13 Real Name: badhair Trader Rating : 18 |
http://www.skylinesaustralia.com/forums/Ch...amp;hl=manifold
dangerman4s thread comparing china manifold to extreme turbo manifold -------------------- BHDave
If you don't like it you can bang it up your arse. |
3 Jan 2008, 09:59 PM
#9
Rank: RB25DE ![]() ![]() ![]() ![]() Posts: 170 Joined: 13th May, 2005 Trader Rating : 1 |
Mark is indeed running a 6boost manifold
I just picked one up for my gtr, it took 4 months of waiting but it finally shipped out. calaisturbo.com has some very smart people. -------------------- |
3 Jan 2008, 10:06 PM
#10
yes, this IS me.. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 10,147 Joined: 11th February, 2003 Real Name: John Trader Rating : 18 |
with manifold you get what you pay for (this excludes crappy stainless jap brands)
3 Jan 2008, 11:24 PM
#11
![]() im living the westlife ![]() ![]() ![]() ![]() ![]() Posts: 348 Joined: 19th February, 2006 From: NOR joondaz Car(s): r32 Real Name: vantanyon Trader Rating : 1 |
would a good manifold ie: 6boost or ETM bring boost on earlier??
-------------------- ![]() 241rwkw 13 psi |
3 Jan 2008, 11:27 PM
#12
what do you guys think of the second manifold
3 Jan 2008, 11:42 PM
#13
![]() GET TO THE WIN! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 3,130 Joined: 14th October, 2006 From: Leumeah Car(s): R33 S2,98 Proton Real Name: Dave Trader Rating : 35 Garage: Skyline GTSt |
Would like to know peoples opinions on the GCG manifolds.Could be an option for you WARLORD.
3 Jan 2008, 11:50 PM
#14
Rank: RB25DET ![]() ![]() ![]() ![]() ![]() Posts: 934 Joined: 7th September, 2005 Real Name: hans Trader Rating : 13 |
the second one is just another version of cheap shit which looks attractive to the untrained eye.
dont be a stingy ass and go out and get yourself a 6-boost or hks gt- cast manifold to complement the reast of your mods |
4 Jan 2008, 12:07 AM
#15
the second one is just another version of cheap shit which looks attractive to the untrained eye. dont be a stingy ass and go out and get yourself a 6-boost or hks gt- cast manifold to complement the reast of your mods very good .......sharp eye -------------------- Nismo thermostate,Nismo high flow fuel pump,Nismo strong release fork pivot,N |
