11 Jan 2006, 10:01 PM
![]() i gotta change my signin to "5" ![]() ![]() ![]() ![]() Posts: 380 Joined: 28th December, 2005 From: Gympie Car(s): mellow yellow S2 & V35 Real Name: Wazza Trader Rating : 2 |
I have read in other threads about the need to stall the auto to make a fast getaway.
While I think i have the basic idea...jam on the brakes, open fun flipper then release on green. It hardly chirps the wheels, even on smooth cement. At 2000 it starts to creep on the brakes I did know a bloke who used to take his Mazda Mark 1 to 10k then pop it into D....alas poor torquey for I knew it well. But I aint about to do dat. So what's the technique? |
11 Jan 2006, 10:53 PM
Well, my technique
- Put on the hand brake really hard. As hard as you wanna launch - Push brake with left foot, as hard as above - Put into 1 with O/D off - Hold left hand on handbrake release - Accel till the car starts to creep a tiny bit, then hold around that area - Release left foot/left hand/floor it all at once - Shift ~6k into 2 - Shift ~6k into D - At 200 put O/D on I can get some pretty hard launches this way. There have been a few times when I have 1->N->D by accident, without really lifting off, resulting in a chirp. The stupid shifter doesnt need to press the button when going up gear, but then from D->N it goes without the button too, causing mis shifts (sounds funny to speak of in an auto) Enjoy mate. PS. Lauch on some grass/dirt, a lot more fun loosing traction ill tell ya -------------------- |
12 Jan 2006, 08:04 AM
![]() RB31DET ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 11,632 Joined: 31st January, 2003 From: Sydney Car(s): R32GTST R33GTST Stagea Trader Rating : 50 |
Similar to Alex, the standard torque converter allows around 2,250 rpm for launch. Higher rpm as the power goes up. This gives 10 psi with the standard turbo. If you flatten the accelerator and drop the hand brake and foot brake simaltaneously it shouldn't drop below 10 psi and will instantly hit 2,500 rpm which is heavily into the torque curve.
I find if I don't use the handbrake the rear wheels spin a little, sorta line locker style. But the ATTESSA then kicks in and it drives throuigh the front brake, so both foot and handbrake are the go. With good suspension and some seriously sticky 245/45/17's and 150 4wkw I can't get any wheelspin, even in the wet. It will be interesting to see what 200 4wkw will do. Should get to the speed limit even faster. Warning, don't hold it against the torque converter for the whole of the red light, they get very hot. And I already have a large transmission cooler. -------------------- Yes, SK is back from the sabbatical.
12 Jan 2006, 11:00 AM
RB25DET ![]() ![]() ![]() ![]() Posts: 295 Joined: 16th February, 2005 From: Brisbane Trader Rating : 2 |
OK so by the sounds of it the torque converter is getting punished. Can this reck the gearbox?.
12 Jan 2006, 11:04 AM
QUOTE(emanuelt @ 12 Jan 2006, 11:00 AM) The torque converter takes the load (torque) and transforms it into heat. If you boil the transmission fluid it will stuff the gearbox. There is very little shock loading transferred to the gearbox, like there is if you slam it into drive with the revs up. -------------------- Yes, SK is back from the sabbatical.
12 Jan 2006, 12:27 PM
Am I the only two wheel drive around here?
Thanks SK and ALex - that's the kind of technical guff I need to know so I can play/practice with it from there. My BC is set to 10PSI and it seems to hold it like you said. ALthough the thread on the (AMS's ? ) blown turbo has got me worried as mine spikes to 11.5 when you stab it as opposed to feeding it on. Still, the stock, cheap and nasty hose clamps are still doing the job. Gotta love that 2500 torque curve - very driveable around town. How large is a large oil cooler. Mines still stock (10 rows?) and sits in front of the condensor and radiator. Do you think moving it to the right hand inner wheel guard (aka left hand side turbo set up) with a fan is a good idea? Do any versions come with a power/economy button like most other auto's? I also have no O/D facility. Only traction Control which is not ATESSA (no front axle) and wheel spin results in retarded performance until you back off to where the ECU is happy again. Fortunatley you can turn T/C off though. |
12 Jan 2006, 06:16 PM
#7
Rank: RB25DE ![]() ![]() ![]() ![]() Posts: 273 Joined: 5th November, 2002 Trader Rating : 1 |
-------------------- Stagea RS4
Dato 1600 Rally Car Gemini Turbo Diesel 66 Mustang |
12 Jan 2006, 06:21 PM
#8
All the RS4 series 1's come with the power/economy button. Its a 4 spd auto that just locks out 4th when the over drive button on the gear stick is turned off. The 2WD Stagea could just use all 4 gears normaly and not have the option to lock out 4th. Unless you have a 5sp gear box.
Lo-Fi Version | Time is now: 20th March, 2010 - 06:36 PM |
