15 Jun 2005, 08:49 PM
![]() You're Either With Us, Or Against Us ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 10,848 Joined: 8th November, 2004 From: Melbourne Car(s): 1978 Holden HZ GTS Monaro Real Name: James Trader Rating : 3 |
Hey guys, I am writing this up in order to help some people out there that don't want to get ripped off getting their turbo timer installed by an auto elec.
Now, firstly the turbo timer I installed was a HKS type 1 turbo timer, so some slight differances may occour Things You will need : Turbo Timer Wiring harness (best not to chop your loom if you can help it) Wire strippers (You will need to strip 0.75mm wire) wire connectors. Side cutters wire crimpers Phillips Head screw driver shifter or small socket set Black electrical tape. Pateince, and care !! Now firstly you will have to remove the steering column surround, as stated in other guides on here. Now look at the back of the key barrel, there will be a 6 pin plug at the back of it, now simply unplug it, and plug the wires into the harness u have, and plug it back into the key barrel. Now before continuing, i made sure i had power and ignition still. So give it a try. Now tidy up all the cables and make them neat under the dash. Plug the wiring harness into the turbo timer unit iteself. Now, connect the earth to any metal surface. To know that its working have the ignition on, the plug connected into the turbo timer, and once u earth it. It should power up. Connect it. ( i installed mine in the ashtray so i ran my earth wire to the screws holding the gearbox boot down. Right next to my stereo one Now, for the handbrake wire. This is where the fun starts. take apart the gearbox surround, and continue to undo the centre console and completely remove so you can see the parking brake wire. Its on a switch. Now i unplugged this and soldered it onto the plug itself. But you can connect it closer to the dash simply by following the correct wire. Now, get the ecu out, which for me (r33 gts-t) was in the passenger kick panel. Now i disconnected the battery before continuing from here on in. take the kick panel off, and undo the bolts holding the ecu in position. Now you can unplug the wires from the ecu so you have a little bit more movement (there isnt much). Follow the guide, cut the correct wires, taking lots of care that you are actually counting the plugs in the unit and not the amount of wires. Say the diagram says the bottom row, 4th from the end. You may have ||.| (| - indicates wire, . indicating now wire) The wire on the left will be the one to cut. I nearly got caught out this way so just take your time and care. Connect all the wires using the crimpers and connectors you had, neaten up all the wires as you see fit. Put everything back together again and enjoy your new fully connected turbo timer Please download these files before continuing. Ecu Ecu plugs Any questions please don't hesitate to ask Best of luck ! -------------------- |
16 Jun 2005, 12:17 AM
Rank: RB25DE ![]() ![]() ![]() ![]() Posts: 316 Joined: 12th February, 2005 Trader Rating : 4 |
plz make it a sticky.
cheers mate will try to hook one up when i get my TT -------------------- ---------------------------
:chairshot :confused: |
6 Jul 2006, 02:40 PM
Rank: RB25DET ![]() ![]() ![]() ![]() ![]() Posts: 1,288 Joined: 6th March, 2006 From: Tamborine Mountain- Gold Coast Car(s): 96' Stagea RS Four, MR30 Real Name: Hugh Trader Rating : 1 |
Has anyone installed an Apexi Auto Timer with A/F rario,O2 sensor voltage
etc.? Did you get a "Specific Vehicle Harness" with it, or did you make it yourself? |
6 Jul 2006, 02:41 PM
6 Jul 2006, 02:42 PM
6 Jul 2007, 08:51 AM
![]() rb25det conversion ![]() ![]() ![]() ![]() ![]() Posts: 696 Joined: 24th March, 2007 From: Carindale, Queensland Car(s): 1995 Nissan Skyline GTS Real Name: Hamish Trader Rating : 0 |
Has anyone installed an Apexi Auto Timer with A/F rario,O2 sensor voltage etc.? Did you get a "Specific Vehicle Harness" with it, or did you make it yourself? No i havn't installed one but i have purchased one and do you have to buy the vehicle specific harness? -------------------- Previous rides:
- 1992 Holden VP Commodore 3.8 ltr v6 Current Ride - 1995 Nissan Skyline GTS - with rb25det conversion - the lean mean green machine - KKR480 Turbo, Otomoto Dump Pipe, Stainless Nismo Front pipe, 3" stainless cat-back, apexi dual pannel D1 forced pod filter, apexi turbo timer, apexi PFC, greddy intake manifold, greddy TB adaptor, greddy typre RS bov, greddy oil catch can, HKS wiring harness, JJR boost controller, Racetech Boost gauge, Hybrid FMIC, nismo front strut brace.. 拓海 - Need a detail or install? PM me for availability |
Lo-Fi Version | Time is now: 5th December, 2008 - 06:01 AM |
