22 May 2009, 04:11 PM
![]() Rank: RB25DE ![]() ![]() ![]() ![]() ![]() Posts: 363 Joined: 28th March, 2006 Car(s): R33 GTS-T S2, Mitsu FTO Real Name: Simon Trader Rating : 0 Garage: R33 GTS-T S2 , FTO GPX |
Just a quick guide on how to install one of these.
These are the terminals for the wires I spliced into. I just used the wire clips that came with the light. The Green factory wire was 12v Ignition. The Yellow with Blue tracer is Tacho signal. Tested all ok before putting dash back together. Mounted using 'Old Faithful' double sided tape. Only needed to be calibrated up one point. Works a treat. Cheers Simon |
22 May 2009, 06:53 PM
![]() Rank: RB25DE ![]() ![]() ![]() ![]() Posts: 416 Joined: 5th September, 2008 From: Sydney Australia Trader Rating : 0 |
Hi Simon,
Nice review ! I'm glad you found the installation so easy and simple. Thanks for taking the time to write a review like this. Is that photo of the back of your instrument cluster on your dash ? -------------------- A division of Waenick Pty Ltd
http://www.tunersgroup.com |
22 May 2009, 09:15 PM
Yeah that's the back of the cluster.
The tacho signal is marked TAM. |
22 May 2009, 10:48 PM
GOJIR4 ![]() Posts: 1,364 Joined: 22nd May, 2008 From: Northern Suburbs, SA Car(s): '94 R32 GTR Real Name: Lance Trader Rating : 6 |
I wired my Shift-I at my ECU loom, tacho, ignition switch (so I could use it's voltage indicator feature).
22 May 2009, 11:05 PM
23 May 2009, 12:35 AM
14.4volts while engine is running, or 12v when the engine is running?
23 May 2009, 07:46 AM
#7
23 May 2009, 05:06 PM
#8
What value did you use as rpm calibration? I think I had to use 4 solid lights (or was it 4 blinking lights)
23 May 2009, 06:49 PM
#9
16 Mar 2010, 04:05 PM
#10
RB30DETT - addicted ![]() ![]() ![]() ![]() Posts: 28,072 Joined: 22nd September, 2005 From: Sydney Car(s): BNR32 Berlina.JZA80-TT Real Name: Steve-O Trader Rating : 96 |
How did you go?
Is it all good? -------------------- SAUNSW President 2010 SAUNSW Vice President 2006, 2007 SAUNSW Club Exec 2005, 2008, 2009, 2010 R32 GT-R (built); 455rwkw JZA80 SupraTT (stock, for now); Feels like 160rwkw VTII Berlina (stock); Maybe 150kw at the spark plugs?!?! |
16 Mar 2010, 04:17 PM
#11
4 May 2010, 11:32 AM
#12
Rank: RB20E ![]() Posts: 3 Joined: 29th December, 2008 Trader Rating : 0 |
Hi Doobs... Tony from Ecliptech here
Would you mind if we put together a fitment guide for R33 GTR owners with your info/pics? Will of course give full credit to yourself and include a link for SAU etc... |
11 Jun 2010, 10:07 PM
#13
Rank: RB20E ![]() Posts: 1 Joined: 11th June, 2010 Car(s): 93 R33 Skyline GTS-T Real Name: Shane Trader Rating : 0 |
Yeah that's the back of the cluster. The tacho signal is marked TAM. Hey guys, I'm trying to hook up my Shift Light in my R33 GTS-T... There is four wires for the it RED +, BLACK -, GREEN (RPM), YELLOW (Light) I'm all good with the RED and YELLOW but i just need to know if I use the TAM screw on the back of the cluster with the GREEN wire and the BLACK to the ground screw will that work...? Has anyone done it...? |
11 Jun 2010, 10:15 PM
#14
ShnaneosR33... which shift light is this you are trying to hookup? I would have expected the black, red and green all you would need. Unsure what the yellow (light) is for. Check the instructions for what it does. Perhaps it's for the lighting circuit, so it dims at night when your headlights are on (given that shift light doesn't have a light sensor to do it automatically). |
13 Jun 2010, 12:17 PM
#15
![]() Rank: RB25DE ![]() ![]() ![]() ![]() Posts: 188 Joined: 18th March, 2010 From: Melbourne VIC Car(s): Skyline R32 Real Name: Victor Trader Rating : 1 |
Where would one buy these? Thanks.
-------------------- It's all about the tyres bro!
13 Jun 2010, 12:23 PM
#16
14 Jun 2010, 08:27 AM
#17
^^^What he said.
17 Jun 2010, 07:15 PM
#18
Ouch at $17X
Lo-Fi Version | Time is now: 31st July, 2010 - 09:24 PM |
