IPB
> Tutorials / DIY / FAQ Rules
3 Pages V   1 2 3 >
> Howto: Water Spray For Aftermarket Intercooler, Work in progress guide
paulr33
post 23 Nov 2005, 09:26 PM
Post #1
SAU VIC Member 0064
Group Icon
Group Icon
Group Icon
Group Icon
Car(s): 1997 R33 GTS25TML
Real Name: Paul
Trader Rating : 1
HOWTO: Water Spray for Aftermarket Intercooler
Intended Audience: Anyone with an Intercooler
Technical Level: Medium / Low
Duration: 2 hours approx to complete
Effort: Medium
Result: Good
!!!Caution/Achtung/Attenzione!!!
Follow this guide at your own risk. You have been warned. We are not responsible for any actions you take. The information contained herein is a guide and should be acted upon with consultation from your local tuner. If you are unsure or are not confident don't do it.
i am no longer accepting pm's any more - i've had enough
if you want to know something about the powerfc search in the faq
if its not in there i dont know the answer
-> Apexi PowerFC FAQ has been updated (April 08) - ChangeLog
Profile CardPM
Go to the top of the page
+Quote Post
Googlebot
Post #
Trader Rating :
> Google Ads
Quote Post
paulr33
post 23 Nov 2005, 09:29 PM
Post #2
SAU VIC Member 0064
Group Icon
Group Icon
Group Icon
Group Icon
Real Name: Paul
Trader Rating : 1
This is to serve as an inplace thread for a DIY Water Spray kit.
There are several aftermarket kits and some DIY home-made ones.
Please post any sucess/failures you have had and your results.
I plan to test a DIY home made kit with a a 3rd party temperature monitoring kit. I will be monitoring ambient temp, and temp at each side of the end tanks on the intercooler. Then at a fixed speed activate the water spray system and record the temperature drop at the end tank of the intercooler core. I will not be adjusting any settings for the test and will be staying at a fixed speed(s) say 60km/h then 80km/h then 100km/h as I believe these will show the true results of the test. I expect a good 5-6-degree drop in outlet temps on the intercooler core.
Profile CardPM
+Quote Post
paulr33
post 23 Nov 2005, 09:32 PM
Post #3
SAU VIC Member 0064
Group Icon
Group Icon
Group Icon
Group Icon
Real Name: Paul
Trader Rating : 1
Temperature datalogger:
K145 - Temperature Logger
This kit is a 4 channel temperature meter. The temperature data, in degrees C or F, is output as a continuous data stream over an RS232 serial port. The kit uses a PIC12C509 and up to 4 x DS1820 digital thermometers (only 1 supplied - more available on request). No external power is required (the kit is powered from the serial port).The output data is in simple text format. Simply capture the data to a text file and then import it into Excel to produce tables and charts of temperature readings over time. Or you can write your own BASIC programs to grab the readings.This is an ideal use for old 386 and 486 computers - continuous temperature data logging. As you can see from the photo there is not much to the hardware.
http://www.ozitronics.com/data.html (they are in sydney)
Kit is $34.50 and comes with 1 temperature sensor.
Addiotnal sensors are $12 each and it can support upto 4.
The system plugs in via a serial port and when you connect it returns the temperature of each sensor one per line each second. Perfect for datalogging. We use these kits at work to monitor server room temperature so they are reliable.
Profile CardPM
+Quote Post
paulr33
post 23 Nov 2005, 09:35 PM
Post #4
SAU VIC Member 0064
Group Icon
Group Icon
Group Icon
Group Icon
Real Name: Paul
Trader Rating : 1
Sard Water Spray Kit:
Sard Item 29205
AU $ 310.09
Sard Cooling Spray Kit
Introducing the Sard Cooling spray unit. Can be used to spray water onto the Radiator or Intercooler. The S.C.S consists of a Manuel or Automatic Mode.
Parts included
Electronic Cooling Spray unit
Plastic Tank
Nosel & Stay
Motor & Pump
Profile CardPM
+Quote Post
paulr33
post 23 Nov 2005, 09:40 PM
Post #5
SAU VIC Member 0064
Group Icon
Group Icon
Group Icon
Group Icon
Real Name: Paul
Trader Rating : 1
Cusco Kit
WATER SPRAY CONTROLLER
FEATURE
Keeps excessive heating down and allows continuous
driving runs, with power.
Decreases temperature for in-going air to the intercooler, enabling better combustion and increasing air intake amount for more power.
USE
There are various ways to cool your intercooler.
It can be set to spray continuously for a span from one to five seconds in one second intervals. Also the spray interval can be set at 3, 4, 5, 7 or 9 seconds. Other settings include continuous spray for a period of 15 seconds to 3 minutes maximum and ability to turn on at a pre-set rpm level. Of course the settings stop automatically when the tank is empty.
ADDITIONAL FEATURE
With the optional Nose and Hose Set fitted, the radiator will can be water sprayed as well.
FITTING
This widely available CUSCO product is made
to fit all models.
00B 732 A AU $ 147.32
AU $ 186.87
Add to Cart
Unversal Water Spray Contoller Kit
00B 732 B AU $ 47.78
AU $ 61.95
Add to Cart
Universal Water Spray Contoller Nosile Kit
http://www.nengun.com/image/catalogue/prim...-product-40.bmp
http://www.nengun.com/image/catalogue/prim...-product-38.bmp
http://www.nengun.com/image/catalogue/prim...-product-39.bmp
Profile CardPM
+Quote Post
paulr33
post 23 Nov 2005, 09:41 PM
Post #6
SAU VIC Member 0064
Group Icon
Group Icon
Group Icon
Group Icon
Real Name: Paul
Trader Rating : 1
PIVOT
* Multi-function water spray control unit cools down intake air by spraying water onto the intercooler. This system can also be used for the radiator or the oil cooler.
* Spray pattern can be selected from "Spray at the rpm more than the set rpm", "Timer set" or "Constant spray" depending on your driving situation.
* The system stops automatically to protect the motor when the water tank becomes empty.
* For the models with factory water spray function such as Lancer Evolutions and WRX STi, etc... the system can work only with the controller kit. For the other models, the washer bottle and the motor for the rear window screen can be used. In this case, optional nozzle kit needs to be purchased as well
WSC AU $ 151.30
AU $ 190.85
Add to Cart
Water Spray Controller
WSN-1 AU $ 54.55
AU $ 68.71
Add to Cart
Water Spray NOZZLE KIT (Nozzle, One-way valve ,Hose and Holder
http://www.nengun.com/image/catalogue/prim...-product-55.bmp
http://www.nengun.com/image/catalogue/prim...-product-53.bmp
http://www.nengun.com/image/catalogue/prim...-product-54.bmp
Profile CardPM
+Quote Post
GTTR34
post 24 Nov 2005, 10:23 AM
Post #7
- -- Oo -- oO -- -
Group Icon
Trader Rating : 7
Awesome thread! Myself and Daniel (CNBLOW) actually made our own DIY Intercooler Water Spray kits by re routing the water hoses from the rear wiper washer motor outlet to spray water on the intercooler. This was controlled automatically via the Relay output on the Apexi Rev Speed Meter, which will trigger the spray motor when a certain RPM or speed is reached. Mine was set to start spraying at 4500RPM or 120kph.
Paul, are the kits you have listed above all available from Nengun ?
BUILT & TUNED by www.recustoms.com.au FTW!
Team Wheel Whore - Because two sets is never enough :D
"If everything seems in control, you're just not going fast enough" - Mario Andretti
Profile CardPM
+Quote Post
paulr33
post 24 Nov 2005, 10:30 AM
Post #8
SAU VIC Member 0064
Group Icon
Group Icon
Group Icon
Group Icon
Real Name: Paul
Trader Rating : 1
yeah they're all from nengun. did you see any good results when you were testing?
Profile CardPM
+Quote Post
GTTR34
post 24 Nov 2005, 10:54 AM
Post #9
- -- Oo -- oO -- -
Group Icon
Trader Rating : 7
I had some issues with finding appropriate nozzels to direct the water onto the intercooler with the best spray area. Didn't test for temperature drop across the end tanks so can't give feedback there as I didn't have any real noticeable difference. I believe a proper sorted water spraykit would make a difference in cooling intake temps.
My DIY job is disconnected at the moment, I'm considering to buy a proper kit since they're so inexpensive.
Profile CardPM
+Quote Post
justin911
post 24 Nov 2005, 02:05 PM
Post #10
^^^ need roof wheels :(
Group Icon
Car(s): R33 GTR
Trader Rating : 26
isnt spraying water onto the intercooler like 1/4 as effective as spraying mist/water into the actual pipes after the intercooler... ?
My sisters ex has a s14.. he uses the injection method INSTEAD of having an actual intercooler.....
Profile CardPM
+Quote Post
paulr33
post 24 Nov 2005, 08:31 PM
Post #11
SAU VIC Member 0064
Group Icon
Group Icon
Group Icon
Group Icon
Real Name: Paul
Trader Rating : 1
a good discussiong on the those topics is at:
http://forums.corvetteforum.com/showthread...#post1552430047
I would be concerned of issues pertaining with failure / something going wrong and a large amount of water being put into the intake. With a water spray for the intercooler the worst that can happen is it dumps all the water. and it would be easier to remove the water spary vs removing water injection i would imagine. bottom line i wouldnt be comfortable trying it
Profile CardPM
+Quote Post
Wink
post 26 Nov 2005, 10:57 AM
Post #12
Black go-karts FTMFW
Group Icon
Car(s): 2003 Toyota MR-S
Real Name: James
Trader Rating : 9
Should be obvious, but remember to use distilled water for the spray as the minerals in tap water can do damage to the FMIC.
Profile CardPM
+Quote Post
Josh
post 26 Nov 2005, 01:13 PM
Post #13
Rank: RB30E
Car(s): 1989 R32 GTSt RB25
Trader Rating : 0
The advantage of spraying water into the intake charge was moreso to lower chances of detonation isn't it? obviously it would help with the temps - but I remember reading about it somewhere about a dude on a dyno had his car detonating its tits off, then he wound MORE boost into it and turned the sprayer on and it was all good...
Profile CardPM
+Quote Post
justin911
post 26 Nov 2005, 06:18 PM
Post #14
Group Icon
Car(s): R33 GTR
Trader Rating : 26
yeah and it lets you up the timing to.
theres not much chance or it spraying tons of water into your pipes because the brass/metal nozzle is a set size and sprays a very very fine mist.. and as long as its installed correctly only abit of the nozzle would be sticking inside the pipe..
With most of the kits aswell they also include a little led or something to notify you when the water/methanol etc is running low..
its understandable people dont like the idea of water inside the pipes i guess, just incase it somehow did go wrong.
Profile CardPM
+Quote Post
MearCat
post 7 Dec 2005, 11:50 PM
Post #15
TRUST Me!
Car(s): '96 Gts-t
Real Name: Alan
Trader Rating : 10
QUOTE(Wink @ 26 Nov 2005, 10:57 AM)
Tap water doing damage to your FMIC??? Gee - I'd better stop washing my car with the hose then hey...
What damage do you honestly expect tap water to do to the outside of the intercooler - except maybe leave tiny traces of minerals on the core? Do you have acid in your tap water? Aluminium does not oxidise as quickly as it's metalurgical reactivity properties would suggest.
WWW.MEARCAT.COM.AU
- Custom Gauge Pods for all Nissans, WRX, Forester, and other Turbo cars.
- 4 Channel Temperature Display - with alarms, peak values & data logging
- Intercooler Spray controller
FOR SALE :
Nissan Consult Port/Cable - Connectors & Pins
Profile CardPM
+Quote Post
