5 Dec 2008, 07:46 PM
![]() Yankee ![]() ![]() ![]() ![]() ![]() Posts: 516 Joined: 17th May, 2007 From: US--no more japan :-( Car(s): '92 GTSt w/RB25 & HX40 Real Name: Chris Trader Rating : 1 |
I've had a lot of questions about the turbo I'm running, and I didn't want to get another thread too off topic, so I'll put some info up here. Just for reference, I have the 6 blade HX40 with a 19cm T4 holset housing. A large majority of the info I have I gleaned from the DSM forums which is the is 90's american version of the Evo. They all have 4G63's in Mitsu Ecliplses and Eagle Talons, and most of the guys on this site have AWD versions. Anyways, I'll post up some general info they have on holsets and get into more specifics later if anybody expresses interest. Also keep in mind most of this info is geared towards 4g63 applications, so they talk about BEP (Bullseye Performance) housings Again, I don't want to take credit for somebody else's work, so here is some info from THIER page.
Summary provided by wiseman, Dsm-onster: HX35: The 8blade hx35 has a 56mm compressor inducer. This is found on 1995-1998 cummins manual pickups. The compressor flows 52 lb/min according to the compressor map. The bolton BEP housing (0.55 a/r) is enough to push the limit of the compressor. There's several 500whp 8blade hx35 cars out there with the bolt on housing. It reaches 20+psi by 3500rpms in 3rd with 272 cams. Smaller cams would equal a faster spool speed in most cases. The 7blade hx35 has a 56mm compressor inducer. This is found on the 1999-2002 cummins manual pickups. The compressor flows 60lb/min according to the compressor map and logged results from a member here. The bolton BEP housing with the hx35 turbine wheel do not SEAM to have enough flow to really reach the potential of 60lb/min. But many have logged over 50lb/min so far and seen 500whp. The stock hx35 12cm^2 twinscroll turbine housing is a t3 flange housing. This mated to a NON-divided runner manifold has produced a 132mph trap speed with a full weight 1g AWD. This is about 600whp. So the flow is there with the stock housing if you use a non-divided manifold. The spool speed of the 7blade hx35 is similar to the 8blade hx35 with 20+ psi by 3500rpms in the bolton housing and by 4000rpms with the stock housing with a non-divided manifold. HY35: The hy35 has a smaller turbine wheel than the hx35. And, it has a turbine housing connection that does not allow for a bolton housing to be used. It does not have a divided housing so any t3 manifold can be used effectively with this turbo. It has the same compressor as the 7blade hx35. We don't know if te hy35 turbine wheel and housing is enough to reache the 60lb/min potential of the 56mm 7blade compressor. Some one try it out already!!! It should at least be a faster spooling viable option to the full t3/t4 50-trim.H1C/WH1C: In 1994, there was the Wh1c which has pretty much the identical compressor as the hx35 but with a Vband compressor cover. The turbine wheel is the same. It will bolt into the BEP bolton hx35 turbine housing. It has 4 bolts at the housing instead of 6. So you will need to buy 2 more bolts and use 6 washers cut to make a flat side. Honestly, I just used bolts that were cut a little short and the bolt head was wide enough to pull the chra to the turbine housing. No sealing issues. Since the Wh1c is for all practical purposes an 8blade hx35 the spool and flow is the same too. I have the big h1c. It comes on the INTERCOOLED 1991-1993 cummins pickups. It has the webbing for MWE but no groove cut like the hx35/wh1c has. This turbo I term the big h1c because it has a 54mm compressor inducer and same exducer than the 8blade hx35/Wh1c. The other h1c is the small h1c found on the NON-intercooled cummins pickups. This has a 50mm inducer but only 7blades and has no webbing for MWE. Less blades helps flow, but so does a larger inducer diameter. The most whp ever recorded on a gas 4cylinder with the small h1c was done on a KA24 nissan: 411whp. Since the big h1c has a 4mm larger inducer and the same turbine wheel as the hx35, it is safe to say that it flows enough for between 411whp and 500whp. The diesel sources state that it flows SLIGHTLY less than the early hx35. So 4lb/min less than the 8blade hx35 puts the flow of the big h1c at 48-49lb/min right where a 50-trim or 20g is. The small bep housing is all that's needed to get the most from the compressor and the spool speed is 20+psi by 3500rpms. HX35-40 hybrid: Keeping the long tradition of the marriage of sportcompact and hybrid turbos, there is the hx35 turbine and the hx40 compressor. It is strongly recommended to use the large bep turbine housing or the stock hx35 turbine housing with an non-divided t3 manifold for this turbo. The small bep housing around a t31 size hx35 turbine wheel is probably not enough to merit any of the hx40 compressor wheel upgrades. 20+ psi by 4000rpms can be seen in the hx35/40 with the hx35 12cm^2 turbine housing with a non-divided t3 manifold. With the large bep housing, spool times are to be determined. But likely similar. HX40: The 8blade hx40 has a 58mm inducer and flows about the same as a 60-1 (around 60lb/min) with ALOT better high boost efficiency and spool speed. It is the most common hx40 out there. The small bep housing with the hx40 turbine wheel is plenty to reach the full potential of the 60lb/min 8blade hx40 compressor. 20+ psi by 4100rpms with 272s. The 7 and 6 blade hx40 is called the super40 and has the 60mm compressor inducer. This compressor flows around 69lb/min. You can get this wheel in billet style (think HTA). The non-billet wheel spools as fast as the 8blade hx40 in the bolton bep housing and has done 653whp at 40psi per the holset results only thread. Billet should spool even faster. The t3 .70 a/r BEP housing slows spool about 400rpms. But reports show a significant gain in flow per psi. So expect more power at lower boost with that turbine housing. H1E/WH1E: The Wh1e is like it's little brother the Wh1c. It mirrors the hx40 8blade in every way except that it has a v-band compressor cover and a 4bolt chra-turbinehousing pattern. It will consequently bolt into the hx40 bep bolton turbine housing and this is plenty of flow to max out its 60lb/min compressor. The h1e is like it's little brother the h1c. There are different size compressors. . . BUT there are also different size turbine wheels too. Check measurements before buying this turbo if you plan on running a BEP turbine housing. There are lower flowing compressors than the 58mm 8blade that are out there. So this turbo may not flow any more than an hx35 if get the wrong one. You need at least a 58mm compressor inducer for this to be a worthwhile turbo vs the proven hx35 or 8blade hx40. HX52: This is a big sucker. It is commonly found on the Volvo Semis and usually has a billet compressor wheel. It flows 88lb/min. There is no bolt on housing for it. If you want a bolton housing for this turbo, then you don't want this turbo. In fact if you want a t3 flange turbine housing for this turbo, then you don't want this turbo. You DO want this turbo if you're looking at a gt4294r or gt4202r. The turbine inlet is slightly different than a t4 bolt pattern. You can still get the t4 manifold to work just fine by enlarging the bolt holes. Misc.:
Cjmartz2k Holset Turbo's 5 Dec 2008, 07:46 PM
Cjmartz2k **Almost forgot the whole point of these turbos. ... 5 Dec 2008, 08:13 PM
R33S2 If I wanted to make 550hp with an RB25 motor that ... 5 Dec 2008, 10:56 PM
Cjmartz2k QUOTE (R33S2 @ 5 Dec 2008, 09:56 PM) If I... 6 Dec 2008, 10:47 AM
robots http://idforums.net/index.php?showtopic=33299... 6 Dec 2008, 04:06 AM
discopotato03 Hi CJ , there has been a trend towards some Holset... 6 Dec 2008, 02:54 PM
robots So lets say I'm looking for good 400-450 flywh... 6 Dec 2008, 05:21 PM
mid life crisis we used to buy holset turbos from a machinery wrec... 6 Dec 2008, 05:44 PM
a31lunacy is there any chance of doing up a chart and referi... 6 Dec 2008, 10:42 PM
Cjmartz2k As for the "how much hp" or "which ... 7 Dec 2008, 11:53 AM
Cjmartz2k Here's a couple of vid of my old HX35/40 hybri... 8 Dec 2008, 10:59 PM
robots I was just typing about how I saw some vids of an ... 8 Dec 2008, 11:49 PM
fandango if i was looking for about 230 kw's at the whe... 9 Dec 2008, 09:35 AM
r3240sx QUOTE (fandango @ 8 Dec 2008, 04:35 PM) i... 9 Dec 2008, 04:57 PM
Cjmartz2k Just some more info for fodder. I went out tonigh... 9 Dec 2008, 11:15 PM
alwaysdreaming hey mate, what would you reccommend for roughly 28... 10 Dec 2008, 01:49 AM
Cjmartz2k QUOTE (alwaysdreaming @ 10 Dec 2008, 12:4... 10 Dec 2008, 02:43 PM
alwaysdreaming [quote name='Cjmartz2k' date='10 Dec 2... 11 Dec 2008, 02:48 PM
Cjmartz2k QUOTE (alwaysdreaming @ 11 Dec 2008, 01:4... 11 Dec 2008, 04:08 PM
RBJ3T This is the first I have ever heard of Holset turb... 11 Dec 2008, 03:20 PM
omy-33 why r the photos of an rb25 motor tho? 11 Dec 2008, 04:20 PM
Cjmartz2k I'm at work right now so I can't see pics,... 11 Dec 2008, 04:30 PM
discopotato03 Hi all , so tired ATM . Trains off the road at Lon... 11 Dec 2008, 04:46 PM
discopotato03 Some Holset turbine and compressor wheel dimension... 11 Dec 2008, 06:17 PM
discopotato03 Lots of reading to do .
Cheers A .
http://www.d... 11 Dec 2008, 07:52 PM
discopotato03 More Holset stuff , looks interesting .
http://ww... 12 Dec 2008, 02:59 PM
alwaysdreaming most of the hx35's i have found have an intern... 13 Dec 2008, 10:59 PM
alwaysdreaming check out the size of this thing!
http://au.yo... 14 Dec 2008, 12:40 AM
FATAZZ I went into Cummins around the corner here in Weth... 15 Dec 2008, 09:34 AM
discopotato03 Yeah it could be difficult finding anything cheap ... 16 Dec 2008, 07:54 AM
Cjmartz2k So Garrett is moving more towards what Holset and ... 16 Dec 2008, 11:54 AM
discopotato03 Well Garretts GT4088R has been around for a couple... 16 Dec 2008, 02:16 PM
alwaysdreaming hey guys just been searching ebay and found this.
... 16 Dec 2008, 09:02 PM
CEF11E QUOTE (alwaysdreaming @ 16 Dec 2008, 10:0... 17 Dec 2008, 02:21 PM
alwaysdreaming QUOTE (CEF11E @ 17 Dec 2008, 03:21 PM) th... 19 Dec 2008, 12:06 AM
Cjmartz2k You need to get the measurements on the wheels, no... 17 Dec 2008, 11:18 AM
mattsr31 http://www.youtube.com/watch?v=LBP-pWe44Ns...featu... 18 Dec 2008, 10:11 AM
Cjmartz2k Not that there aren't some impressive giant Ho... 18 Dec 2008, 12:22 PM
juggernaut1 The Borg Warner s300sx also seems to be a very cap... 18 Dec 2008, 01:40 PM
Cjmartz2k Very interesting read. Also interesting to note t... 18 Dec 2008, 03:16 PM
juggernaut1 QUOTE (Cjmartz2k @ 18 Dec 2008, 04:16 PM)... 18 Dec 2008, 03:32 PM
juggernaut1 One thing I notice with the BW's is that they ... 18 Dec 2008, 03:25 PM
Cjmartz2k I think it's actually the compressor and turbi... 18 Dec 2008, 03:39 PM
SS8_Gohan reckon any of these would be comparable to an HKS ... 18 Dec 2008, 07:55 PM
discopotato03 Personally I think the BW's are the ones to wa... 19 Dec 2008, 01:43 AM
Cjmartz2k Disco, you refer to them as "old", but t... 19 Dec 2008, 09:07 AM
Cjmartz2k I just noticed somebody on here is running a B-W S... 19 Dec 2008, 11:49 PM
radix Reviving this thread just to say:
Evo + HX52 = ... 8 Mar 2009, 03:46 PM
Lithium QUOTE (radix @ 8 Mar 2009, 03:46 PM) Evo ... 8 Mar 2009, 04:41 PM
radix Power to weight ratio........ 4wd advantage for t... 8 Mar 2009, 04:44 PM
Lithium bozodos - What do you mean by the appropriate size... 10 Mar 2009, 10:28 AM
radix QUOTE (Lithium @ 10 Mar 2009, 09:28 AM) b... 10 Mar 2009, 11:00 AM
T04GTR yeah go the dirty truck turbo! hey i almost ha... 8 Mar 2009, 06:19 PM
bozodos Does anyone know off the top of their head the app... 9 Mar 2009, 08:11 PM
radix HX80 sounds like more fun. 10 Mar 2009, 10:07 AM
Lithium They are running Garretts, and that EVO is tube fr... 10 Mar 2009, 01:00 PM
radix Holsets are still fairly new (2-3 years old) to st... 10 Mar 2009, 01:05 PM
radix To add to that.
For someone looking to build a pr... 10 Mar 2009, 01:09 PM
bozodos well I guess a turbine flowing say 600hp? I'm ... 10 Mar 2009, 09:18 PM
Cjmartz2k Bozodos--I'm missing what you are asking. Are... 11 Mar 2009, 11:01 AM
Lithium Yeah its starting to look at it that way. I'd... 11 Mar 2009, 12:21 PM
T04GTR shwitzer ftw 11 Mar 2009, 12:31 PM
bozodos Nah I mean like flow terms, as in I have a KKR480 ... 11 Mar 2009, 07:01 PM
Dearlove anyone know how these last when using antilag?? 23 Mar 2009, 07:29 PM
Cjmartz2k They are built big and sturdy. I don't think ... 23 Mar 2009, 08:37 PM
meet07 ^^^yeah what he said. 24 Mar 2009, 11:15 AM
VspecGTR Hey guys.
Been doing alot of reading up on holse... 26 Apr 2009, 09:21 AM
Cjmartz2k They are fibbing with those numbers on the HX35. ... 26 Apr 2009, 05:10 PM
VspecGTR QUOTE (Cjmartz2k @ 26 Apr 2009, 08:10 AM)... 26 Apr 2009, 06:27 PM
Cjmartz2k I don't know about that company. They give so... 26 Apr 2009, 07:05 PM
smok74 For ya 'typical' RB powered Skyline (2 lit... 26 Apr 2009, 08:22 PM
bigmikespec It would be interesting to see if Holset and/or Bo... 26 Apr 2009, 08:54 PM
VspecGTR Over here (england) With holset being a english co... 26 Apr 2009, 10:25 PM
URAS QUOTE (VspecGTR @ 26 Apr 2009, 10:25 PM) ... 27 Apr 2009, 07:45 PM
VspecGTR what would a borg warner make ie this particular m... 26 Apr 2009, 10:36 PM
Cjmartz2k One definite downside to holsets is they do NOT ca... 26 Apr 2009, 11:25 PM
VspecGTR Yeah is a bit of a bummer chris....knowing that a ... 26 Apr 2009, 11:36 PM
CEF11E Just a heads up for those looking for these turbos... 27 Apr 2009, 05:35 PM
TheRogue CEF11E,
It will be VERY interesting to compare dy... 27 Apr 2009, 06:16 PM
SS8_Gohan so the only downside to these is that to fit them ... 27 Apr 2009, 06:30 PM
VspecGTR Mate if you go a few pages prior to page number fo... 27 Apr 2009, 07:57 PM
URAS QUOTE (VspecGTR @ 27 Apr 2009, 07:57 PM) ... 27 Apr 2009, 08:34 PM
VspecGTR are you going to run an external wastegate? or doe... 27 Apr 2009, 08:00 PM
Cjmartz2k URAS--part numbers -----> http://www.dsmtuners... 27 Apr 2009, 09:35 PM
VspecGTR QUOTE (CEF11E @ 27 Apr 2009, 08:35 AM) Ju... 27 Apr 2009, 08:02 PM
VspecGTR With the holset turbos.....how much modification t... 27 Apr 2009, 08:28 PM
CEF11E water lines are not needed. they can be blocked of... 27 Apr 2009, 08:35 PM
VspecGTR I aint an aussie 27 Apr 2009, 09:59 PM
Cjmartz2k O yeah, UK, forgot! Do they have RB30's i... 27 Apr 2009, 10:22 PM
VspecGTR Have to import them matey.....had a few prices giv... 27 Apr 2009, 11:53 PM
VspecGTR Just had this email from one of the guys in the U.... 27 Apr 2009, 11:58 PM
VspecGTR And another email recieved but this one is regardi... 28 Apr 2009, 12:06 AM
CEF11E in regard to the gate,
looking at the size on the... 28 Apr 2009, 06:01 PM
urtwhistle http://www.turbomaster.info/eng/catalogs/holset.ph... 28 Apr 2009, 10:20 PM
URAS QUOTE (urtwhistle @ 28 Apr 2009, 10:20 PM... 28 Apr 2009, 11:01 PM
urtwhistle therefore look out for
dodge Ram's 1994-curre... 28 Apr 2009, 11:02 PM
urtwhistle oh i see, no probs either way atleast it will give... 28 Apr 2009, 11:03 PM
VspecGTR QUOTE (CEF11E @ 28 Apr 2009, 09:01 AM) in... 29 Apr 2009, 03:48 AM
Cjmartz2k QUOTE (smok74 @ 26 Apr 2009, 07:22 PM) Fo... 29 Apr 2009, 10:13 AM
Cjmartz2k Some of you interested in Holsets from that partic... 1 May 2009, 10:59 AM![]() ![]() |
Lo-Fi Version | Time is now: 31st July, 2010 - 09:10 PM |
