8 Aug 2003, 03:12 PM
![]() Rank: RB25DET ![]() Posts: 617 Joined: 29th January, 2003 From: Gold Coast Trader Rating : 0 |
HICAS Diagnostic Procedure
1. Input starting conditions for self-diagnosis. * Turn ignition switch "OFF". * Set shift lever to "P" or "N" (A/T) or "Neutral" (M/T). * Turn ignition switch "ON". * Immediately start engine. * Turn steering wheel from left to right (at least 20deg from the neutral position) 5- times or more, then depress foot brake pedal at least 5- times all within 10- seconds after ignition switch has been turned "ON". 2. Input self-diagnosis item. * Depress and release foot brake pedal. * Turn steering wheel from left to right (at least 20deg) from the neutral position. * (M/T model): Depress clutch pedal and move gear shift lever to any position other than Neutral and return to Neutral. Release clutch pedal. (A/T model): Disengage and engage parking brake lever. Move shift lever to any position other than Neutral or Parking and return to Parking. * Move car at least 3 meters (10ft) forward and proceed at indicated speed of at least 2km/h (1mph) in self-diagnosis mode. 3. The self-diagnosis mode will then appear in the "HICAS" warning lamp. * When all systems are normal HICAS warning lamp flashes at 0.25 second intervals. * When there is a system malfunction (there is a nifty diagram here of HICAS lamp pulses. I tried to translate them to words...) Mode A) 10 short pulses for 5 seconds. No pulses for 5 seconds. Nine 2-second interval indicating the system status (18 seconds total). (short pulse = good, 1 second pulse=bad) 1) HICAS Solenoid R.H. 2) HICAS Solenoid L.H. 3) Fail-Safe Valve 4) (Constantly normal mode) 5) Vehicle Speed Sensor 6) Steering Angle Sensor 7) Steering Neutral Position Sensor 8) A/T: Parking brake sensor ___ M/T: Clutch Sensor 9) A/T: Inhibitor Sensor ___ M/T: Neutral Sensor ** Display repeats until ignition switch is turned "OFF" or 5 min has past. Mode B) Lamp on for 5 seconds. No pulses for 5 seconds. Nine 2-second interval indicating the system status (18 seconds total). (short (0.1 sec) pulse = good, 1 second pulse=bad) 1) HICAS Solenoid R.H. 2) HICAS Solenoid L.H. 3) Fail-Safe Valve 4) (Constantly normal mode) 5) Vehicle Speed Sensor 6) Steering Angle Sensor 7) Steering Neutral Position Sensor 8) A/T: Parking brake sensor ___ M/T: Clutch Sensor 9) A/T: Inhibitor Sensor ___ M/T: Neutral Sensor ** Display repeats until ignition switch is turned "OFF" or 5 min has past. Note 1: To change the display mode to "A", turn OFF ignition switch after mode "B" is displayed. When battery is insufficient, mode "B" is displayed. Note 2: If fail-safe system was operated (fail-safe valve is operating) when ignition switch was turned OFF for the last time, mode A will be displayed. If fail-safe system was not operated when the ignition switch was turned OFF for the last time, mode B will be displayed. * Canceling the self-diagnosis function Three methods. 1) By turning the ignition switch off. 2) After self-diagnosis has been operated for ~5 minutes. 3) If the vehicle speed goes over 30 km/h (19 mph). -------------------- You know that look women get when they want sex....?
Me neither |
11 Aug 2003, 06:16 PM
What is HICAS? And do I have it?
Good question. HICAS is Nissan’s version of four wheel steering. It is an acronym for High Capacity Actively Controlled Suspension. Unlike other Japanese car manufacturers 4WS (eg Honda’s system) HICAS never exceeds +/- 1°. It is designed for high speed response rather than parking manoeuvres. The system is electro-hydraulic - the ECU in the boot directs a hydraulic actuator at the rear axle to steer the rear wheels using the rearmost suspension links. The result is usually no more than 0.4° of movement. HICAS gives a touch of counter steer before settling with the rear wheel pointing the same way as the front. (Maybe this explains why my Skyline feels so loose on high-speed gravel...) This results in sharp turn-in, and enhanced stability at medium to high speeds. -------------------- You know that look women get when they want sex....?
Me neither |
11 Aug 2003, 06:22 PM
What is SUPER HICAS
Nissan Skyline GT-R has the SUPER HICAS setup. Aided by computer, Super HICAS enables a tightly-controlled power slide that cannot be implemented by any alternatives. When attacking a corner, the rear wheels will steer in reverse first in order to sharpen the initial steering response. Then, when sensors sense that the car responds to steering, the rear wheels will steer in the same direction as the front wheels, thus immediately introduces rear-tyre slip which help adjusting the attacking angle. Since the computer is monitoring the whole process, the amount of oversteering is always under check. You need not to be afraid of losing control. The Super HICAS system was also available on a few S13 models. As you can see htat would make drift that little bit easier. -------------------- You know that look women get when they want sex....?
Me neither |
15 Apr 2004, 04:42 PM
Rank: RB25DET ![]() ![]() ![]() ![]() ![]() Posts: 803 Joined: 2nd March, 2004 Trader Rating : 1 |
Does this HICAS diagnostics work for a 34 GTT as well?
-------------------- Dont ask me to put on stickers.. say no to stickers
*waves the anti-stickers flag* Blonde + Skyline = dangerously... :aroused: |
5 Jun 2004, 12:06 AM
Rank: RB20E ![]() Posts: 1 Joined: 27th April, 2004 Trader Rating : 0 |
the hicas light on my car pretty much stays on all the time but occasionally turns off, i have an r32 i was wondering if the diagnostic procedure is the same .
10 Jun 2004, 11:26 PM
![]() Car-less ![]() ![]() ![]() ![]() ![]() Posts: 1,705 Joined: 3rd August, 2002 From: Melbourne Trader Rating : 8 |
What is the neutral sensor - i got this code?
-------------------- R33 rear hicas rack, perfect condition (I installed a lock bar) - $50
R33 rear swaybar mounts and bushes - $20 R33 Exhaust bracket (supports exhaust at cat converter, stops it moving around) - $20 Grey carpet - matches R33 boot carpet, perfect for subwoofers etc - $20 R33 clutch and pressure plate - $50 SOLD CAR NEED TO CLEAR |
17 Jun 2004, 07:06 PM
#7
HICAS Diagnostic Mode
There is a HICAS warning light in the instrument cluster. If it comes, on it is indicative of a problem. R32: Check the HICAS oil level (power steering reservoir in some models, or a remote reservoir accessible from the boot) R32 and R33: Check all HICAS electrical connections, and if the light remains on, follow the diagnostic below. Note that having an aftermarket steering wheel fitted without the appropriate HICAS boss adaptor can also cause the HICAS system to show a fault.
HICAS Diagnostic Codes 1989-1993 1 HICAS solenoid right hand 2 HICAS solenoid left hand 3 Cut off valve 4 Power steering solenoid 5 Vehicle speed sensor 6 Steering angle sensor 7 Neutral position sensor 8 (Auto) Parking brake sensor, (Manual) Clutch sensor 9 (Auto) Inhibitor switch, (Manual) Neutral sensor HICAS Diagnostic Codes 1993-1999 11 HICAS control unit 12 HICAS motor power supply not present 13 HICAS motor output not present 21 Vehicle speed sensor not present 22 Steering angle sensor not present 23 Steering angle sensor neutral or not present 24 Rear main sensor input not present 25 Rear sub sensor input not present 31 Parking brake sensor input not present 32 (Auto) Inhibitor switch input not present; (Manual) Neutral switch input not present 33 Engine speed signal not present This information from "The Sky Is The Limit, A Book Of Skyline Stuff" -------------------- R33 rear hicas rack, perfect condition (I installed a lock bar) - $50
20 Dec 2004, 11:24 PM
#8
![]() Isn't it obvious? ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 3,456 Joined: 8th August, 2003 From: Sydney, Australia Trader Rating : 9 |
A couple of questions
1) What's the difference (beyond the obvious slight difference in how one enters the mode) between the methods posted by Lozza150 and Greg? Do both methods apply to all Skylines fitted with (Super) HICAS? 2) Using Lozza150's method , does HICAS go in to Mode B by default? Cheers, Lucien. |
7 Feb 2005, 07:15 PM
#9
![]() R32 GT-R ![]() ![]() ![]() ![]() ![]() Posts: 905 Joined: 2nd January, 2005 From: ADELAIDE/SYDNEY or 744 Real Name: Ben Trader Rating : 9 |
ok I am trying to self check this HICAS light fault.... now the question remains, does HICAS work, or is it marketing? votes for removal on the GTR? and did gibbo's race cars have it removed?
will have to run this check, as the light seems to come on on slight corners or hard accelleration.... ideas? |
8 Feb 2005, 12:09 AM
#10
QUOTE(williamsf1) now the question remains, does HICAS work, or is it marketing? votes for removal on the GTR? and did gibbo's race cars have it removed? Yes, it works insofar as it does turn the wheels. If that's a positive (it makes manevourability at very low speeds easier) or a negative (you never quite know what the car will do when you start to corner) if up to the driver. The diagnostic mode should tell you exactly what's wrong. LW. |
14 Feb 2005, 04:46 PM
#11
![]() Rank: RB25DET ![]() ![]() ![]() ![]() ![]() Posts: 1,337 Joined: 16th August, 2003 From: Tasraceia Car(s): R32 GTR Real Name: Ben Trader Rating : 1 |
I did the test, and it came up with 5 Vehicle speed sensor as the problem. Where is this sensor located?
19 Feb 2005, 05:00 PM
#12
![]() Richy ![]() ![]() ![]() Posts: 47 Joined: 9th June, 2003 Car(s): '94 R32 GTR Trader Rating : 0 |
Another 2 cents.. I read somewhere that the hicas light will come on if an aftermarket steering wheel is installed and the steering wheel position sensor is not relocated correctly. If i drive in a straight line (open highway) for a couple of minutes without moving the wheel much , my light comes on and stays on till i turn off and restart the car. I know this is my problem as i have a momo steering wheel. Haven't got around to fixing the sensor yet though
14 Mar 2005, 08:43 AM
#13
![]() Rank: RB25DE ![]() ![]() ![]() ![]() Posts: 367 Joined: 22nd February, 2005 Trader Rating : 0 |
I did the diagnostic and got codes 22 & 23, then as I went back into garage it started flashing quickly (the "good" sign), so I did the diagnostic again and got code 22. BTW I had no probs with the HICAS light before this just did the test out of curiosity.
Are: 22 Steering angle sensor not present 23 Steering angle sensor neutral or not present big problems for the operation of HICAS? |
14 Mar 2005, 12:11 PM
#14
If tyhe light does not come on, and the fuse is ok, id say everything is ok. does seem odd that the codes come up and the light stays off.
Me neither |
15 Mar 2005, 06:44 AM
#15
Hey actually maybe it was a wrong code, because I noted in another post somewhere I think that if you don't drive forward (or back) far enough you can get an erroneous code. I tried this test again twice going forward further and got the HICAS light flashing fast saying everything's ok. In any case unless it causes me any probs I'll leave it be.
On a side note - I've noticed people saying they disable HICAS because it develops problems and aussie mechanics never know how to deal with it, but as far as I know the 300zx had Super HICAS and that was delivered locally so Nissan mechanics at least would know how to fix it, and certainly there'd be others who've fixed 300s? |
22 Mar 2005, 07:54 PM
#16
![]() Only a fool breaks the 2 second rule ![]() ![]() ![]() ![]() ![]() ![]() ![]() Posts: 3,088 Joined: 12th February, 2005 From: Logan Qld Car(s): Its just a car Real Name: Terry Trader Rating : 19 |
QUOTE The Super HICAS system was also available on a few S13 models. As you can see htat would make drift that little bit easier. It is my understanding that hicas reduces the ability to DRIFT properly as what we are trying to do is loose grip on the tires and therefore DRIFT the rear end about w |
