13 Feb 2006, 07:04 PM
![]() RB25DET Neo ![]() ![]() ![]() ![]() Posts: 365 Joined: 28th December, 2005 From: Gympie Car(s): 1 mellow yellow S2 Real Name: Wazza Trader Rating : 1 |
A useful glossary of terms and acronyms.
This is a basic list I created for myself in an attempt to catch up on the lingo. A fuller, more comprehensive list can be found at: http://wiki.r31skylineclub.com/index.php?title=Glossary SLANG: Noob/Newb - new person, freshman to the scene, doesnt know much CBF'd - couldnt be bothered, to investigate the truth of a statment but will happily give you my own opinion as valid. OMG - oh my goodness!! said with numerous exclamations and hand to the open mouth AFIK - As far as I Know LOL - laugh out load ROFL - Roll on floor laughing IMHO - In my humble opinion Meh - whatever FTW = For The Win/World, i.e. basically proclaiming to be the best of whatever... CAR: AWKW - All wheel kilowatts AVCR - Apexi's Electronic Boost Controller AFM - Air Flow Meter CoG - Centre of Gravity Cat - Catalytic Converter CAI - Cold Air Intake DC - Davies Craig, manufacturer of aftermarket thermo fans. DFA - Digital Fuel Adjuster (AFM Voltage Bender) (Jaycar named unit similar to SAFC) EBC - Electronic Boost Controller (Generic name) FMIC - Front mount intercooler IEBC - Intellegent Electronic Boost Controller (Jaycar just added on I) (Jaycar specific name) ICE - In Car Entertainment LSD - Limited Slip Differential OEM - Original Equipment Manufaturer NVH/NVM - Noise Vibration Harshness/Movement - ie Road Noise PCV = Positive Crankcase Ventilation PCV Valve = a one way valve that allows the crankcase to breath into the plenum when not on boost. On boost the valve closes, otherwise the boost pressure would escape from the plenum and go into the crankcase. R&R - ECU Rich and Retard RWKW - Rear wheel kilowatts SITC - Super Ignition Timing Controller (Apexi specific product) SMIC - Side Mount Intercooler SAFC - Super Air Fuel Controller (AFM Voltage Bender) (Apexi specific product) SFHC - Superfine Hard Coat. Coating on the cars paint surface to give an 'always waxed' look TT - Turbo Timer or Twin Turbo when after an engine designator (ie RB26DETT) TPS - Throttle Position Sensor WOT - Wide open Throttle GENERAL: WTB - Wanted to buy EOI - Expressions of interest CONVERSION TABLE: 1KW = ?PS 1PS = ?KW 1KW = ?HP 1HP = ?KW |
13 Feb 2006, 08:50 PM
SITC - Super Ignition Timing Controller (Apexi specific product) R&R - ECU Rich and Retard NVH/NVM - Noise Vibration Harshness/Movement SMIC - Side Mount Intercooler SAFC - Super Air Fuel Controller (AFM Voltage Bender) (Apexi specific product) AVCR - Apexi's Electronic Boost Controller AFM - Air Flow Meter DFA - Digital Fuel Adjuster (AFM Voltage Bender) (Jaycar named unit similar to SAFC) EBC - Electronic Boost Controller (Generic name) IEBC - Intellegent Electronic Boost Controller (Jaycar just added on I) (Jaycar specific name) TT - Turbo Timer or Twin Turbo when after an engine (aka RB26DETT) DC - Davies Craig Cat - Catalytic Converter Cant really think of much more now, if anyone has any more ideas post away.. -------------------- |
13 Feb 2006, 09:08 PM
Thanks AC - off to a good start - it answered some of my questions
If adding to this list is it possible to distinguish between a generic name and a brand name. ie, you had SITC as Apexi, so is this just an apexi product only or do a number of different companies make SITC's |
23 Jul 2007, 01:23 AM
![]() Rank: RB25DET ![]() ![]() ![]() ![]() ![]() Posts: 648 Joined: 21st October, 2006 From: SA Car(s): S2 Stagea, S2 Bluebird Real Name: Dave Trader Rating : 1 Garage: Stagea Series 2 |
CONVERSION TABLE: 1KW = ?PS 1PS = ?KW 1KW = ?HP 1HP = ?KW Thought I might add to this... looked unfinished: 1 PS = 735.49 W 1 KW = 1.36 PS 1 PS = 0.74 KW 1 KW = 1.34 HP 1 HP = 0.75 KW Source: http://www.statman.info/conversions/power.html |
Lo-Fi Version | Time is now: 5th December, 2008 - 06:40 AM |
