IPB
> Tutorials / DIY / FAQ Rules
10 Pages V   1 2 3 > »
> Fuel Pump Direct Feed Rewire., 11.2v to 13.8. :)
Cubes
post 22 Oct 2005, 12:57 AM
Post #1
Rank: RB26DE
Group Icon
Group Icon
Group Icon
Trader Rating : 10
I recently checked the voltage my fuel pumps were receiving.
Voltages were consistently around 11.2v's.
I zipped down to Jaycar and picked up....
8GA OFC Red Power Cable x 6m
8GA OFC Black Power Cable x 1m
FuseHolder x 1
5AG 30AMP Fuse x 2
60amp Horn Relay x 1 (Nice big terminals to suit the 8GA cable and its spade connectors)
Red/Black Large Eye Terminals for 8GA x 1
Yellow 5.3mm Insulated Eye Terminal x 1
Yellow Large Insulated Spades x 1
Blue 6.4mm Insulated Spades x 1
Thats about it off the top of my head.
Basically, ran the red wire from the engine bay to the boot, placed the fuse inline then ran the wire to the relay, chopped the 12v feed to the fuel pump shoved a connector on the end of it and connected it to the relay, earthed the relay so that it can earth. lol, ran the new 12v feed from the relay to the fuel pumps. Earthed the fuel pump neg directly to the chassis.
Instantly I noticed the external fuel pump sounds angry as it buzzes away. Measured voltage, 13.8v, exactly whats at the battery.
The priming also sounds much more agressive, the fuel pump is definitely louder outside the car and sounds as if its spinning much faster, inside you can hardly hear it.
The warm weather will be interestering, it usually makes loud surging vibrating noises when it gets hot in traffic. I'm hoping this will help stop that some how, hopefully it doesn't make it worse. tongue.gif
Profile CardPM
Go to the top of the page
+Quote Post
Googlebot
Post #
Trader Rating :
> Google Ads
Quote Post
Busky2k
post 22 Oct 2005, 02:19 AM
Post #2
Captain Boostin'
Car(s): S14.5 200SX
Trader Rating : 1
Yeah the stockie wiring is pretty hopeless for aftermarket pumps which easily demand >10amps when the pressures go up. I take it you have a Bosch? The surging gurgling sounds didnt go away when I rewired mine unfortunately.
In search for the ultimate in response and power...
Profile CardPM
+Quote Post
Cubes
post 22 Oct 2005, 04:58 PM
Post #3
Rank: RB26DE
Group Icon
Group Icon
Group Icon
Trader Rating : 10
The stock wiring definitely has issues coping with 2 fuel pumps, I still have the intank and the external. tongue.gif
Driving today, the surging gurgling sound is still there, feeling the fuel pump it makes your hand numb. tongue.gif
Profile CardPM
+Quote Post
Trust33
post 23 Oct 2005, 09:27 AM
Post #4
Trader Rating : 7
Cool.I think that the earthing system i have in the car now made a huge difference in the way the battery holds it's charge.Though i havent done any tests,after i made up my new earthing system i could insdtantly see that the 3yr plus old battery can hold it's charge even after being connected to the terminals and the car being off the road and not being started for a month or so at a time cranking it over charge is like it had been run the day before.
185rwkw R33GTS-t For Sale $15.5K
TUTORIALS:
Diy:diff Shimming For R33 Gtst. A tutorial for more lsd lock.
>> Video on R33 gtst Front Mount Intercooler Install <<
What stock rims 16" & 17",any make and model of car,will fit the rear of an R33gtst
A life lived in fear is a life half lived.
Profile CardPM
+Quote Post
Bl4cK32
post 23 Oct 2005, 10:25 AM
Post #5
よのトルク
Trader Rating : 21
I'll be off to Jaycar now to do some shopping.....wanna draw up a circuit diagram too while your at it? smile.gif
RB31DET"brute torque available at any RPM in any gear for violent acceleration"
Profile CardPM
+Quote Post
Cubes
post 23 Oct 2005, 10:48 AM
Post #6
Rank: RB26DE
Group Icon
Group Icon
Group Icon
Trader Rating : 10
whoohooo..
It is damn loud outside the car with its gurgling/surging noise once the fuel heats up, just can't be heard inside the car. biggrin.gif
Profile CardPM
+Quote Post
Sydneykid
post 23 Oct 2005, 11:13 AM
Post #7
RB31DET
Group Icon
Trader Rating : 49
Hi Cubes, glad to see you finally did the wiring upgrade, it's a very worthwhile investment in time and not a lot of money.
You are suffering from "excessive size pump syndrome", because the 044 flows a bit over 360 litres per hour at 13.8 volts. This means every minute 6 litres of fuel is being pumped to the engine. But if it is idling or crawling along in traffic using say 1/10 of litre per minute, 5.9 litres goes back to the tank every minute. If you have say 20 litres in the tank (bit over a 1/4 on the guage), that means the 20 litres takes a bit over 3 minutes for all of it to go to the engine and back.
While it is in the engine bay it gets heated up, then it goes around again and gets heated some more. After a 15 minute slow drive with little or no airflow, the engine bay gets up around 100 degrees and so does the fuel. I have seen fuel boil in the tank ..............
To be continued
I don't own or work for a workshop and I don't know everything.
Wanted standard front and rear strut tops for R32/33/34 Skylines and Stageas plus 200SX S15 & S14
Group Buys on for Road & Track Kits (Whiteline, Eibach & Bilstein) for R32GTST, R32GTR, R32GTS4, R33GTST, R33GTR, R33GTS4, R34GTT, R34GTR and Stagea, plus Road and Track Kits for 200SX, S15 & S14
Profile CardPM
+Quote Post
Cubes
post 23 Oct 2005, 11:22 AM
Post #8
Rank: RB26DE
Group Icon
Group Icon
Group Icon
Trader Rating : 10
Interestering.. It does sound correct, idle it around in traffic and I hear the noise, throw some nice new cool fuel in and it goes away, or go for a long drive at a constant speed and the noise goes away. smile.gif
Feeling the pump it does feel like its vibrating quite a bit, makes my hand numb holding the pump while its operating. tongue.gif
Profile CardPM
+Quote Post
bj_dove
post 23 Oct 2005, 02:23 PM
Post #9
Trader Rating : 3
just on the note of the low stock voltage at the fuel pump, was this taken at idle?? i was lead to believe that some skylines (32 gts-t in particular), have a variable votage unit for the fuel pump, ie. to pump less under low loads/revs.
was told this by my local tuner, so im thinking some readings taken may be lower than when the car is say cruising or driven hard.
just a thought.....
Mitsubishi Legnum - 206kw 4WD Wagon! - NOW FOR SALE!
Profile CardPM
+Quote Post
Cubes
post 23 Oct 2005, 02:28 PM
Post #10
Rank: RB26DE
Group Icon
Group Icon
Group Icon
Trader Rating : 10
The R32's do have variable speed pump control.
As soon as you touch the accelerator the pump receives the full voltage.
However, the AP Engineering PFC bypasses the variable speed control. The PFC has the pump running at full speed all the time.
I had tested the fuel pump voltage at idle, stationary with rev's and under load on boost. Voltage hardly varied, 11.2v being the peak.
Profile CardPM
+Quote Post
predator
Post #11
rb25 > rb20
Group Icon
Real Name: Gordon
Trader Rating : 36
I have just put a GTR pump in mine.. so noisey at low speeds..ok at higher speeds. I think it may be due to me using a hose clamp to secure it to the bracket.. which in turn sends the vibration right up the bracket and into the boot.. making it a noisy mofo. The stock setup has a rubber base which i think helps that.. so I have to pull it out and wrap it in some rubber.. see what difference in makes.
Interestingly, the GTR pump wiring already has secondary wiring for grounding built in..
on my stock pump, it drew 14.1v at idle.. I will have to check what is happening with the GTR one and see if the extra grounding is a good idea.
I used to have a 910 in the old r33, and was pretty quiet.
Profile CardPM
+Quote Post
Cubes
post 23 Oct 2005, 02:30 PM
Post #12
Rank: RB26DE
Group Icon
Group Icon
Group Icon
Trader Rating : 10
My pump being 3years old is probably not helping its noise, i can't hear it at all in the car now, only outside. But it is still noisy outside, not a bad noise, a tinny bit louder than a V8 VS fuel pump.
By grounding the pump to the chassis I picked up half a volt, use the supplied loom ground and it was half a volt lower. tongue.gif
Profile CardPM
+Quote Post
bj_dove
post 23 Oct 2005, 02:37 PM
Post #13
Trader Rating : 3
QUOTE(Cubes @ 23 Oct 2005, 02:28 PM)
thanks for the info, wasnt sure on the specifics of the variable voltage.
would there be any benefit of grounding the stock pump directly to the chassis? or would this interfere somehow with the standard ecu?
Profile CardPM
+Quote Post
Trust33
post 23 Oct 2005, 05:47 PM
Post #14
Trader Rating : 7
Yes could you just splice it straight from the existing ground by putting a ''t peice'' in the gound wire and ground it to the chassie???
TUTORIALS:
Profile CardPM
+Quote Post
Bl4cK32
post 23 Oct 2005, 06:17 PM
Post #15
よのトルク
Trader Rating : 21
Unless the origional ground isnt good to begin with, hence why u are redoing the wiring....
Profile CardPM
+Quote Post
